Question about Bosch Water Heaters
Bosch water wizard 16p not heating properly - sometimes warm but only for a few minutes then goes cold again. Very rarely does it produce 'hot' water Bosch told us to replace a seal which we did and it helped for a month or two then went back how it was
  • sam3158 May 23, 2011
    I cant find anything on Google about this product being recalled
    President:
  • 1,902 Answers
This water heater has major issues with this problem. I have seen it many of times, every few months back out at the job replacing the seal. The best thing I can tell you from what customers tell me is to file a complaint with Bosch, most of the time they pay for the new part and it have it install. I believe that there was also a recall for this issue. You can check it by looking up your model number and the "recall"
Posted on May 21, 2011
I have a power star ae115 electric tankless water heater. It has performed flawlessly for approximately 5 years. A couple weeks ago it stopped producing HOT water but is still heating to Luke warm. The "...
5 years is about the lifespan for tankless.
You might have shorted element. That would explain cooler water and tripping reset.
Test element: power is off, disconnect wires from element; ohms = voltage squared divided by watt rating of element
http://waterheatertimer.org/How-to-test-water-heater-element.html
Call service technician./ Call Bosch
http://waterheatertimer.org/pdf/Bosch-AE115-AE125_manual.pdf
Gene
Oct 14, 2014 | Water Heaters
Water turns cold very quickly
I had the EXACT same problem (installed my tankless last winter and worked fine, now this summer it fluctuates, have to turn the shower completely off and then on again to get any hot water and then it only lasts for a couple of minutes!) Argh - it is frustrating!
Here's what I found: the demand for hot water is lower during the summer (hot) months because the "cold" water coming in is already quite warm. You don't need as much hot water to make the shower temp comfortable. SO, my tankless was shutting off due to low flow demand. I've removed the flow restrictor from my shower head and it helped alot but didn't completely solve the prob. Next step is what has been recommended to me by several people but is much more expensive - change the pressure valve on your shower to a temperature valve. Or just wait til winter and it should work ok again :)
Jul 06, 2010 | Bosch & Tankless LP Hot Water Heater
Bosch tankless GWH 2400 ELP in use 2-1/2 years. Whenever it is below freezing, we have problems with EC and/or EA errors, and no hot water. Sometimes restart will work. Bosch customer support is useless. I...
are u using well water or hooked up to city line if well water --may be to cold for unit if water is below a certain temp unit usually goes into error or shuts down if un heated space where water heater is u may have to warm [ insulate ,heat tape etc]the incoming water usually water that around 40 degrees causes problems
Feb 03, 2010 | Bosch & Tankless LP Hot Water Heater
Water heater doesn't keep running
Sounds like youo have a problematic gas valve. But I would get a gasfitter to replace it. Not for the amatuer.
Nov 20, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Bosch AQ125BNG Burner goes out even though the
Often, this is the result of a restriction of exhaust gases. This type of hot water heater must be adequately vented, (per installation specs). I found this out after taking a number of cold showers. :^( Two years later, and still counting, no more problems. :^)
Jul 11, 2009 | Bosch Water Heaters
Bosch 16p gas, keeps going hot and cold
check the thermostat, you will probly need someone that has worked on the same kind of unit, they are not all the same {tankless} I would suggest a repairman,, there is a little bit much to explain how to do it over the internet,
Jun 22, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Bosch Water Wizard 600 pilot light keeps going out
You need a new thermocouple. Its the little stick like thing that the flame heats up to tell gas valve to open.
Jun 15, 2009 | Bosch Water Heaters
Bosch hot water service 16p burner shuts down
a tankleess water heater doen's have a piliot? but check the vent outside make sure nothing is blocking it, if it detects the exhaust thru the cold air intake it will shut off and over heat, other then that it would have to be the control board
Jun 05, 2009 | Bosch & Tankless LP Hot Water Heater
Bosch gwh-425ef nat gas on demand heater
sound like pcb board is failing - control board
Nov 09, 2008 | Bosch & Power Vent Water Heater
Water Heaters Logo
188 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
