Question about Sebo Automatic X1 Bagged Upright Vacuum
Trying to replace the belts, cannot get the large belt on
  • 710 Answers
Hi Danny,
Copy and paste this address from our website: >>>> http://www.fixya.com/support/t2681489-sebo_automatic_x1_cleaner_toothed_belt
One of our experts gives a full description of how to change belts and what to be careful of when you do.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on May 20, 2011
I need to replace the belt. Have the belt and the vacuum bottom off. What do I attach the belt too?
This unit has 2 belts. The V-belt on the brush usually doesn't cause problems. The larger flat belt requires regular replacement ( belt # 38528-035 ). The belt is first placed around the motor shaft toward the rear of the machine, and then around the large pulley. You must have strong fingers to stretch the belt over the drive pulley. Start the belt at the top of the pulley, and try to "roll " it around the pulley a little at a time, holding the belt firmly around the pulley as you go.
Feb 21, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
How to change a belt on a Hoover wind tunnel
It depends largely on the model. Do you know the model number? you can get any hoover replacement belt here:
Replacement Hoover Vacuum Belts
Dec 09, 2009 | Vacuums
Ihave a Hoover Windtunnel self-propel model U6445-920. The belt from the drive motor to the big wheel will not run in the center of the wheel. The belt runs about 1/3 off the wheel. I have tried several...
The large wheel may be worn off center. If the belt stays on and is not thrown, you can run the vac. if there is wobble in the wheel causing a genuine belt to slide off replace the wheel mechanism.
Sep 07, 2009 | Vacuums
My vacuum belt came off and I do not know how to replace it, it is a #7
Here is link for the users guide for your model. On the right side of page you'll see the "Download Manual" link. Scroll down until you find the belt replacement section. There are instructions for both small and large belt replacement. If you scroll down further, you will see the toll free number to order your belt.
Hope this helps.
http://www.azmanual.com/manual/16363/bissell-proheat-2x-deep-cleaner-manual/
Aug 31, 2009 | Bissell 9200 Upright Vacuum
Replace the belt
Once the bottom plate has been removed, the motor shaft is silver, but hard to see. hook the new belt on it first. then start rolling on the top of the large black pulley to install.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 26, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
Installing belt
here are the step by step instructions from the owners manual for your machine.
Disconnect cleaner from electrical outlet. WARNING: Agitator brush roll can start suddenly. Unplug cleaner before turning it over. Replacing Flat Belt Place handle in low position and turn cleaner over so bottom side is facing up. Remove the 6 screws as shown with a Phillips screwdriver. Lift off bottom plate. Replace belt if it is stretched, cut or broken. To check the flat belt. Removing Bottom Plate Removing Belt Positioning Belt Remove used belt from large pulley and discard. Reposition bottom plate and 6 Phillips head screws. Tighten screws securely. Insert agitator brush roll through belt and position belt in groove (A) on agitator brush roll. Inspecting V-Belt The V-belt is designed to last for a long time and is not normally replaced. However, if the V-belt is cracked, gouged or broken, it should be replaced. Slide flat belt off large pulley. To remove V-belt, slide back of belt over pulley (A). Then firmly pull on belt and “snap” it out. Discard used belt. To install new belt (with lettering on outside of belt), slide back of belt over pulley and pull front of belt toward groove next to pulley. Belt will “pop” into place. Flat Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for Flat belt - HOOVER part No. 40201-271. V-Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for V belt - HOOVER part No. 40201-200.
If you can't get the answer from this post, send me a message and I will try to walk you through this. I hope it helps.
Jan 19, 2009 | Hoover Windtunnel Supreme U5280-900...
Brushes won't turn
Sounds like you have broken belt. I had the same thing happen, Got replacement belts, but can't figure out how to get the smaller belt back on. There two larger belts - one on each end of the brushes under the clear plastic covers. On the left side there a single silver metal gear, but nothing to hook up the other end of the small belt to drive the brushes. If you take yours apart let me know how to hook up the smaller belt.
Thanks,
David Wood
Aug 13, 2008 | Bissell 9200 Upright Vacuum
Flat belt to hard to stretch
The belt number is 38528035 and it will stretch far enough to go over the bigger pulley.
May 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Sebo Automatic X1 Bagged Upright Vacuum Logo
60 people viewed this question
Top Sebo Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
