Question about LG DLEX3001R Dryer
Lint filter catches on clothes and rips them. What can I do?
4 Suggested Answers
  • 77 Answers
SOURCE: Our dryer lint trap won't go down all the way and
It may be backwards. But the first thing I would look for is if there is lint caught in the shute keeping it from going down all the way. If it is a newer model there is a lint screen sensor that may have come unattached and keeping the lint screen from going down all the way. Good luck.
Posted on Apr 20, 2009
protek480
  • 1723 Answers
SOURCE: LEQ1442ES--Nasty Smelling Clothes--Major lint inside
They make a 'air vent' lint cleaner and there is a handy brush made for cleaning your fridge coils that would work great. After you clean it, toss a 'Bounce' dryer sheet in to freshen it up!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 08, 2009
Daniel S
  • 4323 Answers
SOURCE: I have a front load
Hi
I don't think that the part you have bought is correct one; you can buy the parts for your LG DLE2601W dryer from this link. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 16, 2011
Top load GE High Efficiency washer has been leaving excessive lint on dark clothing. How can I fix this problem?
Clean out filter also spin clothes in dryer the lint catcher in the dryer will catch the lint.
Nov 15, 2014 | Washing Machines
My electric dryer won't dry clothes. Doesn't get hot, what's wrong with it?
how is the lint filter maybe it is too full of lint and the dryer will not heat up to protect you from burning doen your house when the lint filter gets too hot and catches fire. Just a thought
Oct 28, 2014 | Dryers
My bosh next 700 series I not heating to dry the clothes I checked the vent and it not clogged inside and outside. Help pls
Try to reset the thermal cutoff, but should be no reason why it should have tripped.
The actual operating procedure is
The air enters the body of the dryer through the large opening in front of the dryer
Then the air is sucked past the heating element and into the tumbler. (the tumbler is the large bin holding your clothes).
Then after the air has circulated around the clothes, it enters the door and is directed down through the lint screen. (this catches lint from the drying process... some clothes producte more lint (such as towels) than others (such as panties) because the weave is more coarse.
Then the air passes through a duct in the front of the dryer (after the lint filter) and into the fan.
The fan forces the air into the duct leading out the back of the dryer, at which point it exits your house.
It is extremely difficult to tell you the problem without being there to eliminate any one of several things that could be the problem. First, when you have the dryer turned on and have the heat setting set to cottons, is there ANY heat at all? If you feel the door, and there is SOME heat but there is not much heat on the clothes when you feel them, the intake opening in front of the dryer is probably in need of cleaning.
While you should always clean your lint filter after each use of your dryer, you should also periodically clean the intake at least once every six months. If you do not, the air intake is eventually restricted and the drying efficiency of the drye is affected. Consult your owner's manual for the exact location of the air intake.
IF THE INTAKE IS CLEAN and clear of obstruction, and there is still not enough heat to dry the clothes, but the door feels warm when dryer is operating. Then this would imply that the exhaust duct needs cleaned out. This is something that definitely needs done periodically to prevent fire. The exhaust duct collects additional lint that the lint filter misses. While this is a small amount of lint, over a period of time, this builds up on the inside of the exhaust duct and prevents the flow of the exhaust which reduces the heated air flow around the clothes in the tumbler. This results in the air not flowing and not becoming warm enough to dry the clothes efficiently.
IF THERE IS NO HEAT AT ALL: Then there is a likelihood that the heater itself needs replacement. This is a costly repair and you will be wise to invest in another dryer instead.
The working process of your clothes dryer is a relatively simple machine. It brings in air, heats the air, flows the air through the tumber where the clothes tumble loosely with the heated air circulating around them, then the air passes through the lint filter as it exits out your home. The lint filter is necessary because those tiny pieces of fabric (lint) can collect in your exhaust duct and catch fire. This is the major cause of dryer fires. This is why you should also periodically clean out your exhaust duct. Even though you have a lint filter, the lint filter does NOT catch all the lint and lint will eventually coat the interior walls of the exhaust duct.
Apr 20, 2012 | Bosch Dryers
The lint filter does not fit properly in the lint trap. The corner of the filter catches an item of clothing and twists it. I have to check it several times to clear the item away. I assume this...
We have the same model and experience the same thing. The way I fix it is to remove the filter, then with a flash light I look down into the lint trap. You will notice that lint has built up in the track where the lint filter sits. I use a wooden skewer to run along the track and lift out the lent. Hope that helps
Aug 21, 2011 | Samsung DV448AEE Electric Dryer
My kenmore elite dryer lint screen won't go all the way don't into the slot. It is catching my clothes while they are drying them and tearing, ripping and stretching garnets out of shape. Has there been a...
This may sound silly, but have you tried turning the screen around? I found that I was trying to put mine in backwards, even though it looked right.
Feb 19, 2011 | Kenmore Dryers
We have had a consistent problem with our dryer. The lint filter eats any staps in the dryer. I have found straps from bras, tops, and belts twisted around the lint filter. They get caught on the edge...
sound like front felt glide assy # upper felt seal part #134440200 lower felt seal #134134700 u can order these from sears.com
these componets support the front of drum and when felt wears away then clothing slips in gap and when dreyer tumbles clothing gets snagged in gap and tears clothing and leaves black scuffs
Jan 31, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Ijwant to dry my cloth but when i turn on it appear check filter how i am going to fix
You should empty the lint filter. The lint filter catches all the lint from your clothes and will need cleaned occassionally. I clean my lint filter after every load. Towels usually clog the filter faster than other clothes.
Aug 07, 2010 | LG DLG5932W Gas Dryer
My dryer won't heat
is it a condenser or vented tumble dryer
Jun 28, 2009 | Dryers
Lint problem
You'll need to remove the hoses from the pump and inspect the inlet strainer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 27, 2009 | Kenmore Washing Machines
LG DLEX3001R Dryer Logo
406 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
