Question about Mitsubishi VS-55707 TV
Mitsubishi model# VS-50502
I turn tv power on it clicks then the light leaves the power button and the program timer button lights up then the tv turns off
  • 1 more comment
  • lj_hoy Sep 14, 2008
    some times when watching my mitsubishi tv, the power just turns off. it happens at random times, sometimes a couple times a week, sometimes a couple times a day. then when I hit the power button to turn the tv back on, it just clicks, and powers off again. then will take anywhere form 10 min. to an hour or more to power back on. bought the tv used, but have the orignal remote and book for it. if you know something I could do to fix this, please let me know! thanks
  • cartagena Dec 03, 2008
    Timer light is blinking and tv has no power
  • Anonymous Dec 12, 2008
    me to
SOURCE:
techman
  • 3130 Answers
SOURCE: Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Posted on Jun 16, 2006
MikeNJ1964
  • 398 Answers
SOURCE: mitsubishi vs-4543
Most likely the convergence output IC has shorted out and has overloaded the convergence power supply, which has stopped working. The computer senses that the convergence power supply is not running and shuts the set down. The convergence IC should be replaced, the power supply restored and the convergence circuits realigned by someone experienced in Mitsubishi projection sets. When I do a housecall for a set like that I charge $150, but shops in your area will vary so ask around.
Posted on Aug 05, 2007
  • 556 Answers
SOURCE: mitsubishi vs-5052 tv
as you are not electronic person so call skilled person. problem is simple. 1 there might be in power supply. 2 if power supply is ok horizontal section might be defective
Posted on Sep 17, 2007
  • 1153 Answers
SOURCE: Mitsubishi VS-50607 Won't Turn On
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Posted on Oct 06, 2007
  • 1153 Answers
SOURCE: tv powers on, then switches off immediately
check out ctechnicians.com and find error codes
Posted on Dec 25, 2007
Timer light continues flashing; won't turn on/off
Could be an open internal fuse or power supply failure
Jun 25, 2017 | Mitsubishi WD-65731 65" HDTV
Mitsubishi vs-50609 green timer light comes on no
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
Mar 29, 2010 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi Proj. TV,Model VS-50603, S/N 119340, won't turn ''ON'' when pushing TV ''ON'' button or remote. Green ''ON'' light comes on and then immediately off. Whats the problem?
62" mitsuabishi WD62525 had it over 5yrs now, we have been changed lamps three times,(geee lots money!!!)it worked ontill now...
two weeks ago blinking red lamp light was on , i thought lights out again so soon, i order new lamp, i cant turn on TV but blinking green timer light, TV is not working, try reset botton, turn off TV few days.
Please help
Lilly
Dec 06, 2009 | Televison & Video
Mitsubishi VS-50609 won't turn on
What a great tv this is Mitsubishi did a fine job making this one, but......only an authorized mitsubishi servicer should repair it. This set records diagnostic led codes that the technician receives to help determine where the problem might be, not the problem, but in which circuit it might be. The one thing to try is, unplug the tv , let it set for a minute, plug it back in , turn it on and hope it reset the micro. Next , call for mits. service.
Jun 11, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Does anybody have a download of a repair manual for a mitsubishi
User-Manuals.com has them in .pdf for $14.99 for download. Not a fix for a borrow but yours to keep.
Mar 25, 2009 | Mitsubishi VS-50502 50" Rear Projection...
Mitsubishi Projection TV Model # VS-50502
The power supply section is having trouble.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Feb 13, 2008 | Mitsubishi VS-50502 50" Rear Projection...
Mitsubishi VS-50607
Oct 04, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-55707 TV Logo
113 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
