Question about Olympia Supertype 330 Typewriter
Problem I can not get the typewriter to stop typing symbols. I do not have a slidebar I,II or III thank you for your help Brigitte
  • Olympia Master
  • 3,594 Answers
Check to see if it is in PS (proportional space).
DickyO
Posted on Aug 15, 2008
When typing numbers a strange symbol appears in it's place, not a code symbol or a cap symbol.
Hmm, I have a sd 670, and I have a button called KD II, and it makes symbols appear. If you have that key, hit code then hit it. That should bring you back you back to normal.
Jan 29, 2014 | Smith Corona SL 580 Electric Typewriter
How can I determine whether my typewriter is a Selectric II or III?
The video shows the models C, Selectric I, and Selectric II.
If your typewriter doesn't compare to any of these in the video it is most likely a Selectric III.
This will also help:
The Selectric III featured a 96-character element vs. the previous 88-character element. IBM's series of "Electronic Typewriters" used this same 96-character element. The 96-character elements can be identified by yellow printing on the top plastic surface and the legend "96," which always appears along with the font name and pitch. The 96- and 88-character elements are mechanically incompatible with each other (they won't fit on each other's machines) and 96-character elements were not available in as many fonts as the older 88-character types.
Jul 09, 2013 | Office Equipment & Supplies
I am not able to type the @ symbol on my Brother typewriter. Model #EM-530. I have tried everything it is driving me crazy. Thanks for your help!!
If it is typing the alternate symbol on the key you are in KBII. The code key with the key in the top row labeled KBII will get you out of that mode.
DickyO
Aug 09, 2011 | Brother EM-530 Typewriter
Need to understand how to operate typewriter
In order to type the extra symbols you must be in keyboard II I believe it is hold the code ket while pressing the 5 key.
DickyO
Mar 02, 2010 | Swintec Office Equipment & Supplies
Improper charcters
You didn't say what kind of typewriter it is or if it only happens on the symbol keys.
Jul 21, 2008 | Lexmark Wheelwriter 35 Series II...
IBM selectric I...88 charter type balls
All the selectric I & II's take the same elements the sel III uses a 96 char. one that is printed in yellow that isn't compatable.
DickyO
Jul 06, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 15 Series II -- the paragraph symbol appears when we type the @
change your wheel with word`s and everythin is ok,possibly mark @ is broken on typewrither wheel
Feb 01, 2008 | Lexmark Wheelwriter 15 Series II...
Help me with my typewriter
You have a Code Button on the typewriter..hold this down while pressing the keytop with the Symbol wording or Icon. Or you have a slide lever in I II or III keyboard.Change this and it should go back to normal.
Jan 24, 2008 | Olympia Supertype 330 Typewriter
IBM Selectric III - ribbon won't turn
Make sure the ribbon cartridge lever is closed and that the ribbon is on the outside of the shock wire (where the ribbon exits the left side of the cartridge)
Jan 20, 2008 | Lexmark Wheelwriter 15 Series II...
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
Olympia Supertype 330 Typewriter Logo
52 people viewed this question
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Alan W Kelly
Alan W Kelly
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
