Question about Hayward Phantom Pool Cleaner Complete with Booster Pump
Immediately rises and stays on top of the water
  • 640 Answers
You might need to check to pool cleaners floats. You might have too many floats attached or might have them improperly placed. It is also possible that you have the pressure thought the cleaner turned up to high. It could be propelling the cleaner off the pools floor. More severely, it could be that your cleaner head is cracked and has taken on large amounts of water. You would need to have this professionally prepared.
Posted on May 24, 2011
  • Jessica  Harwell
    Jessica Harwell May 24, 2011
    There is also a switch on this cleaner that you can set to "top, bottom, or automatic". If you have it on automatic and its not cleaning the bottom, change it to top.
Pentair chlorinator tablets not dissolving. Also the dispenser tube loses water level when pump is down.
make sure water is running into unit take off top see if water rises run about 3.5 let water rise then close top
Aug 08, 2013 | Pentair 2.0 Hp Whisperflo Pump
Tip
Hate streaky windshiels in the rain? Wipers stop all together?
I take an old pair of hose (womens), buy some loose tobacco, cut the hose to about 1 foot long making sure there are no holes in the toe or elswere, put a 1/4 cup or so of tobacco into the sock, tie a knot so the tobacco stays put. Then open the bonnet of the car, find the windshild wiper water tank drop the end of the sock into the solution or plain water, make sure the upper end of the sock is securely fastened to something outside the tank so you won't loose the bag you created and you'll be amazed at how clean the winshield will be next time you use them after squirting the windshield as usual.
If your wipers stop working all together and you can't see to drive, take a sock as the one I described, get it wet and wipe the winshield with it. The rain will then sheet off the galss as if there was no rain at all. no drops can form. The tobacco breaks the surface tention. Want proof? Take a glass of water, fill it to the top just short of spilling over. You'll notice the water actually rises above the edge drop one grain of tobacco or black pepper and the glass will immediately release the water out of the top of the glass.
on Jun 14, 2010 | Lamborghini Lm Cars & Trucks
Pool heater won't heat water
How big a pool? You normally will not notice a temperature rise immediately. On average, swimming pools will see a one degree rise in temperature every 45 - 90 minutes.
Jan 22, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Bread does not rise enough I have carefully measured ingredients use rapid bake setting fleichmans rapid rise yeast checked water temp still having problems I have tried 4 times regular and rapid rise and...
A few tips.
The yeast must be absolutely fresh, use sachets instead of packets.
Keep yeast well away from the fats and liquids.
The fast rise setting will produce less rise than the full program.
You must only use strong bread flour.
Open lid immediately beep sounds.
Jan 10, 2011 | Panasonic SD-YD250 Bread Maker
My Frigidaire freezer (not frost free)won't stay cold
look at level side to side , and front to back. if not level door can leak . you will see water where it is leaking. check defroster is if staying on .
Feb 18, 2018 | Frigidaire Freezers
Hello! I change the rubber sealer to my Bialetti 12 cup yesterday and since then the water stays in the bottom and does not rise to the top. The sealer is properly put in. I have not done anything...
This happened to me, too....the gasket needs to be broken in so that it seals properly, which will happen once it's been used several times. In the meantime, just tighten the pot together extra tight and that will help to seal the gasket properly. After several uses, you won't have to tighten it so much and can go back to how you've always done it. I hope this helps!!
May 19, 2010 | Bialetti Moka Express 6-Cup Coffee Maker
Aprilaire Humidifier Model 560 - Humidity Not Rising in House
water trough on top filling up. do not clean it too much as crud distributes water across top better.
Dec 25, 2008 | Aprilaire 700 Humidifier
Hayward Phantom Pool Cleaner Complete with Booster Pump Logo
109 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
