Question about Kenmore 62802 Electric Dryer
Hello, I have a kenmore electric dryer model 11063932101 that was having difficulties heating while drying and it took a long time to dry the clothes. After a few weeks of this it began to have a burnt smell and the heat would be there sometimes other times not. Now, it began to dry for a while and shut off then come back on after 10-15 minutes run for a bit then shut off again repeating the process over and over. After doing a little reading on similiar issues I went on line to sears parts and discovered several parts that may have been related to my problem. I found that it has a high-limit thermostat, a thermal cut-off fuse, a non-resettable thermal fuse and a thermistor that I suspected maybe the problem. I replaced the high-limit thermostat and thermal cut-off fuse and now I have plenty of heat, but it still shuts off and on. Interestingly, after putting the parts in I turned it on and let it run for a few minutes then opened the door to check and to see if it was getting hotter than before, which as I mentioned it was providing plenty of heat, but after closing the door and pushing the start button it made a brief humming noise and failed to start... What should I do next...any ideas?
    President:
  • 3,074 Answers
The cutting off is a restricted vent, you will need to disconnect the vent and run a load of clothes, then clear the vent of the restriction. the humming is the motor, either the belt is off/broken or the motor is stuck, you will need to take it apart and see what the problem is, I am not sure if the Kenmore has a belt brake trip on the motor or not, if it does it will have to little buttons where it plugs into the motor one button trips it the other resets it. Hope this helps Tim
Posted on May 20, 2011
Kenmore 110.66902690 electric dryer does not dry completely
Dear Barry,
Try 2 things.
One, be certain the clothes are very dry coming out of the washing machine.
If the washer leaves the clothes wet ( like the belt might be slipping), it can take the dryer forever to finish drying the clothes.
You can tell by hand-wringing them.
You should not be able to get any water out of them by hand-wringing after they have spun dry in the washer.
Two, try running a load with the vent hose unhooked off the back of the dryer.
If this fixes the problem, you are having a "clogged vent" issue somehow.
Be blessed.
Apr 16, 2013 | Dryers
My Kenmore 6.7 cu ft he2 Super capacity electric dryer is taking twice as long to dry. no error codes
It sounds like a connection problem with one of the heating elements, or perhaps only a clogged input or output hose from the dryer. Either of these could cause the problem...also, a burned out electric element.
Jan 15, 2013 | Kenmore Dryers
My Kenmore dryer does not get hot enough to dry a load
If your dryer IS still heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire exhaust duct run to ensure you have no kinks or clogs anywhere. The following link explains many of the problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to actually overheat. Eventually, this can lead to component failures and is the source of fire hazards.
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate along the door opening) and let me know. I hope you find this information helpful.
May 31, 2010 | Kenmore 62802 Electric Dryer
Hello! Is it possible to replace a heat sensor?
put it on timed dry to see if it does it if not the sensa dry is bad
Apr 19, 2010 | Kenmore Elite HE4 Electric Dryer
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
Kenmore dryer will not dry completelt in even heat cycle
This video will help you to determined what you need,
copy n paste
http://www.youtube.com/watch?v=HRKIU4LiS20&feature=related
for parts n prices
http://www.partselect.com/AppliancePartList.aspx?Brand=Kenmore&Appliance=Dryer&ModelNum=&Type=Electrical%20Parts,%20%20No%20Heating%20Elements&MinSize=U&MaxSize=U&Electrical=Y&Metal=U&Plastic=U&OneColor=U&PageSize=15&FirstPart=1
Was this helpful?
Apr 29, 2009 | Kenmore 63942 Dryer
Kenmore dryer 400series electric not gettin hot enough to dry
you might have a open heating element. ohm out your heating elements.
Feb 20, 2009 | Kenmore 62602 Electric Dryer
Kenmore dryer takes to long to dry
You may have to get inside the exhaust assembly ...somtimes there are lint buildups that occur and cause long drying times. Also make sure you don't have a DUAL heating element model. I had one and only one of the elements worked when I repaired the second one it worked great. Most likely is the exhaust block however. Hope this helps.
Jan 18, 2009 | Kenmore 659 Electric Dryer
Clothes Dryer not drying
Hello, check to make sure that the dryer is venting properly, is the hot air getting out of the vent ?. If not clear the restriction or unkink the vent then try again. good luck
Dec 16, 2008 | Hotpoint NVL333EY Electric Dryer
Kenmore 62802 Electric Dryer Logo
345 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
