How do i turn on my wireless internet - Computers & Internet
  • JDTec
    JDTec May 20, 2011
    what model of computer?
  • 27,725 Answers
You might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver you might see a yellow question mark? This means you need to update the driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Posted on May 20, 2011
Conection on internet with wifi alweys turn off when i want to go on internet how to fix that
Replace wireless card if you do diagnostic on card and it fails in device management.
Nov 11, 2013 | Computers & Internet
Wireless internet turned off
Go to networks on your computer and see what is there and in range if yours is there click connect. Or you may have hit the wireless button on your keyboard by accident , Failing this I would phone your internet supplier
Mar 02, 2013 | Computers & Internet
Internet on-off key: how to use it ? May it be
hi, rmoriconi
pay no attention to people that tells you that that switch turns your wireless on and off..you do not have a wireless modem
all it does is block your incoming and outgoing internet service, its a security feature and thats it
(your modem is not wireless, if it is, its the first wireless modem i have ever seen)...
bill
Jun 23, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Cannot setup my linksys wrh54g wireless router
Hi Friend,
In order to resolve the issue, please follow the steps:
If you have a cable internet connection:
1.Connect the wire (which is coming out from the modem, i.e, the internet wire)
into the WAN/Internet port of the router.
2.Connect your computer to any of the four LAN ports with a Ethernet cable(usually Blue/Yellow/Grey color wire)
3.Turn on the router
4.At the back of the Router there is a Red/Black button (Reset Button)
5.Push and Hold that button for 30 seconds.
6.Release the button and turn off the router for 30 seonds and turn it on again.
7.Type 192.168.1.1 in the address bar of the Internet Explorer and hit Enter
8.Enter the username and password (default password is admin and leave the username blank)
9.on the Setup page, make sure the Internet Connection Type is set to "Automatic Configuration-DHCP" and click Save settings.
10.Now click Wireless tab and fill the sections as mentioned:
Wireless Network Mode:Mixed
Wireless Network Name:As per your choice
Wireless Channel-6-2.437GHz
Wireless RF Control-Standard
Wireless SSID-Enabled
Wireless RF-Disable and click Save Settings
11.Now Click Wireless Security and fill the sections as mentioned(if you want to make your network password protected)
Security Mode-WEP
Default Key-1
WEP Encrypion-64 bits 10hex digits
Key1-Enter 10 digit password(e.g-your 10 digit telephone number) and click Save Settings
If you have DSL internet connection, then all you need is to change the Step-9 and all the settings will remain same.
Step-9 (for DSL internet connection)
Internet Connection type should be selected to PPPoE and enter the Username and Password provided by your Internet Service provider. Then click Save Settings.
After completing all the above steps, turn off the Router for 30 seconds and turn it on after that. You can connect your wireless devices.
I hope this will resolve the issue.
Regards
Chiranjeet
Jun 02, 2010 | Linksys WRH54G Wireless Router
Can't connect to wireless internet anymore device
Please install the latest wireless adapter card driver and then configure it to your wireless router.
Dec 26, 2009 | Compaq Network adapter
Wireless capability turned off
What you are seeing is the offline web page view. It is not actual internet unless you can search through different sites. There should be a light just below your screen what will allow you to turn wireless on or off. Or search your computer files for wireless assistant aka WLAN
Oct 01, 2009 | Acer Aspire 4720 Notebook
Set up 2 wireless routers, 1st for printer, 2nd for internet
You should only need one wireless router for everything. The purpose of the router is to "route" multiple devices together. Your set-up should be something like this:
Modem connected to wireless router via Ethernet cable.
Wireless router broadcasting wireless internet connection.
Computer(s) connected to wireless router via cable or wireless adapter.
Computer with network printer sharing enabled.
Turn on wireless printer.
You should be able to detect the printer via Windows.
Sep 05, 2008 | Office Equipment & Supplies
Computers & Internet Logo
David Payne
David Payne
