1996 BMW 318 Logo
Posted on Aug 15, 2008
Over heating - 1996 BMW 318
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 18, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
323
Points
Bmw 318ti its over heating we change thermostate,radiator radiator cooling sensor we inspecte the water pump looks ok what could cause that???
Anonymous
Level 1:
  • Posted on Aug 30, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
323
Points
0
Remove the water pump first, bmw's often fail on their plastic impellor, if thats is the fault an easy and relatively cheap repair.
good luck lee
My passenger side power seat, and seat heater stop working simultaneously on my Cadillac SRX 2011 model. The Passanger side air bag light also came on simultaneously. I checked the fuses and mini circuit...
Looking at a wiring diagram for the passenger seat an checking wiring colors mite help you figure it out . But then again maybe not . Electronic's involved here , Right door module .
Heated Seat Components
The heated seats consist of the following components:
• Left heated seat switch
• Right heated seat switch
• Memory seat module
• Left door module
• Right door module
• Left seat cushion heating element
• Left seat back heating element
• Left seat cushion temperature sensor
• Right seat cushion heating element
• Right seat back heating element
• Right seat cushion temperature sensor
Modes of Operation
The heated seat module (MSM) controls heated seat operation for both the driver and passenger seats. There are 2 modes of operation available for heated seats; both the seat cushion and seat back heat, or seat back only heat. When a heated seat temperature signal request is received, the MSM will activate both the seat cushion and seat back heating elements. When the heated seat BACK ONLY mode button is pressed once the MSM will deactivate the seat cushion heating element and leave the seat back heating element ON.
Heated Seat Switch/LED Indicators and System Operation
The left and right heated seats are controlled by separate heated seat switches located in the door panels. Ground is supplied to the heated seat switches through the switch low reference circuits from their respective door modules. The door modules also control the heated seat switch heat mode and temperature indicators. The memory seat module (MSM) controls the heated seat operation for both, the left and right heated seats.
The following describes the sequence of operation and how the MSM responds to each of the switch inputs.
• High Temperature--When the heated seat switch is pressed once, ground is applied through the switch contacts and the switch signal circuit to the door module indicating the high heat request. In response to this signal, the door module applies a low current voltage through the 3 temperature indicator control circuits illuminating all 3 LEDs indicating the high temperature mode. The module then sends a message via the GMLAN serial data line to the MSM indicating the heated seat request. The MSM then applies battery voltage through the heating element supply voltage circuit to the seat cushion and seat back heating elements. At the same time, it supplies a ground through the element low reference circuits to the seat heating elements.
• Medium Temperature--When the switch is pressed a second time, the MSM sets the temperature level to medium heat. The door module removes the voltage from the high temperature indicator leaving 2 LEDs illuminated indicating the medium temperature mode.
• Low Temperature--When the switch is pressed a third time, the MSM sets the temperature level to low heat. The door module removes the voltage from the medium temperature indicator leaving 1 LED illuminated indicating the low temperature mode.
• System OFF State--When the switch is pressed a fourth time, the MSM removes the battery voltage and grounds from the heating elements. The door module removes the voltage from the low temperature indicator, indicating the system OFF state.
• Back Only Mode-When the heated seat is ON and the BACK ONLY mode button is pressed, ground is applied through the switch contacts and the heated seat back only mode signal circuit to the door module. In response to this signal, the door module sends a GMLAN message to the MSM indicating the back only mode request. The MSM then opens the ground path to the seat cushion heater element, leaving the seat back heater active. The door module turns OFF the seat cushion/back mode indicator, then applies a low current voltage through the heated seat back only mode indicator control circuit illuminating the back only mode indicator.
Know how to test an what test is the key to finding the problem .Not guessing . The connector you found may or may not have anything to do with it . What color are the wires ? I have factory service repair manual . Does it have memory seats ?
The Memory Seat System consists of the following components:
• Memory seat module (MSM)
• Seat horizontal motor
• Seat front vertical motor
• Seat rear vertical motor
• Seat recline motor
• Lumbar horizontal motor
• Seat horizontal position sensor
• Seat front vertical position sensor
• Seat rear vertical position sensor
• Seat recline position sensor
• Lumbar horizontal positional sensor
• Seat adjuster switch
• Seat lumbar switch
• Memory seat switch
• PWR SEATS Circuit Breaker 30 A
• MEMORY RPA Fuse 7.5 A
1helpful
2answers
Where is the on button to turn on the heated seats in a 2007 ford five hundred? I just got the car and I don't know where it is and I was told there was heated seats.
The heated seats are a luxury feature that heat the front seats. This provides maximum comfort for the driver and the front passenger. To turn on the heated seats, press the heated seat button, which is a picture of a seat. There are two of these buttons, and each are located on the center console. The button on the driver's side of the console controls the heat for the driver's seat, while the button on the passenger's side of the center console controls the heat for the passenger's seat. Pressing the heated seat button will turn the heated-seats onto their highest setting. Pressing the button a second time will lower the heated seats to their medium setting. Pressing the button a third time will result in the lowest setting. Pressing the button a fourth time will turn off the heated seats. There are three lights next to the heated seat buttons to indicate what setting the heated seats are on.
