Question about Weslo Cadence 200 Treadmill
Regarding my Weslo cadence 200 treadmill. The belt has migrated to the left side of the machine and is starting to fray. I am at a loss as to what to do to fix the problem and keep it centered. Fixable?
    Master:
  • 448 Answers
At the end there is adjustment screws they have to have some way to adjust the belt
the screws are probably covered by tape or plastic plugs the adjuster's most likely are
phillups screws it wont take much to shift the belt maybe a 1/4 turn at a time
let me no if you find it the screws are Ware you first step on the tread mill
hope this helps you
bob
Posted on May 21, 2011
The belt keeps moving towards the left side of the treadmill and rubs the side. How can I adjust the belt to fix the problem? It is a Weslo Cadence SR12 model. Thanks!
There are Allen bolts on both sides of the bottom on the front (away from the console) of the treadmill. Turn one one way and the other the other way to adjust the belt. If this does not work, your belt is probably worn and stretched and needs to be replaced. See Treadmill Parts to order a new one.
Aug 29, 2011 | Cadence Weslo 825 Treadmill Walking Belt
Walking surface will only move very slowly. The belt seems tight enough, tried to tighten 1/4 turn, still not moving properly. Treadmill is a Weslo Cadence 450, bought a few years ago. Thanks
lift the sides of the w/belt the hieght should be 2-3 inches. if more to loose,tighten it up. still have a issue take hood off and check the motor belt. if you find a bunch of black dust. your belt is worn or on its way out.PS you can find the belt on the web.
Mar 09, 2011 | Cadence Exercise & Fitness
My Weslo Cadence 840 treadmill mat keeps trying to run off to the left
Check that the plastic end cap has not broken first. If it is OK, adjustment should be simple.
Start the machine running. With the allen key provided (3/16) simply tighten (clockwise) the left hand rear roller adjustment screw about 1/4 turn and observe the belt. If it is way off, you might need to turn 1/2. Let the belt do a couple revolutions before adjusting more. A very small adjustment id usually needed to straighten the belt. If it is way off, there may be a more serious problem..
Feb 26, 2011 | Weslo Exercise & Fitness
I have a weslo cadence 200 cs treadmill. I changed the batteries but the display keeps blinking 0
You probably need a new treadmill display screen but one thing you can try is to get a 6 volt power suppply and use the power supply instead of the batteries.
May 20, 2010 | Exercise & Fitness
Cadence weslo 340 cs treadmill wont engage treadmill
If the transformer does not produce a "hum" the power is either not reaching the rectifiers or the rectifiers have died . Not likely if the machine was running last time prior to being put away. Try physically advancing the tread/belt to set the motor to a different contact starting point since corrosion (ambient humidity) may have dulled the motor contacts(brushes).
Dec 31, 2009 | Cadence Exercise & Fitness
My weslo cadence 200 treadmill belt keeps slipping to the left. i keep tightening and loosing it to keep it even but i keeps sliding to the left
please look under the bottom of the treadmill and be sure that your alignment brackets are not benmt/missing. (put the machine in the storage position and look about 2/3 way down the side of the belt) you should see a metal bracket on each side pressing in on the belt. They should be pressing in about 1 1/2 -2 inches to help track the belt.
Nov 24, 2009 | Proform XP Weight Loss 620 Treadmill
The walking belt slips to the left when walking
There are two allen bolts (one on each side) at the end of the machine. These bolts adjust the tension on the belt. If they are not adjusted evenly the beft will gradually shift of the more loose side.
Sep 29, 2009 | Cadence Weslo 825 Treadmill Walking Belt
How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Mar 14, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Weslo Cadence 200 Treadmill Logo
126 people viewed this question
Top Weslo Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Jim London
Jim London
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
