Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
10 flashing lights then 9
My Sony KP-46WT520 began not turning on and the standby light would flash 9 times, pause, 9 times....etc.. It would still turn on eventually but today it wouldn't turn on again and now it is flashing 10 times first then it goes to 9 flashes, pause 9 flashes, etc....
I am thinking of replacing the G-board but not sure. Someone had mentioned just replacing D6116 or D6301 on the G board. What do you recommend?
Thanks for any advice you may have :)
  • 3 more comments
  • tyart22 Sep 13, 2008
    My Sony TV Kp-46WT520 stanby light flashes 9 times pause and 9 times goes on ......
    Is there any component can i change for the G board, the relay?
  • darlakay Jan 21, 2009
    The TV won't come on at all. I am thinking I need to replace the entire G-board but Sony said they no long sell them....lol :) Crazy because the TV is only 3 years old!
  • Anonymous Feb 28, 2009
    i replaced the diodes but still nothing? can anyone help 10 blinks then 9
  • olyman69
    olyman69 Feb 15, 2012
    I've got the same problem. 10 flashes, then 9,9,9,9,... Granted the tv isn't new, but it isn't that old. What's the fix to this problem and the costs associated with it ?
  • olyman69
    olyman69 Feb 16, 2012
    I've found out that if I completely shut my DirectTV box off, the tv comes on. If the Direct TV box is on, I get the 10 flashes and then the 9,9,9. This problem just started after I installed a new Direct TV box. Anybody heard of this or dealt with it ?
    Problem Solver:
  • 3 Answers
You need to see if you can get tv on in service mode.
if it will only work in service mode then yes replace those 2 diodes
Posted on Aug 25, 2008
  • 125 Answers
Make sure it is 9 blinking it may be 10
Posted on Aug 20, 2008
Sony kp-51ws520 when turned on just has standby light flashing . the rest is all dead, no picture or voice.
Standby flashing light shows that tv got some internal problem. How many times standby light is flashing is info that provide info about what section of tv got problem.
Count standby light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Jul 21, 2010 | Sony KP-51WS520 51" Rear Projection...
Sony kp-46wt520 standby light flashes 10 times. Does not power up.
hello Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
shaun
Dec 27, 2009 | Sony KP-46WT520 46" Rear Projection...
Sony kp-46wt520 rear projection tv: standby light flashes
Two things here.
1) This is a CRT based set so there is no "lamp" involved.
2) The standby light should be blinking a repeated count of blinks with a 2 second pause between counts. Please report the exact count here. This will indicate the circiut in which a problem was detected.
With the above information, we can provide you with a more detailed description of the problem as well as the likely solutions and cost.
Thanks,
Dan
Sep 17, 2009 | Sony KP-44PX3 44" Rear Projection...
Sony KP-46WT520 Standby Blinks 10 Times
High voltage in TV got problem and thats why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
Apr 15, 2009 | Sony KP-46WT520 46" Rear Projection...
Stanby just flashing 5 times - din't turn ON
Most likely the CRT drive boards have a bad video output IC or the A board has a defective IC452
Apr 06, 2009 | Sony KP-46WT520 46" Rear Projection...
Light flashes 9 times
that means it has an audio error.
Dec 31, 2008 | Sony KP-46WT520 46" Rear Projection...
Should i have this fixed or buy a new tv?
OK LOOK IN YOU STK RESOLD YOU IC STK AND BE FIX
Dec 29, 2008 | Sony KP-46WT520 46" Rear Projection...
Stand by light flashes 9 times
replace the zero crossover detect diode in the power supply.
Nov 11, 2008 | Sony KP-57WS520 57" Rear Projection...
Troubleshooting
I will need the model number of your set and how many times the LED is blinking in between pauses.Then I should be able to help you with wahts happening with your Sony
Jul 04, 2008 | Sony Televison & Video
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
742 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