Tip
The heated seats will only work when the engine is running.
1helpful
2answers
Trying to find which fuse is for the heated seats on a 2004 ford explorer sports trak
Heated Seats
This system allows the electrical heating of the front seats on passenger demand.
The components of the system are:
  • the seat heating elements located in the seat cushion and backrest.
  • the heated seat control switch, located on the seat side trim panel.
  • temperature sensors located in the seat cushion heating elements.
  • heated seat relay.
Do both front seat heaters not work ? Do you know how to test electrical circuits with voltmeter ?
PINPOINT TEST J: THE HEATED SEAT IS INOPERATIVE Test Step Result / Action to Take J1 CHECK HEATED SEAT SWITCH OPERATION
  • Key in ON position.
  • Press the heated seat switch on the driver and passenger seats.
  • Are both heated seat switch indicators illuminated?
Yes
If both indicators illuminate, Go To Pinpoint Test K . If only one indicator illuminates, GO to J5 .
No
GO to J2 . J2 CHECK THE HEATED SEAT RELAY CIRCUITS
  • Key in OFF position.
  • Disconnect: Heated Seat Relay C3250 (located under the driver seat).
  • Measure the voltage at heated seat relay C3250-86, circuit 1003 (GY/YE), harness side and ground; and between C3250-30, circuit 566 (DG), harness and ground.
  • Are the voltages greater than 10 volts?
Yes
GO to J3 .
No
REPAIR inoperative 1003 (GY/YE) or 566 (DG) circuit. TEST the system for normal operation. J3 CHECK HEATED SEAT RELAY GROUND CIRCUIT
  • Measure the resistance between heated seat relay C3250-85, circuit 57 (BK), harness side and ground.
  • Is the resistance less than 5 ohms?
Yes
GO to J4 .
No
REPAIR circuit 57 (BK). TEST the system for normal operation. J4 CHECK THE HEATED SEAT RELAY
  • Install a fused jumper lead between heated seat relay 3250-30, circuit 566 (DG), harness side and heated seat relay C3250-87, circuit 1064 (YE/LB), harness side.
  • Do both heated seat indicators illuminate when pressed?
Yes
INSTALL a new heated seat relay. TEST the system for normal operation.
No
REPAIR circuit 1064 (YE/LB) to switches. TEST the system for normal operation. J5 CHECK INOPERATIVE HEATED SEAT SWITCH INPUT
  • Disconnect: Heated Seat Switch C320 (Driver) or C321 (Passenger) for the inoperative heated seat.
  • Measure the voltage between heated seat switch C320-2 (driver) or C321-2 (passenger), circuit 1064 (YE/LB), harness side and ground .
  • Is the voltage greater than 10 volts?
Yes
GO to J6 .
No
REPAIR circuit 1064 (YE/LB). TEST system for normal operation. J6 CHECK CIRCUIT 57 (BK) FOR AN OPEN
  • Measure the resistance between heated seat switch C320-4 (driver) or C321-4 (passenger), circuit 57 (BK), harness side and ground.
Yes
INSTALL a new heated seat switch. TEST the system for normal operation.
No
REPAIR circuit 57 (BK). TEST the system for normal operation It's not that simple , being a fuse . It's probably the relay or the heating element .
PINPOINT TEST K: SEAT DOES NOT HEAT BUT THE HEATED SEAT INDICATOR ILLUMINATES WHEN PRESSED ? Does it ?
Your best bet would be to take to a qualified repair shop .
Do
Honeywell troubleshooting
Emergency heat is the setting that shows that your heat strips are activated. Sometimes people do not wire up the heat strips at all as the use a great deal more power than the normal heat pump uses. The problem is that a heat pump comes to a point where it is not efficient at about 28 degrees and this is where you need the heat strips or if you want to heat the house quickly which a heat pump will not do. Heat strips are located in the ductwork and act like a space heater. A H/A tech is probably needed to check this stuff out for you.
2answers
How to repair a drivers heated seat on a 2007 Ford 500
The following checks and repairs can help you:
1. In the fuse box within the bonnet - check fuse number 22, if burnt, replace it
2. Check fuse 19 in the fuse box inside the car located under the dashboard on the driverside
3. If these steps don't help, the problem may be with the wiring and connection between the module and the seat cushion - inspect it
4. Check if the signal return on the circuit is adequately functioning - if the module is being informed of an active seat
5. If there is a problem - repair or replace the circuit and/or wiring.
2003 kia sedona replaced rear heat pipes now no heat and over heating?
Something is blocking the way for the heat to reach the vents.
Reconnect the pipes
3helpful
2answers
Where is the bank 1 sensor 1 o2 sensor located in a 2006 hyundai sontata gls v6?
