Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Seagate freeagent 500g usb 2.0 beeps sound
I had this hard disk for few month. its works fine. but last few day it give out low beep sound and try on a few pc also can not detect it. its still under warranty. but there is important data that i need. how to open up the case without breaking it? same prob seagate wants 1700$ to recover the data!!! any tips?
  • 1,800 Answers
Try to re-install the driver then plug it if that comes with no result u just try what the mate said google data recovery cuz i ve seen one of those hard disks its impossible to open the case without breaking it!!! they have the advantage to tell u that price but try google data recovery that is the best solution we recommand
best regards!!
Posted on Aug 15, 2008
    Master:
  • 521 Answers
Its impossible to open up the case it will definately break. and the warranty will be void. then they will charge you more and no garranty for the product.hence if it is still under warranty,. you can tell them about this hard disk failure.may they help you.as tthanks.
    Scholar:
  • 93 Answers
To resolve this problem, delete the UpperFilters registry value and the LowerFilters registry value. These values may cause access problems. To do this, follow these steps:
1. Click Start, click Run, type regedit , and then click OK.
2. Locate and then click the UpperFilters registry value. This value is located in the following registry subkey:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlClass{4D36E980-E325-11CE-BFC1-08002BE10318}
3. On the Edit menu, click Delete, and then click OK.
Note If you receive an error when you try to delete the registry subkey, you may not have correct permissions to edit the subkey.
4. Locate and then click the LowerFilters registry value. This value is located in the following registry subkey:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlClass{4D36E967-E325-11CE-BFC1-08002BE10318}
5. On the Edit menu, click Delete, and then click OK.
6. Exit Registry Editor.
7. Restart the computer In Safe Mode With Networking
Then Smitfraudfix that shoud be run in Safe mode with networking only
8. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
9. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
10. When the Boot menu appears again, and the words "Safe Mode with Networking " appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Download SmitFraudFix Click Here and click on RUN and the on the next Screen once again click RUN Once Again
  • Search:
    • Double-click SmitfraudFix.exe
    • Select 1 and hit Enter to create a report of the infected files. The report can be found at the root of the system drive, usually at C: apport.txt
  • Clean:
    • Reboot your computer in Safe Mode (before the Windows icon appears, tap the F8 key continually)
    • Select 2 and hit Enter to delete infect files.
    • You will be prompted: Do you want to clean the registry ? answer Y (yes) and hit Enter in order to remove the Desktop background and clean registry keys associated with the infection.
    • The tool will now check if wininet.dll is infected. You may be prompted to replace the infected file (if found): Replace infected file ? answer Y (yes) and hit Enter to restore a clean file.
    • A reboot may be needed to finish the cleaning process. The report can be found at the root of the system drive, usually at C: apport.txt
  • Optional:
    • To restore Trusted and Restricted site zone, select 3 and hit Enter.
    • You will be prompted: Restore Trusted Zone ? answer Y (yes) and hit Enter to delete trusted zone.
  • Posted on Aug 15, 2008
    • 6,487 Answers
    Because if the hard drive is not detected there's no way you can retrieve the data on it, try first to put this hard disk to a different computer and hopefully it will be detected then you can now get the data, but if still no needs replacement already...
    Hope that helps.........
    • 37 Answers
    If you open the case, then you will void the warranty.
    If you do open it, you need to be careful while you pry the case off. I believe it has tabs, that need to be seperated.
    Once you have the hard drive out, use something like this: http://www.geeks.com/details.asp?invtid=2020 That will let you get the data off if it's still there and intact. Or you could install it in your computer, and access it that way.
    • 928 Answers
    You can contact some companies that will do it for much much less such as the link below. I would not advise that you attempt to recover it yourself as you may lose the data. You can also search in google under data recover to see other companies that have a more reasonable fee
    Link
      Genius:
    • 2,028 Answers
    The thing is, that they do not want you to open the unit, so they make them to where it's near impossible to open without breaking it. Unless you've done it before, and know what you're doing, I wouldn't recommend it. There are many places that do data recovery for a lot less than what Seagate wants. They are still expensive, but considerably less than $1700. Google data recovery, and get some estimates.
