Question about Kettler CTR2 Elliptical Trainer
My ribbed belt needs replacing on my Kettler CTR 2 Crosstrainer Elliptical...where can I get one?
4 Suggested Answers
rockitman187
  • 2559 Answers
SOURCE: Is is possible to replace a snapped belt in the
Yes it is and the parts and the installation manual can be found at the link provided
Thank you
Posted on Aug 17, 2010
SOURCE: Loud banging noise when using the Kettler elliptical trainer, ctr
This is a common problem for the CTR1, it actually sounds a lot worse than it is. It's just one of the 4 bolts that hold the front "pole" of the CTR1 in place that is broken. You will need to unscrew the bolts at the base (just move the plastic piece that hides the bolts up on the "pole"). After removing the pole you will need to remove the broken bolt from the inside of the "pole" with plyers. Then just put the pole back in the base, replace the screws (be sure to tighten them good). All will be good :)
This is a weak point of the CTR1, be prepared to run into the same problem again down the road...
Posted on Jan 16, 2011
  • 1739 Answers
SOURCE: My power pack & cable(
Contact Kettler as per the following instructions from their website: https://www.kettlerusa.com/parts. Your product is still available on the Canadian site so you should be able to order parts.
KETTLER'S Parts and Service Staff are available Monday thru Friday from 9:00 a.m. to 4:30 p.m. EST.
Requests can be submitted by phone to 866.804.0440, fax to 757.563.9273 or e-mail to parts@kettlerusa.com.
Model number of your product, your name, phone number or e-mail address is extremely important in order to process your order on time. Regular orders should be completed within 4-5 business days of order receipt. Special orders (parts required to be shipped from manufacturer in Germany) should be completed within 30 - 90 days. Our phone system is equipped to process messages in the order they were received.
Please only submit your request once by phone, fax or e-mail. Each of our KETTLER Parts and Service staff will provide you with accuracy, excellence and friendly professionalism. Please note we are only able to service US and CANADIAN customers.
To look up the part numbers for the items you require and for future reference your manual is available here:
https://www.kettlerusa.com/manuals/fitness/crosstrainers/7852-690.pdf
Posted on Jun 25, 2011
Tip
95Xi Crosstrainer Drive Belt Replacement
Drive Belt Replacement Video for LifeFitness 95Xi Crosstrainer Elliptical
Tools needed:
  • Philips Screwdriver
  • T25 Driver
  • T50 Driver
  • 2MM Allen Wrench
  • 5/32" Allen Wrench
  1. Remove the main shrouds as seen in the main shroud removal video
  2. Remove the left outer link cover as seen in the Outer Link Cover removal video
  3. Remove the left pedal lever assembly as seen in Sportsmith's Pedal Lever replacement video
  4. Remove the two bolts holding the crank arm cover in place, and remove the crank arm cover
  5. Walk the drive belt off the pulley and remove it from the unit
  6. Install the new belt around the crossover shaft first and then walk it onto the pulley
  7. Replace the remaining parts in reverse order
LifeFitness 95Xi Drive Belt Video How To Replace
on Feb 11, 2015 | Life Fitness Crosstrainer, 9100, 9500 Rear...
User manual for Kettler 07854-000 "Orion" Cross-Trainer Elliptal
Try here
http://toolbox.kettler.net/fileadmin/_kettler_dam_import/SPORT/Dokumente_-_Kataloge/Montage_und_Ersatzteile/Cro(ss)trainer/07854-_Orion_706f-1003.de,en,fr,nl.pdf
Oct 28, 2014 | Exercise & Fitness
Kettler crosstrainer UNIX PX error e2
intl.sport.kettler.net/service.../error-messages-troubleshooting.html
Sep 09, 2014 | Sport & Outdoor - Others
Kettler 67005127 belt
I just ordered a replacement belt (67005127) from Kettler USA parts.
Requests can be submitted by phone to 866.804.0440, fax to 757.563.9273 or e-mail to parts@kettlerusa.com. Model number of your product, your name, phone number or e-mail address
To ensure you have the correct part number, download the assembly & spare part manual from the corporate website in Germany.
1) To find the part number go to: Service-Center menu, select Assembly and Spare Parts
http://intl.sport.kettler.net/service-center/assembly-and-spare-parts.html
2) Select the category ("Crosstrainer" in my case) and enter the model number "XTR 1"
note: the space is important since it won't find "XTR1"
3) Select the appropriate document by selecting the language, and the download will commence.
4) These documents have an exploded assembly diagram and the list of all parts.
Nov 30, 2013 | Exercise & Fitness
A friend recently gave me a ProForm 700 treadmill that folds up & the front left side of what appears to be the belt or possibly the rotor sounds like dolphins talking when you turn it on. How can I...
dEAR Sir:
I will help you inmediately.
HOW TO LEVEL THE ELLIPTICAL CROSSTRAINER:
After the elliptical
crosstrainer has
been moved to
the location
where it will be
used, make sure
that the ends of
both stabilizers
are touching the
floor. If the elliptical
crosstrainer
rocks slightly during use, turn one or both of the leveling
feet under the front stabilizer until the rocking
motion is eliminated.
2) You must put a little oil ( tree in one oil) +a little grease in the rotor shaft.
Hoping that you fix this, anyway if you need some extra help, contact me.sincerely.
blessing.
E.CUADRA
Managua, Nicaragua C.A.
Sep 13, 2011 | Proform CrossWalk TreadSoft Treadmill
Nov 10, 2009 | Kettler Mondeo Elliptical Trainer
Kettler CTR2 Elliptical Trainer Logo
393 people viewed this question
Top Kettler Exercise & Fitness Experts
Jim London
Jim London
ray gallant
Steven's...
Steven's...
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
