My speaker system gives out terrible echo distortion cannot find problem through normal channels can you help?
    Genius:
  • 1,479 Answers
My guess is that you have realtek sound on your pc. open the realtek icon from the tray by the clock if you have one, if not you need to go through the control panel. you'll probably find the equaliser is set on hall or something, play with the settings until you find the one you like.
Posted on May 20, 2011
Serious echo on in the speakers
Go to your local apple store, there are several types of cables and the wrong one will not work. Check if you have a reverb unit in the system that would give that effect. It cold be picking up a speaker but normally that causes feedback with a howling sound.
Mar 01, 2014 | Samson MDR8 8 Channel Mixer
Bose acoustimass 3 left channel fuzzy
Being Bose, the service department will require the unit back for service.
Jun 14, 2017 | Bose Audio Players & Recorders
The speakers sound like an echo and you can't understand what is being said with everything being distorted. The monitor has not been in use for a few months and everything else is working properly, but I...
Have you checked the sound with some other speakers or a headphones.
If the sound is still like echo try adjusting audio settings not thru My Computer - audio, but try finding a software that comes with *********** board/sound card. I suppose the sound is some AC97/Realtek compatible card, so you should looking in your program files under Realtek into WDM and run the Audio Control Panel or Sound Manager (whatever you find). Adjust the sound effects to NONE and use some normal enviroment (other then echo/cave/big hall).
May 22, 2010 | ViewSonic Computers & Internet
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
Terrible distortion from Sony Dav-x10 2.1 subwoofer
its not broken just turn the cut off frequency to level and the volume of the sub lil bit higher and it should work fine.
Nov 11, 2008 | Sony SA-W305 Subwoofer
Echo suppression
I don't know how to remove the echos from you video but think I know what is causing them.
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I'd use headphones during videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Nov 08, 2008 | Logitech Quickcam Ultra Vision Webcam
Video conversation ECHO/Feedback
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using headphones during videoing.
Nov 04, 2008 | Logitech Webcam
Echo
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Mar 04, 2008 | Microsoft LifeCam VX-6000 (68C-00001)...
Terrible feedback sound
sounds like maybe you have two microphones running at same time?
Feb 25, 2008 | Microsoft LifeCam VX-3000 Web Camera
Awful High-pitched Noise and Echo Feedback
Jan 17, 2008 | Microsoft LifeCam VX-6000 (68C-00001)...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
