I have a WAVETEK OTDR model type MTS 5200e that never continue to power up when I press the power on/off switch. When I also connect the external charger, the unit is not charging. The battery is good and the external charger is good also. When I press the SETUP button the screen lights up with remarks ( starting file transfer to RAM.) but after that it leads also to ( Centronics error and the unit will reset in a few seconds.)
  • 55 Answers
SOURCE: Non-Responsive PDA
You may have to do a hard reset. You hold one finger at the power and the other hand hold your stylus and his reset. This technique is applied to most PDA.
Posted on Aug 25, 2007
myob247
  • 1342 Answers
SOURCE: Compaq V5201US Notebook Will Not Start/Boot UP
Remove the power adapter and the battery. Hold the power button in for up to 60 seconds to discharge the laptop. Re-apply power and try booting the laptop.
Posted on Jul 20, 2008
SOURCE: Docking Station Will not start
I just got off the phone with the Altec Lansing technical support line and after running some test found my station is defective so I am suppose to ship it back to the company and they are sending me a replacement...I suggest calling the tech line the number can be found on the altec lansing website! Good luck!
Posted on Apr 20, 2009
SOURCE: Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Posted on Aug 06, 2009
  • 186 Answers
SOURCE: Hi my hp compaq nx9010
It sounds like you have a bad motherboard.
Posted on Mar 08, 2011
On my e-motion tv when I switch it on and go onto did it says no signal....help please
Why does my TV say no signal? If your HDTV or Standard TV displays a "No Signal" error message, it may be due to one of the following issues:
  1. Determine how many TV's are affected.
    • If it is one TV, continue to step two.
    • If multiple or all TV's are affected, continue to step five.
  2. Ensure that your HDTV is on the same source/input as your MTS Ultimate TV service.
    1. Press the TV button on your MTS Ultimate TV remote control.
    2. Press the TV/Video button.
    3. Wait 10 seconds.
    4. Repeat steps b and c continually to cycle through all the available source/inputs on your TV until the correct source/input is selected. (ie. HDMI 1, HDMI 2, Component 1, Component 2, etc.) On standard TV's (non HDTV), you may have only 2 choices, TV or Video.
  3. If the source is correct from step two:
    1. Unplug the HDMI cable from your MTS Ultimate TV Set-top Box.
    2. Wait 30 seconds.
    3. Plug the HDMI cable back in.
    4. Wait for the signal to initialize.
    5. Make sure all cables connected on the set-top box and your TV are secure.
  4. If the problem persists:
    1. Unplug the power cable from the back of the MTS set-top box.
    2. Wait 60 seconds.
    3. Plug the MTS set-top box back in.
  5. If you are still experiencing a problem:
    1. Make sure ALL Ethernet and/or Coax cables are securely in place.
    2. Unplug the power from the MTS box labeled 2Wire or Pace as well as the affected set-top boxes.
    3. Wait 60 seconds.
    4. Plug the power back into the MTS box labeled 2Wire or Pace.
    5. Wait for the broadband light to turn a solid green colour.
    6. Plug the power back into the affected set-top boxes.
    7. Wait for the signal to initialize.
Good Luck
Feb 24, 2015 | Televison & Video
Wavetek dm27xt have a multimeter that when I try to measure some element, the digital display does not show the actual value of the measurement, only shows the initial value of the measurement range in...
Can you watch .mp4 or .avi files? The Youtube video is over 10mb in size, so it can not be sent (gmail has a 10mb size limit on attachments). I have to cut it into several smaller pieces and can convert to another file type (the original is an mp4).
Mar 03, 2014 | Wavetek Computers & Internet
Operator's manual/ owner's manual for wavetek fg2a needed
I couldn't find your exact model for free, but I did find the manual for the Wavetek FG2C. Perhaps they are similar? You can find it here: http://www.tequipment.net/assets/1/26/Documents/FG2C_FG3C_Manual.pdf
If not, you should be able to purchase the manual here: http://www.manualsdrive.com/results.php?lang=en&search=WAVETEK%20FG2A. I've never used that particular site, but the FG2A manual, installation guide, etc are listed.
Best of Luck!
Nov 07, 2013 | Wavetek Computers & Internet
Acer connect projector
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods.
1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor.
2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times.
Here is a list of key combinations for some of the laptops :-
IBM ThinkPad = Fn + F7
HP and Compaq = Fn + F4
Toshiba = Fn + F5
ASUS and Dell = Fn + F8
May 07, 2013 | IBM ThinkPad Computers & Internet
Problem with external monitor activating with DV6 1360-us
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 20, 2012 | HP Pavilion Computers & Internet
Connecting laptop to projector
You can switch to anexternal monitor or data projector by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCD screenplus the external monitor or back to LCD screen only by pressing the Fn keyplus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
Jun 05, 2012 | HP Pavilion dv6200 Notebook
Unable to connect projector
May 20, 2012 | IBM Lenovo ThinkPad T510 Notebook
Hitachi 28LD 5200E TV will not switch on. It has a toggle switch underneath and a tiny push button on the front. Is there a special sequence, or a time delay or something. It worked earlier on today. I...
Fixed by leaving switched off at the wall and at the toggle switch for more than half an hour. Then switched on at wall first, then toggle. All OK!
Dec 18, 2009 | Haier Televison & Video
Need a manual for a Wavetek DMM, digital multimeter model DM15XL
Here it is:
http://www.tequipment.net/pdf/Wavetek/5XL10XL15XL16XL_Manual_Rev_A.pdf
Nov 15, 2009 | Measuring Tools & Sensors
Acterna otdr printouts?
look, depending on the version of the acterna otdr you have, find under the system setup, a parameter called printer, set it to the model of your printer, please refer back to me with the model (i.e 5100e, mts 6000) for more details..
Sep 22, 2009 | Fluke Networks OptiFiber Certifying OTDR...
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
