Question about Frigidaire Side by Side Refrigerator 26 Cu. Ft. FRS6R4E
Frigidaire not cooling off
I have had the frigidaire FRS6LR5EM2 for about 2 years now and yesterday it just started heating up and will not cool at all. I took the back panel off to clean the condensor coils off but they weren't really dirty..... The compresor was mildly hot....I unplugged it for a little while and then plugged it back in and the line from the compressor got really cold for about 20 seconds, then warmed up again.... any ideas?
  • snowflakes3 Sep 22, 2008
    I was hit by hurricane Ike and had the refrigerator hooked up to a generator. It didnt seem to cool off properly using the generator, but now that power is back on, neither the refrig. and freezer is cooling off properly. Any ideas?
    Guru:
  • 93 Answers
Hello, You are more than likely having a freon issue.  The problem sounds like a filter drier restriction.  This could be a simple fix.   It will require some indepth time.
www.applianceoutletservice.com Bill
Posted on Nov 05, 2008
  • Bill Newberry
    Bill Newberry Nov 08, 2008
    Read this article on defrost issues and see if it applies to your machine.  It will give some helpful tips.  Any other questions after that feel free to ask.
    No Cool Refrigerator
    Bill
How do I replace the heating elembent in a frigidaire FRAM18ER2A ac/heating UNIT
This type of unit does not normally have a heating element, it is a heat pump. In summer if blows cold air through the front and hot air out of the vent at the back. In winter, cool air is drawn in through the back, heated by the compressor and vented out of the front vents.
The manual is here. It seems Frigidaire Service is the only answer.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020219A0576en.pdf
Wiring diagram is here. The unmarked item, 2/3rds down on the left may be an element.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/202021990031.pdf
This intimates it has a 4000 watt to 4900 watt element depending on voltage supply.
Voltage Rating: 240V / 208V 60Hz
Amps (Cool): 8.4 / 9.2
Watts (Cool): 1900 / 1880
Amps (Heat): 22.2 / 20.0
Watts (Heat): 4900 / 4000
Horsepower (Cool): 2.49
Power Cord Length: 5' (6')
Plug Type: 6-30P
Despite my best searches I can't find anyone selling gthe element. Try these two companies though
Frigidaire Refrigerator Heating Element Parts: Fast Shipping
https://www.repairclinic.com/Shop-For.../Frigidaire-Refrigerator-Heating-Element-Par...
Looking for parts for your Frigidaire Refrigerator? ... Frigidaire Refrigerator Garage Heater Kit. ... Frigidaire Refrigerator Defrost Heater Assembly.
Missing: fam18er2a
Frigidaire 137488301 Heating Element (10 - AppliancePartsPros.com
www.appliancepartspros.com › Frigidaire › Washer › Frigidaire Washer Parts
US$65.40
HEATING ELEMENT (10 137488301 / AP5618485 made by Frigidaire.
Missing: fam18er2a
Nov 16, 2017 | Frigidaire Heating & Cooling
Frigidaire window air conditioner LRA157MT1 worked yesterday. Today fan works but it doesn't cool?
unplug it if you can and let it set for 20 minutes, set the temp control where you want it and plug it in, wait a bit and see if it starts cooling. you can confuse these things if you turn it off and on rapidly or change the temp control up and down sporadically. The compressor has to take it's time to kick on after it has been shut off and then on again.
Jun 11, 2017 | Frigidaire Heating & Cooling
Frigidaire Air conditioner: fas296n2a2 Compressor
Do you have an amp meter? and volt meter. Are you sure that the compressor is getting power? The click may simply be a relay closing but no power. Check both sided of the relay. You will need to trace the power and make sure that the compressor is getting power. Then check the amps to see how much power it's pulling.
Jun 15, 2010 | Heating & Cooling
Bought a Frigidaire FTD080600948 Central Ac & heat pump 13 months ago. Compressor fan outside quit working yesterday. Compressor runs but can not cool because the fan won't cool the coils. anything...
yes there is a silver cylinder lookin object thats called a compasitor which goes to the fan motor change that out to see if thats the problem if not your fan motor is the problem
Jun 04, 2010 | Heating & Cooling
Frigidaire FRS26R4AW5 buzzing sound not cooling
Something has stopped your compressor. The part could be the start relay, start capacitor, overload or the defrost control board. where are the buzzing sounds coming from ? Sea Breeze
Dec 20, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire not cooling & freezing cold enough
We ahve a two year old Frrigidaire Freezer. every year same time it seems to correct itself(?), like self defrosting etc, and takes a long time come back to its cooling level. This is made in brazil G series. Please help.
V/r Syed
Dec 23, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Jun 30, 2008 | Frigidaire FAH08EJ1 Air Conditioner
Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Jun 10, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Open Questions:
Frigidaire Side by Side Refrigerator 26 Cu. Ft. FRS6R4E Logo
357 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
