Question about Maytag PYE2300AY Electric Dryer
How do i replace the broken belt on maytag sde305dayw?
  • Maytag Master
  • 7,482 Answers
Hi nonstop68...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please take time to rate me
Posted on May 21, 2011
  • dewayne dabney
    dewayne dabney Feb 09, 2015
    Great information! Thanks......
How do I open my Maytag dryer model # SDE305DAYW Legacy series?
Unplug
use a scrapper/puddy knife just under top find clips and push in on clips at same time pulling up on the top
Sep 17, 2014 | Maytag Dryers
My maytag legacy dryer SDE305DAYW has a very loud squeeking noise when I start the dryer. After a minute or 2 it stops making the noise. Is this the belt?
While I would suspect the belt also, it could also be the drum bearing since they both could have the same symptoms. Suggest you try to turn the drum by hand and see if you can hear it then.
Aug 13, 2011 | Dryers
Need SDE305DAYW dryer belt routing diagram. Please help
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Scroll down and you'll find the maytage diagram. There are many, but it's about half way down.
Good luck, it might help to have a buddy help for an extra set of hands.
Mike
Aug 04, 2011 | Maytag PYE2300AY Electric Dryer
The push button to start my maytag dryer SDE305DAYW won't start dryer
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Mar 05, 2011 | Dryers
In my Maytag dryer model SDE305DAYW the heating element works; however, the tumble drum stopped moving. What's wrong?
This sounds like the drum's drive belt broke. But also ensure there isn't a problem with the drive motor. Do you still hear a motor running when you turn it on? If so, you'll need to replace the drive belt.
I hope this helps! :)
Dec 15, 2010 | Maytag HYE3657A Electric Dryer
Maytag dryer model SDE305DAYW drum will heat but not turn. Belt is not broken/
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 29, 2010 | Dryers
I need help replacing maytag dryer belt model no.sde305dayw . I am having a problem getting around the pulley maytag dryer
The Link below will show you the configuration for all dryers. Choose the one that looks most like yours keeping in mind that some dryers are made under several different names: Good Luck
Belt Configuration
Nov 12, 2009 | Maytag Dryers
I have a Maytag Legacy Dryer SDE305DAYW that is squeeking. How do I change the belt?
the belt is not causing the squeek. either the tub rollers, or the idler pully is squeeking. you must remove the front panels and drum to inspect these parts. usually when a roller or idler pully is squeeking, you need to replace them. if they arnt to worn, you can clean the shaft and grease them to stop the squeek, but i dont recomend that, as it will just be a temporary fix and will start squeeking again. this isnt a easy repair if you've never done it. let me know if you have any further questions. Shane
Jun 19, 2009 | Dryers
Maytag model sde305dayw
Check your fuses or breaker...If you have fuses, replace both 30 amp fuses. If you have breakers, flip breaker to OFF then back to ON, then try your dryer to see if it heats.
Mar 20, 2008 | Maytag HYE3657A Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
853 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
