Question about Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television
Bought new lamp and housing and tv lamp wont fire up. keeps turning on and off. fan is good 65hm167 dlp
  • 3 more comments
  • keithheld May 21, 2011
    cover is fine what else could be wrong is there another ballast
    65hm167 dlp new lamp and housing fan works switch cover fine tv turns on and off resetting itself but does not fire the lamp
    dont know where ballast supply is
    yellow light blinks (bulb) solid blue light on
    evrything is fine with door just keeps restarting
  • Toshiba Master
  • 2,098 Answers
May I know the status of the led light at the front panel. Please let me know what led light lit and if blinking.
Jdvillanueva
Posted on May 21, 2011
  • Jdvillanueva
    Jdvillanueva May 21, 2011
    Thanks for the response, that's led light status indicated of "waiting to re-light the lamp".
    It seems that the problem is still in the lamp. You must double check the lamp connection. Ensure that the lamp is securely connected to the ballast board connectors and properly seat-in to the lamp housing. Ensure also that the screws are installed securely or otherwise the symptoms will remain. Reattach the lamp unit door, making sure to insert the hooks on the left side of the door inside the opening in the TV cabinet. Make sure that the lamp unit door is installed securely.
    Please double checked the above mentioned, re-installed the lamp if necessary.
    Hope I helped you.
    Have a nice day!
    Thanks for using Fixya.
  • Jdvillanueva
    blue solid led light, yellow blinking lamp light indicated that the lamp didn't initialize and re-start the process. If you've confirmed that the lamp is securely seat-in and checked the surroundings, another caused of this symptoms is the faulty ballast board and its power supply. Checked if you can hear the ballast board trying to ignite or not upon powering on the unit and cycling from on and off.
  • 10,594 Answers
Hi, Please make sure lamp cover has been placed back in properly because it has to engage a safety micro switch inside that prevent tv to turn On.
Lamp cover is first thing that was removed to access / replace lamp in dlp tv.
If that does not help then ballast supply could be another reason of no lamp fire up problem and swapping ballast supply in/ from similar working tv will confirm it.
Hope this will help.
Thanks.
Posted on May 20, 2011
  • Shahid Electronics
    Shahid Electronics May 21, 2011
    Did you replaced/ swapped ballast supply in tv?
My power blinked and now my tv wont come back on,the yellow light just blinks and it wont do anything else???
not the lamp and lamp door is closed--double check lamp to make sure it is not shattered inside and is correctly inserted.
Other than that the possible reasons are Bad ballast that fires lamp, power supply board problems in the set or even a bad optical light engine or fan or fans not running.
Mar 19, 2012 | Toshiba 65HM167 65" Projection Television
I have a 42 inch toshiba 720 dlp hdtv, and it wont turn on. i press power to turn it on, it tries to fire up, the lights under power and lamp start blinkin green, and then orange, but then just stops and...
Tv "LAMP" LED light indication is blinking or lite up?The tv projection lamp insisde this tv now like 1 1/2 or 2 years already?Tv on and used daily like 4 or 5 hours everydays?Yes.The tv projection lamp life are over.The tv require a new tv projection lamp.Still have problems after this the tv board that call the Ballast board it is dead too,must require changing too.The Ballast board only job are to help to fire up the tv projection lamp and keep it lit.
May 01, 2011 | Toshiba 46H84 46" Rear Projection...
My viore 50" dlp tv keeps turning off every few minutes
Ck Fan that cools Lamp if it stops running then it is defective But it could be you just need to Replace Lamp Call Mats 1-800-628-1118 and Look up online Encompass Parts for your TV,this is there # 1-800-638-3328 Also look on E-Bay found Lamp for my DLP for 85.00 thier.
Nov 18, 2009 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
I have a toshiba 65hm167 no red color on the screen
Your TV is a DLP one lamp does it all, not like the old projection TVs with the Red, Green & Blue CRTs. Your TV may have a bad light engine or lose cable connections.
Good luck
N Sabre
Nov 08, 2009 | Toshiba 65HM167 65" Projection Television
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-R6768W started making squeal noise from rear of TV. At same time lost picture and will not come back on. Sound is ok and you can hear light trying to turn on. Can fan motor not working correctly...
Look at the fan and verify its comming from the fan and not the power supply unit, you can clean the fan or replace it, but yes the fan would be likly the problem. Make sure you double check the power supply unit and clean if its needed,
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 29, 2009 | Samsung DLP HL-P5663W 56" TV
Toshiba 52HM84 DLP TV with new bulb but the lights keep blinking
They exact way the lights blink are telling you what the failure is. If the tv is firing the lamp and the lamp is bad, you will hear a buzz sound for about 1 second. The tv tries 8 times before it gives up and spits out the lamp error. Check the user manual for led diagnostics. If you put in a new lamp but still have issues, you've likely got a bad ballast (most common on this model) or colorwheel (less common). Both are part of the optical block (light engine) and I don't believe they're available as individual components from toshiba.
Nov 28, 2008 | Toshiba 52HM95 52" HDTV Projection...
Samsung DLP HLM-617W/XAA
with lamp out (door closed) the ballast should "strike" or give an arc sound, trying to fire the lamp. If it does not do that maybe the color wheel is not spinning up - has to do that first.........then the set will try to fire the lamp
Jul 18, 2008 | Samsung DLP HL-P5663W 56" TV
Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television Logo
69 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
