Question about Black & Decker 17 in Hedge Trimmer
Blade stop cutting like it jammed blades stop moving when trigger is pressed gets power but blades don't move
  • 5 Answers
Drive sheared
Posted on May 21, 2011
Erratic starting circular saw
Sounds to me like you have a bad cord. Clamp the saw to a workbench so that it can start and run safely without you having to hold it. Put tape or a wire tie around the trigger to hold it in. THEN plug it in. Then move the cord around, especially near where it enters the saw. If the saw starts and stops intermittently you have confirmed the bad cord. Good luck.
Mar 06, 2013 | Saws
Andis master clippers lose power
Oil the blades and then adjust them. You will need to add oil while grooming from time to time and then clean & oil them again when finished.
Sep 23, 2012 | Andis Improved Master Clipper/Trimmer...
Changed cutting blade now blade will not stay stable in position to cut
did you get the cutter release knob back in the right place or position?
is the horseshaped bracket damaged in any way?
Mar 07, 2012 | White Sewing Superlock 1934D Mechanical...
I have a 12" Ridgid
if it is only 2 months old take it back and get another one. if this not an option try some loctite on bolt
Jun 27, 2011 | Ridgid Reconditioned 12 In. Compound Miter...
I need to use my late husband's jigsaw but can't get the old, bent blade out. How do I do it and which blade do I replace it with? I need to cut a few cms off the width of a kitchen worktop. I...
Hi Jen,
It depends on whether you have an older or newer model jigsaw. Bosch makes the newer ones with a button you push that will release the blade.
On an older jigsaw, look at the handle from above the jigsaw directly in line with the blade. You should see a screw in the top of the handle. Use a screwdriver and loosen this screw, don't remove it, and when the screw is loose enough, you'll be able to pull the blade out. When you put the new one in, slide it in the slot until it seats.
A rule of thumb is to use the blade with the wider gap and larger teeth on wood, the smaller teeth on metal. Most blades will say bimetal on the metal cutting blades.
Now, the courser the teeth the rougher cut you'll get. So, if you want a nice cut, don't use the blade with the largest teeth. Move down to the next largest.
I don't have a Bosch, so am not sure which codes are for which blades, but you can't go wrong if you go by the size of the teeth.
You didn't say what material the worktop is made of. If it's wood, the second largest toothed blade should be fine.
If you've never used a jigsaw before, I could suggest a couple tips that would help you get a nice job done.
First, put a piece of painters tape or masking tape over where you will cut, draw your line and go easy. The tape will keep the blade from giving you a roughed up top edge.
When you get near the end of the cut, hold a piece of scrap wood flat against the back edge to prevent tearout.
Also, let the saw do the work, don't push it.
Hope this helps, If it does, I'd appreciate a 4 thumbs up, Thanks,
Handie Andie, "woodworker by night"
May 24, 2011 | Bosch Garden
The clippers are back together but are cutting the skin and still dont sound right did i put them together right.
Did you remove the comb and blade only? If so, the comb (the part that doesn't move and is closest to the skin) should extend beyond the reach of the blade (the part that does move left and right). Nicking is sometimes caused by excessive pressure against the skin. A properly adjusted blade will resemble someone with an underbite (extended lower jar) with the comb part extending beyond the blade.
Most clippers have a clatter adjustment screw. Turn this until the clipper clatters (buzzes really loud) and then adjust it back until the clatter stops (but not too far or you will lose power and the blade will stall or cut slowly). Be sure to oil the blades. Mineral oil (from a drugstore) will do if you can't get shaver oil.
Good luck from Detroit, MI
Apr 29, 2011 | Vacuums
We have an Oster 78950-100-700 model and I dont' think it worked out of the package. It seems that the head does not move. It is like the bottom blade is putting to much pressure on the top blade and so...
The two screws of the blade guide are tightened completely. Adjust the tension between the blade and the blade guide with the large plastic screw on the side of the trimmer (this allows the blade to move rapidly from side to side). I plug it in at this time and when the cutting blade begins to move the clipper makes much louder noise. This is normal but it sounds like it is broken, it isn't. Adjust the cutter slightly past movement. You don't want it to bounce on the guide
Feb 27, 2011 | Oster 78950-100
Reattaching the blades
The blade (the small one with several holes) gets attached to the slide spring (the thin pieces of metal with a small gap between them), through the two diamond shaped holes, with tension on the slide spring keeping the blade in position. The blade guide, the large plate with only two holes, gets mounted with the two screws. The rough surfaces of both blade and blade guide face each other.
The two screws of the blade guide are tightened completely. Adjust the tension between the blade and the blade guide with the large plastic screw on the side of the trimmer (this allows the blade to move rapidly from side to side). I plug it in at this time and when the cutting blade begins to move the clipper makes much louder noise. This is normal but it sounds like it is broken, it isn't. Adjust the cutter slightly past movement. You don't want it to bounce on the guide.
Feb 21, 2011 | Oster 78950-100
Noisy, blade seizes, used two hours
Sorry but there is no help for this equipment. Remington went bankrupt and i have not been able to get parts.
Plus they,in the past, considered this a throw away unit.
Sorry for the news.
Good Day.
Oct 27, 2009 | Remington At3017b Hedge Wizard
Grinder question
Use a pencil and straight edge to mark the cutting line on the wood. Place the wood on the saw table and line the mark up with the saw. Place the mark on the right side of the blade to ensure proper cutting. Plug the saw in and put on your safety goggles. Support the wood on the work surface with your left hand, placing it far from the saw blade. Place your right hand on the handle, and push the trigger to start the saw. Move the saw blade down onto the wood. Put constant pressure on the handle to slowly move the blade through the wood. Release the trigger and raise the blade once the cut is complete. Make diagonal cuts in the same manner, by marking the wood and lining the mark up just to the right of the saw blade. Continue as you would for a straight cut. Remove the wood from the saw. Unplug the chop saw and dust the sawdust off. Remove the dust bag from the back and empty it. Vacuum any remaining dust off of the saw.
Aug 27, 2008 | Dremel 10 Diamond Cut-Off Wheels Saw Disc...
Black & Decker 17 in Hedge Trimmer Logo
777 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
