Question about Zanussi Dishwashers
Zanussi dishwasher zdt 6244 how do i remove top spray arm from basket
2 Suggested Answers
  • 901 Answers
SOURCE: Zanussi ZDT 6244 Dishwasher , wash cycle completes
Try cleaning all the jet orifices in the rotating vanes. Use tooth brush. Check for dish plate is touching the rotating arm in the wash chamber. Rotate by hand for freeness.
Posted on Mar 30, 2010
Hi there, I have an ESL424 Electrolux dishwasher and I'm having some problems with it not washing dishes properly. Is there any common reason for this? The problem seems to be more apparent in the top...
first thing is to ensure the top spray arm is turning freely. make sure nothing is blocking it, for example one of them dishwasher fresheners.
also check the holes on both spray arms to ensure they not blocked up, also if you can remove the spray arms and clean them out, also clean out the filter.
i also always susjest putting the upper basket on the highest setting as high plates etc. in the bottom basket can stop spray arm turning
after checking all of the above, put the spray arms in the 12 o clock posistion and turn the dishwasher on, when it starts washing open the door to see if they have moved.
also always use a good quality diswasher tablet, cheaper ones dont always give good wash results.
Jun 25, 2011 | Electrolux 18 in. ESL424 Built-in...
The glasses are coming out of the dishwasher with a cloudy film on them. the plates are just fine but the glasses are really bad.
Check your salt container is full and the cap is on securely. Check the rinse aid is full. Check that the holes in the top spray arm are not blocked with food, plastic etc. or if you have a deodoriser hanging on the top basket that it is not obstructing the rotation of the spray arm.
This model has a diversion motor that alternates the water flow between the top and bottom arms, there is the possibility that this is faulty and the water flow is locked and only feeding the bottom spray arm. (This unfortunately will require a professional to replaced the instantaneous water heater). If you put the machine on a prerince cycle you should be able to hear the switch between the two baskets (approx every minute) to verify this, if you completely remove the top basket the change in the noise will be more obvious.
Hopefully, the first part of info will solve your problem.
Hope this helps, please leave feedback or add comment if this helps or you require further assistance.
Aug 04, 2010 | Bosch 24 in. SHY66C05 Stainless Steel...
I have a bosch dishwasher silence , when it finishs wash i open the door and find the tablet falling on the bottom or hanging on the container of the tablet part, which did not use at all..please advise,...
Check top basket is straight and moves back fully, remove top spray arm and check holes are not blocked. The water pressure from the top arm is deminished if they are blocked and once the dispenser door opens it is the top spray arm water that propels the tab into the tank. Also, check that when your tallest item is in the bottom basket it does not obstruct the rotation of the top one.
Hope this helps to give you a starting point to remedy fault.
Jul 22, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Zanussi ZDT 6244 Dishwasher , wash cycle completes , all water drains out , but the dishes are not brilliant clean & dishes are still wet
Mar 29, 2010 | Zanussi 24 in. DE6544 Built-in Dishwasher
Detergent tablet not dissolving.
sometimes the dispenser doors are not designed for tablets, and they don't let enough water in to dissolve them....next time you wash; put the tablet in one of the silverware compartments....should do the trick. and leave the dispenser door for liquid detergents only.
if this is helpful please click the correct button. thanks
Jan 22, 2010 | Zanussi Dishwashers
SHU43C06UC dishwasher cleans dishes on bottom rack but leaves dishes on top rack dirty
your top spray arm is blocked and not rotating,remove it from top basket and thoroughly clean it paying particular attention to the holes right at the ends these are angled to drive the arms round if they block up the arms will not rotate.
Nov 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water left in bottom dishwasher and after resetting to wash will not start unless the water is drained out manually
GE Dishwashers are equipped with an anti-syphon ball that generally dislodges itself and goes into the drain line. To remove it, you'll have to pull it out of it's hole. Turn the supply off and open the kick plate. Remove the supply line from the dishwasher and the drain line free from the air gap. Remove the two screws that hold it to the counter top and pull it out. Remove the lower rack and spray arm. To remove the spary arm you have a 1/4 inch head screw to undo, and on the back of the spary arm is a plastic clip. Use a small screwdriver to depress from the spray arm and pull the spray arm off. There are then two 1/4 inch screws that hold the food screen on and remove the basket. Now, underneath the dishwasher is a large manilla-colored hose with a large hose clamp that must be loosened. Pull this loose and a bit of water as well as the ball will come out. Reattach and drop the ball into the left hole under the basket. Reconnect everything and slide the dishwasher back in. Reinstall drain hose and supply line. Turn on supply. Run and look for leaks.
Jul 11, 2009 | GE Dishwashers
Top spray arm not connected to anything so dishes dont wash properly
as long as you have a spout mounted in the middle of the top basket, everything is fine , water will spray from top nozzel (mounted in ceiling of dishwasher) into spout entering spray arm.
May 01, 2009 | Dishwashers
Zanussi zdt 6252
I had the same problem with Zanussi ZDT 6252. To fix it, turn power on, close door fully, then open door, turn off then turn back on again. If you follow this sequence the machine is reset and you can select programs again.
Dec 26, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Dishwashers Logo
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