The bank has to do with which side of the engine. The 'Sensor 1' indicates that it is upstream of the catalytic converter.
Heated Oxygen Sensor Removal & Installation Heated Oxygen Sensor (Front) (2.4L) hyundai-04-24-5822.gif
Heated Oxygen Sensor (Bank 1/Sensor 1) (3.3L) kia-04-00-5213.gif
Heated Oxygen Sensor (Bank 1/Sensor 2) (3.3L) kia-04-00-5214.gif
Heated Oxygen Sensor (Bank 2/Sensor 1) (3.3L) kia-04-00-5215.gif
Heated Oxygen Sensor (Bank 2/Sensor 2) (3.3L) hyundai-04-33-5855.gif
Heated leather seats will not heat up. Switch lights up and all fuses are okay. Is there a hiddedn relay I am not finding? Is there a quick way to determine if the problem is in the heating element under...
are you saying neither the heated seat cushion nor heated seated back on either seat works? But the light or lights does work?
Please rate as solved if this helps you. It took some time to dig all this stuff up. Please report progress.
Here's some info to start you off:
  • The heated seat is inoperative — seat does not heat but the heated seat switch illuminates when pressed
  • Circuitry.
  • Heated seat module.
  • Seat heater and temperature sensor.
  • Seat back heater.
  • Heated seat switch.
3helpful
2002 Grand Cherokee Heated Seats don't work
I will post it in 2 different posts because its too long DB
HEATED SEAT SYSTEM
Individually controlled driver and passenger side electrically heated front seats are available factoryinstalled optional equipment on this model, when it is also equipped with the power seat option. The heated seat system allows both the driver and the front seat passenger the option to select one of two seat heating ranges, Low or High, or to turn the individual seat heaters OFF using the heated seat switches located in the center lower bezel near the bottom of the instrument panel center stack. The heated seat switch circuit operates on ignition switched battery current supplied through a fuse in the junction block, only when the ignition switch is in the ON position.
The heated seat system consists of the following components
  • Heated seat elements
  • Heated seat sensors
  • Heated seat module (or memory heated seat module)
  • Heated seat switches.
The heated seat system also relies upon resources shared with other electronic modules in the vehicle over the Programmable Communications Interface (PCI) data bus network. The PCI data bus network allows the sharing of sensor information. This helps to reduce wire harness complexity, internal controller hardware, and component sensor current loads. At the same time, this system provides increased reliability enhanced diagnostics, and allows the addition of many new feature capabilities. For diagnosis of these electronic modules or of the PCI data bus network, the use of a DRB scan tool and the proper Diagnostic Procedures are recommended.
The electronic modules that may affect heated seat system operation are as follows:
  • Body Control Module (BCM) - Refer to Body Control Module in Electronic Control Modules for more information.
  • Heated Seat Module (HSM) - Refer to Heated Seat Module in Electronic Control Modules for more information.
  • Memory Heated Seat Module (MHSM) - If the vehicle is equipped with the Memory System, refer to Memory Seat Module in Electronic Control Modules for more information.
Refer to Power Seats Premium I/III in the Contents of Wiring Diagrams for complete circuit diagrams. Following are general descriptions of the major components in the heated seat system.
The heated seat system will only operate when the ignition switch is in the ON position, and the surface temperature at the front seat heating element sensors is below the designed temperature set points of the system. The heated seat system will not operate in ambient temperatures greater than about 41 °C (105 °F) . The front seat heating elements and sensors are hard wired to the Heated Seat Module (HSM) or the Memory Heated Seat Module (MHSM).
The heated seat switches are hard wired to the Body Control Module (BCM). The BCM monitors the heated seat switch inputs, then sends heated seat switch status messages to the HSM or MHSM over the Programmable Communications Interface (PCI) data bus. The HSM or MHSM contains the control logic for the heated seat system. The HSM or MHSM responds to the heated seat switch status messages, ignition switch status messages, and the front seat heating element sensor inputs by controlling the output to the front seat heating elements through integral solid-state relays.
When a seat heater is turned ON, the sensor located on the seat cushion electric heater element provides the HSM or MHSM with an input indicating the surface temperature of the seat cushion. If the surface temperature input is below the temperature set point for the selected Low or High heated seat switch position, the HSM or MHSM energizes the integral solid-state relay, which supplies battery current to the heating elements in the seat cushion and back. When the sensor input indicates the correct temperature set point has been achieved, the HSM or MHSM de-energizes the solid-state relay. The HSM or MHSM will continue to cycle the solid-state relay as needed to maintain the temperature set point.
The HSM or MHSM and the seat heater elements operate on non-switched battery current supplied through the power seat circuit breaker in the junction block. However, the HSM or MHSM will automatically turn OFF the heating elements if it detects an open or short in the sensor circuit, a short or open in the heating element circuit causing an excessive current draw, or when the ignition switch is turned to the OFF position.
See the owner's manual in the vehicle glove box for more information on the features, use and operation of the heated seat system.
I WILL POST THE REST
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