    Seagate goflex 500gb not detected giving 3 beeps
    I would say if it was spinning when it dropped, you are probably out of luck. There are services available for platter recovery, but they are quite expensive. Practice the 3 backup policy.
    Feb 09, 2014 | Seagate FreeAgent GoFlex 500 GB USB 3.0...
    See if Testdisk sees the drive and if so try restore or create a boot sector
    Nov 21, 2017 | Seagate FreeAgent GoFlex 500 GB USB 3.0...
    My drive was working fine the next day i pluged it in and it just wasent appearing on my desktop is was just making a beep beep beep noise :( please help
    the beeping sound is the post system searching for your hard drive and other connected devices
    try replacing all the leads that attach to your hard drive
    good luck
    Sep 16, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
    I just bought that disk (seagate SATA 500G) half year ago and found it stop working randomly, resulting the whole system to be dead. BTW, I am using Win XP. I tried to use seatool, provied by seagate, to...
    It sounds like you're not concerned about the data on the drive, just the drive itself.
    If that is the case, the drive will still be under warranty. Most seagate drives have a 3-5 year warranty.
    Take the drive back to where you purchased it and they can get it replaced for you. Alternatively you can send it to seagate direct, however there may be a minor courier fee.
    http://www.seagate.com/www/en-us/support/warranty_&_returns_assistance
    Apr 04, 2010 | Seagate FreeAgent Go 500 GB USB Hard Drive
    Low beep sound and try on a pc also can not detect it
    Unfortunately, they are designed to void the warranty if opened. But since you mentioned trying different PC's, how about different USB cables, or perhaps a duplicate power supply, perhaps one of these items is the issue. There may be a software issue, in that instance if you can find an imaging program, like Acronis, or Macrium, they may detect the drive and **** the info off of it, in order to get any different results that windows the imaging programs will need to run off of "bootable media"
    Apr 03, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
    I own a 320GB seagate freeagent hard disk and accidentally unplugged it from my laptop a few days back. It gives a beeping sound whenever I try plugging it into a laptop and I've tried 3 laptops, all gave...
    Connect the 320GB HDD before switching ON the laptop and try to repair using scandisk option to repair the drive. Also use chkdsk /f option in command line mode.
    Revert back for more assistance.
    Jan 20, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
    You still need assistance in cracking open the Seagate Freeagent Pro 500GB and trying data/file recovery? If yes, would appreciate a post back.
    Good luck and kind regards.
    Thank you for using FixYa.
    Mar 17, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
    I am so happy to say that i HAD the exact same problem.
    Its an issue with the drive disk itself. Long story short because i dropped the drive the the disk was no longer able to spin fast enough to start the drive (the beeping sound actually being the disk trying to start spinning.
    After spending literally the last 4-5 hours looking for a solution I found a unusual method that basically either works, or it doesn't there's no it kind of works. what you need to do is unplug the drive, then plug it back in and start Vigorously spinning it whilst keeping the drive horizontal (similar to what you would do when your unscrewing a light bulb).
    You have to try and do so simultaneously with the beep and it should "kick start" the drive (AND OBVIOUSLY DON'T LET THE WIRE DROP OUT AS YOUR SPINNING IT AS YOUR COMPUTER WONT RECOGNISE IT IF ITS NOT PLUGGED IN).
    I Know this method sounds far fetched but put it this way, 15mins ago I was working out how im gonna get hundreds of pounds to restore this drive, Now, i've just finished copying my informations onto a laptop from the drive so i can take this piece of plastic **** back to the shop :D.......
    Never again Seagate and Thank God for letting me find a solution.
    Feb 11, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
    Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
    261 people viewed this question
    Top Seagate Computers & Internet Experts
    Arora Singh
    Arora Singh
    Alun Cox
    Computer Links
    Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
