Question about Car Audio & Video
CD plays between 25 seconds and a minute before volume stops. A few seconds later I get the Error 11 message. What causes this and can this be fixed by an amateur, if not how much does it cost to have it repaired?
  • 3,018 Answers
  • The majority of the time this is due to an internal fault. Check the wiring harness for cracks etc. Two things are your options here. One, up-plug the radio harness for a few minutes and plug it in and see if this works. You can also remove the battery cables for 30 minutes then touch the two cable ends together before reattaching the cables to the battery. Make sure you have the radio code BEFORE disconnecting anything or the radio won't work at all. If this does not work the you need to contact the manufacturer because the radio has gone bad.
Good luck, Regards, Tony
Posted on May 20, 2011
Oven keeps asking for probe
connect probe and insert probe
Jul 26, 2015 | Kitchen Ranges
Cannot playback video on laptop video keeps stopping
seems that a memory upgrade is in order
start button
control panel
system
what is current memory?
for video 2 gig is ok but 3 to 4 gig is better
May 24, 2012 | Sony Computers & Internet
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
When playing DVD, it's sometimes display 'PROTECT' and stop playing.
Check if you receive the error when playing any DVD in particular.
What happens when you take out the DVD and try playing it again? Does it play
This protector error denotes several possible problems. Heat, volume level and incorrect DVD settings may be the cause of the problem. The following steps will help you correct your problem and rid your amp of its "Protector" error.
  • Examine your volume setting to be certain that your volume knob is not at maximum. Having your volume cranked too high can cause the capacitors to overheat, shutting down the receiver.
  • Unplug your receiver and disconnect your speakers from the terminals on the back. This will allow you to determine if the error is internal. Plug your receiver back in and look for the same error message. If you continue to get the protector error without having your speakers connected, you may have an internal electrical problem. In this case, contact Sony about finding a repair center.
  • Reconnect your speakers one at a time. The order of connection doesn't matter. When reconnecting, be sure that you do not have your positive and negative speaker wires crossed in any way. After each connection, test your amp by running it with a source. Give each speaker a few minutes of power before connecting the next one. This will help you isolate which speaker terminal is causing the error. When the protector error returns, take note of which speaker connection caused it. Check this speaker wire for shorts or torn shielding.
  • Examine your ohm rating of your speakers if you have no shorts or wiring issues. Sony receivers are not compatible with speakers lower than 4 ohms. Connecting a lower ohm-rated speaker will cause an error.
  • Turn off the surround sound option if you have both your A and B position speakers in use.
  • Keep your receiver well ventilated. Overheating due to poor ventilation can also cause Protector errors.
  • Examine the sampling frequency of your connected DVD player. If the error only occurs when you watch a DVD, the sampling frequency of the DVD player may be set too high. Check the sampling rating in your receiver's manual and in the DVD player
Mar 22, 2011 | Sony DAV-S500 System
My Pioneer Auto CD Player has an Error 11 & 12 message, plays for a few minutes then the error message shows
the laser eye needs cleaning.....i actually just did mine today, just with a normal cleaning cd...if it doesnt work first time, smear a little nail polish remover on the cleaning disc, it works a treat........error 11 and 12 mean the laser cannot read disc properly......starts and stops depending on how much cleaning is required....
Sep 13, 2009 | Pioneer DEH-1600 CD Player
Error 11
Error 11 and or Error 17 is mean that CD is dirty or scratch, and the optic can not detect CD track.
Solved problem:
1. Clean the CD
2. Change open source by push knob going to "CD" display or push "search" from remote to "CD" display
3. If still come out Error 11, change the MP3 CD by Original CD with clean track CD.
4. For the last step, clean the optic sensor by CD cleaner for a few minute.
5. Check and try to play the CD again.
Apr 26, 2009 | Pioneer Car Audio & Video
Error 11 and 12
First try to clean the optical lens of the player. USe a cd disc cleaner for cleaning.
Hope tis initial info helps.
Nov 20, 2008 | Kenwood KDC-CPS89 10-Disc CD Changer
Masterlink "Disc Read Error"
try to reinstall the O.S. /firmware.
the firmware is avail on the alesis site
dave
Sep 11, 2008 | Alesis MasterLink ML-9600
Yamaha DVD S520
yes sir, starting to malfunction and needs replacement now. unless you cant ry cleaning it manually maybe it will help a little but sooner or later it will again give you same trouble
Aug 03, 2007 | Yamaha DVD-S520 DVD Player
Car Audio & Video Logo
41 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
