Question about Panasonic KX T7220 Corded Phone
I cannot answer the phone without pressing the incoming call button that is flashing. I want to be able to answer the phone just by picking up the phone.
  • Panasonic Master
  • 2,460 Answers
From the phone, don't pick up the handset and press PROGRAM 99 then dial 22 and press STORE. Here's a problem. By default, that's what it's supposed to be and if it beeps twice when you press STORE, you didin't change it. Pick up the handset and drop it back down to exit programming.
In order to have incoming line preference, your phone has to be RINGING :-) So, if the first program didn't work, you need to see your system manager to program your phone to ring. Or find an installation manual on the internet.
Carl
Posted on May 21, 2011
Uniden dect 6 0 manual
Try pressing the intercom button (base) above the number 1, on the handset the intercom button is below the # button.
Intercom?
Whenever the phone is in standby, you can make an intercom call
between stations without using the phone line.
You can make an intercom call from any station, but only two stations
can be in an intercom call at any time.
If an outside call comes in during an intercom page, the phone cancels
the page so you can answer the incoming call.
?f an outside call comes in during an intercom page, the phone cancels the page so you can answer the incoming call.
If an outside call comes in during an intercom call, press
speaker on the base or talk/flash on the handset to hang up the intercom call and
answer the outside call
see page 15/16 of the manual at the link below.
http://www.uniden.com/pdf/D1688-2om.pdf
Sep 03, 2014 | Uniden D1688-2 Dect 6.0 1 Corded 2...
If i want to reject some call. thn how could it b possible
Without a specific make and model from you, I dont know about your phone specifically, but most cellphones,if you press the End Call button while the phone is ringing, it will reject the call.
Most cellphones send the caller to voicemail when the call is rejected. Some simply cut the caller off.
I am almost certain that this will work, I have yet to see a cellphone that doesn't.
Make sure you have Any Key Answer turned OFF in your Call Menu...
Some phones let you choose which activity answers incoming calls. Most options are Answer Key to answer, Any Key To answer, or Flip Open to answer. Choose the Answer key Only to pick up calls.
Then, when you press the End Call button, your caller will be rejected....
Good Luck!!
Feb 01, 2011 | Cell Phones
I want to push the line button to answer the phone, not just pick up the handset. I have vodavi StarPlus TR 9015
Now that's an oldie but a goodie :-)
Line Preference Incoming (called PREF LINE ANSWER in Vodavi) requires system programming from a 24 button set. It's a sequence of FLASH 50 (your extension twice) and hold, then press Flex key 8 and dial 0 HOLD.
Of course you have to know how to get into system programming and try not to do anything destructive.
Carl
Sep 09, 2009 | Vodavi Lands Phones
GE 27938GE7_C call waiting
Yes, I re-read the manual and it says (under Caller ID) to press the flash/program button to answer the new incoming call...I must have hit the pound key in error thinking I hit the flash button. I have yet to try this in real time, but will next time it arises and report if it does NOT work.
Nov 09, 2008 | Uniden Cordless Phone
Receiver dosen't pick up line that is ringing
go to programming section 5
You want Automatic Line Selection
Press feature00
left intercom button press twice (system program)
press right intercom once (central tel program)
enter # of extension to be programmed (intercom #)
press **
press line buttons in desired order line1 line 2 etc and
end with left intercom then press**
enter feature 00 to exit programming
Dave
Aug 26, 2008 | Avaya Corded Phone avaparp18d
Lost the time and date line in the display
Unplug the phone, wait one minute, then plug it back in and see if the display comes back on. Press the program button, press 22 on the dial pad, press program button again ( if the phone is ringing on the incoming call and not just flashing).
May 31, 2008 | Panasonic KX-T7630 Corded Phone
Uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Jan 20, 2008 | Uniden Cordless Phone
Epson Aculaser CX11NF won't receive faxes
Change your incoming mode from "autoswitching" to "TAM" (TAM is short for telephone answering machine" Press the "Setup" button on the control panel Use down arrow twice to select "FAX SETTINGS" Press the right arrow once The FAX SETTINGS menu appears Press the down arrow twice to select RECEPTION SETTINGS Press the right arrow once Press the down arrow unit INCOMING MODE appears in display Press the right arrow once Press the down arrow until TAM appears in display Press the right arrow once. That should do it for you If I got lost somewhere, it is in your Operator's manual - look in the index for TAM Hope it helped Ed
May 22, 2007 | Epson ACULASER CX11NF All-In-One Printer
Panasonic KX T7220 Corded Phone Logo
176 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
