Question about Puma Air Tools & Compressors
Puma tue7580 two stage, the relief valve on the inter cooler pops just bebore max pressure is reached, i have changed the relief valve and the valve plate, no change. what's next
SOURCE: My EC12 builds up pressure, but then releases all but about 10 psi.
The non-return valve is sticking and it's an easy fix. First, for safety, unplug the electric power to the unit and release any pressure in the tanks. Then unscrew the cap of the non-return valve (between the compressor and the tanks). Inside you should find a tapered rubber plug which is probably sticking in the valve housing. Sand down the diameter of the large end of the plug, being careful not to damage the flat face at the narrow end (which is the sealing surface). For sanding try 400 or 600 grade wet-or-dry paper and sand until the plug just moves freely in the housing. Reassemble and the compressor should work. Incidentally it's an oil-type unit, and quite durable. Make sure it has enough oil.
Posted on Nov 14, 2008
Bruno2
This was a great find, been having this problem for a while, but your suggestion worked. Thanks so much.
twodogs2
Posted on Nov 22, 2008
SOURCE: The compressor relief valve keeps popping, compressor runs
What pressure is it popping off at? You might have to adjust the pressure switch to a lower setting.
Posted on Apr 01, 2009
comax
  • 154 Answers
SOURCE: keeps stalling out
It sounds like you will have to adjust the governor system to hold the throttle on the motor open more so it doesn't bog the motor down. There should be an adjustment screw at the carb to perform this.
Hope this helps
Posted on Apr 14, 2009
  • 54 Answers
SOURCE: I have a quincy 350 and the relief valve on the
It won't be rings. You may have solved the main issue with the valve replacement, but still have a weak safety valve, especially if it was popping a lot before your repair.. I'd try replacing the safety valve before going much further.
Posted on Nov 06, 2009
POP OFF VAVLE ON HEAD KEEPS POPPING UP
The over-pressure relief valve may be defective if the valve is opening before the desired tank pressure is reached. If not, then the shut-off pressure adjustment (if there is one) may be set wrong. You'll need to find out from the manufacturer exactly what static tank pressure the compressor is designed to provide and then determine if it is working correctly. If so, then the relief valve might be defective. DO NOT attempt to defeat the relief valve under any circumstances - it can result in compressor damage or a dangerous tank failure.
Oct 06, 2014 | Porter Cable 175 PSI 80 Gal. Oil-Lube...
I have a craftsman air compressor model # 921.16472S. When it got to cut off pressure the bleed valve started blowing. I changed the pressure switch and bleed valve then lowered the cut off pressure. When...
Either the pressure switch is not shutting off when reaching the desired pressure or the pop off is either the wrong one or it is bad. Some blow off at lower pressures for single stage air compressors while others blow off higher for 2 stage air compressors.
Feb 11, 2014 | Craftsman Air Tools & Compressors
AIR COMPRESSOR BUILDS PRESSURE IN OIL COMPARTMENT AND LOCKS UP COMPRESSOR MUIST RELEAVE ALL AIR BEBORE IT WILL START AGAIN
Have a look at the check valve (you will find it between the pressure switch and the tank) Make sure there is no pressure in the tank before you remove it!!! There should be a spring and and rubber or plastic valve in there. Clean it up, or if necessary, replace it. Otherwise, you may need to check the valves in the head, if the are not seating properly then you will get the air passing through. It is very irregular for the air to get passed the piston rings in the pump, but try those things and post on here to let me know how you get on
Thanks
Carl
Sep 24, 2012 | Air Tools & Compressors
My compressor is building to much pressure and blowing out the relief valve. what do I check
You didn't give the model of your compressor so, for an electric model: Check your gages while the tanks are filling. If the pressure gets to the rated high pressure level for your model and keeps going until the relief valve pops, the problem is with the pressure switch. It isn't turning the motor off when it's supposed to. If the relief valve pops before getting to the max pressure the tanks are supposed to be at then the spring in the valve is broken or weakened to where it pops too early. Replace the relief valve.
May 23, 2012 | Air Tools & Compressors
How do I adjust the cut-out pressure on my DeWalt D55140 compressor? The relief valve is activating at 140psi before the compressor cuts off.
I had the same problem. The relief valve loosened up after a couple years of use. Right around the center pin in the relief valve is a ring that has a slot in it that you can fit a small straight blade screwdriver into and tighten in a clockwise direction. This should tighten the spring on the relief valve and raise the pop-off pressure above the 150 psi setting of the cutout switch.
Apr 10, 2010 | Dewalt D55140 Heavy Duty 1 Gal, 135 Psi...
Champion compressor pops manifold relief on head
depends on what relief valve it is, if it is a 2 stage pump and it is the relief on the inner-stage that is lifting indicates the second stage is not pumping correctly! I would check for a broken valve. if it is the one on the discharge line to the tank, then something is restricting it, check for blockages in the line or in the check valve entering into the tank. Most important you isolate the compressor and drain all air pressure before you attempt any repairs
Dec 29, 2009 | Champion International Air Tools &...
I have a quincy 350 and the relief valve on the second stage keeps lifting. I have changed valves, unloader, gaskets, filters and cleaned the cooler. Could it be the rings?
Nov 05, 2009 | Air Tools & Compressors
Howdy, I just acquired an air compressor, ''Westinghouse Air Brake Co., Type Y 3YC, SN 136848. I am wondering about parts motor config, cfm output, psi, etc. It appears to be a 2 stage & I'm thinking...
We have a Westinghouse 3YC air compressor. The safety relief valve in the line between the two compressors started "popping off" recently. The compressor seems to be working fine. Is this a problem only with the relief valve or could there be a symptom of a more serious condition that we should be attending to? The valve is stamped 60 max which I assume is 60 psi. Is this the correct size. The tank pressure is set for125 psi. The tank relief valve is marked 250 max.
Sep 12, 2009 | Air Tools & Compressors
Compressor shuts off before reaching max pressure
Yes,but if the max is 125 you don't want to increase it above 110 and set off the pressure relief valve.
Jul 21, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Keeps stalling out
Hope this helps
Apr 06, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
24 people viewed this question
Top Puma Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Lawrence Oravetz
Are you a Puma Air Tool and Compressor Expert? Answer questions, earn points and help others
