Question about HP Photosmart C6180 All-In-One InkJet Printer
Ink system failure, error 0xc18a0001. happened suddenly, adviseme to turn it off, have turned it off, and same problem persist, it will not function a all.
    Guru:
  • 731 Answers
Resetting the printer fixes most of 0x errors. Try next reset if the 1st one did not work.
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
NVM Reset
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards
Riztech
Posted on May 21, 2011
Error 0xc18a0101 persists. Have tried solution given earlier for 0xc18a0001 without success. Ink system failure not resetting; all cartridges are full.
Its tricky mechanism, once printer detects ink system failed it cannot be resetted. Do this take out cartridges from printer., open right cover., find out logic card., remove cmos battery., wait for 5 minutes., refix batyery., power on the printer., follow the screen messges ... I hope it will solve the issue..
Sep 15, 2014 | HP Office Equipment & Supplies
Ink system has failed. Error:0xc18a0001 my printer is HP Photosmart 8250All-in-One System Failure) I refer to printer documentation Error:0xc18a0001 Turn power off, then on again. I dId this command but...
Try taking out the cartridges, and turning off then unplugging the printer. Leave it unplugged for about five minutes, the plug it in. Wait a few more minutes, and turn it on. Wait for it to completely start up, then put the cartridges back in (make sure you are putting them in correctly, I think this is your product here). If it still shows the error, contact HP customer service. They will probably say something similar, though.
Jul 06, 2011 | Office Equipment & Supplies
PHOTOSMART D7360 - INK SYSTEM FAILURE
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- the error message 0xc18a0001 "Ink System has Failed" is now gone.
Regards,
FixYa
*Please rate this solution with Thumbs Up
Nov 27, 2010 | HP Office Equipment & Supplies
HP Photosmart C6280 printer won't print and displays Ink System Failure message and Error #0xc18a0001.
Hi there
0xc18a0001.
Try the following steps to remove HP Printer Error Code 0xc18a0001.
I have put 3 ways for you to try.
1. Without turning off the printer, unplug the USB cable.
2. Remove the cartridges.
3. Wait until the message "Insert cartridge" appears.
4. Unplug the power cord.
5. Wait 60 seconds.
6. Reconnect the power cable. If the printer does not turn on automatically, press "On button".
7. Reinsert the cartridges and close the lid.
8. If the printer has a page of calibration accept.
9. Reconnect the USB cable and remake an impression.
10. If the problem persists, the machine must be repaired.
Or try 2
Turn the printer and wait until you receive the error message.
* Simultaneously press the keys "9" and "#" printer.
* While holding the button down, unplug the power cord from the unit.
* Wait a few seconds.
* Still holding the button down, reconnect the cable and turn on the printer.
* Release the buttons.
Or try 3
* Turn the printer and wait until you receive the error message.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
ERROR 0XC18A0001
Press the On button to turn off the printer.
Unplug the power cord and universal serial bus (USB) cable from the back of the printer.
Wait for 30 seconds.
Plug the power cord back into the printer.
Press the On button to turn the printer on.
If Ink system failure does not display, the issue is resolved; reconnect the USB cable and resume using the printer.
If the previous steps have not cleared the message, let us update the printer Firmware and check.
Please click on the below provided web link :
http://h10025.www1.hp.com
Once you open that web link, please follow the steps provided below :
Installation Instructions
1. Disconnect all other USB devices from the PC.
2. With the HP Photosmart 8250 series printer directly connected to the PC, click on "FirmwareEnable_Release.EXE"
3. If the ink system failure condition returns contact HP to service the printer.
Note: Do not use this patch if there is any visible ink around the product. In this case contact HP to service the printer.
This should resolve the issue.
Good Luck!!
May 06, 2009 | Office Equipment & Supplies
HP Photosmart D7460 problem
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
/Putte
May 15, 2008 | HP Photosmart D7460 Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
160 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
