Question about Compaq Presario 5000 PC Desktop
TSSTcorp CDDVDW TS-H653Z SCSI CdRom Device I am looking for a replacement drive
4 Suggested Answers
  • 62 Answers
SOURCE: driver needed for TSST Corp CDDVDW TS-H653N
Download it from
http://www.megaupload.com/?d=YX4P99CU
would suggest, personally, to download that driver [File Version: 6.0.6000.16386 (vista_rtm.061101.2205) file, and use that file to overwrite the driver on your system, seeing as my drive functions. The file source can be located at: C:/Windows/System32/Drivers/cdrom.sys
That is what I'm showing as the latest driver at the moment. Hopefully that will be of some help.
Posted on Sep 15, 2009
nostechjb
  • 28 Answers
SOURCE: TSSTcorp CDRWDVD TS-H493B SCSI CdRom Device
the laser head is faulty or the spinning mechanism is faulty. buy a new one.
Posted on Nov 22, 2009
SOURCE: Driver needed for TSST Corp CDDVDW TS-H653N SCSI
If the computer still cannot read a disc, there may be a problem with the drive. Go to method 3 to troubleshoot the CD or DVD drive. If the computer can read the other disc, there is a problem with original CD or DVD. Contact the manufacturer of the damaged disc to obtain a replacement. Method 3: Try a different disc drive If the disc is clean and undamaged, check whether there is a problem with the drive. To do this, follow these steps: If the computer has more than one disc drive, insert the disc in a different CD or DVD drive to see whether it can read the disc. If your computer does not have more than one disc drive, you can insert the disc in a different computer. If the other CD or DVD drive can read the disc, there may be a problem with your CD or DVD drive. Go to method 5. If the other CD or DVD drive cannot read the disc, the disc may not be compatible with the drive. Go to method 4. Method 4: Make sure that the disc is compatible with the drive Check the following list to make sure that the disc that you are trying to use is compatible with your CD or DVD drive. A DVD disc is incompatible with a standard CD drive. A CD-RW disc is incompatible with a CD drive that does not support CD-RW discs. A DVD disc is incompatible with a drive that does not have a DVD logo on the front. If the disc is compatible, go to method 5. If the disc is incompatible, use a compatible disc or contact the vendor for a compatible replacement. Back to the top Method 5: Use Windows Update to check for updated drivers If the disc is compatible with your CD or DVD drive, check for updated drivers that the CD or DVD drive may be missing. To check for driver updates that you can install, visit the following Microsoft Web site: http://windowsupdate.microsoft.com If these methods do not resolve your issue, try the advanced troubleshooting steps in this article. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help, or you might want to contact Support. For information about how to do this, visit the following Microsoft Web site: http://support.microsoft.com/contactus/ If methods 1 through 5 did not resolve the issue, you can follow these methods to try to isolate and resolve the problem. Method 1: Test the disc by using the command prompt to copy files Try to copy files from the disc to the hard disk. If the hard disk cannot copy files, the disc might be damaged. If the files are copied successfully, there may be file types on the disc that the hard disk cannot read, or there may be a problem with the CD or DVD drive. To test the disc by using a command prompt to copy files, follow these steps: Create a test folder on the hard disk, and then give the folder a folder name such as "cdtest." This is the folder to which you will try to copy files. Click Start, and then click Run. Copy and paste (or type) cmd in the Open box, and then press ENTER. Copy the files from the CD or DVD drive to the test folder on the hard disk. To do this, type xcopy DiscDrive:*.* HardDiskDrive:cdtest /v /e at the command prompt, and then press ENTER. Make sure that you replace “cdtest” with the name of your test folder. Note In this step, DiscDrive is the drive letter of the CD or DVD drive with which you have problems. HardDiskDrive is the drive letter of the hard disk drive to which you want to copy these files. If you are asked whether cdtest specifies a file name or a directory name, press F. If you successfully copied the files from the disc to the hard disk, the disc is not damaged. To remove the copied files, type rd /s cdtest at the command prompt, and then press ENTER. If you cannot copy the files, the disc may be damaged. Contact the manufacturer of the damaged disc to obtain a replacement. To continue trying to isolate the problem and test the CD or DVD drive, go to method 2. Method 2: Test the CD or DVD drive in a "clean boot" state If the disc is readable and undamaged, there may be some hardware or software that is interfering with the CD or DVD drive. You can test this by inserting the disc into the drive after restarting your computer in a clean boot state. This helps you determine whether any hardware or software is interfering with the CD or DVD drive. To test this, follow these steps: Restart the computer in a clean boot state. Note For more information about how to start Windows with a minimal set of drivers, click the following article number to view the article in the Microsoft Knowledge Base: 310353 How to configure Windows XP to start in a "clean boot" state After the computer is restarted, exit all programs and applications that may be using the CD or DVD drive. First, right-click each icon in the notification area, and then click Exit. Note The notification area is located at the far right of the taskbar, near the clock. Some programs that are listed in the notification area do not have an Exitcommand. Therefore, you may have to click Quit, Close, or Disable, depending on the commands that are available for that program. Click Start, and then click Run. Copy and paste (or type) taskmgr in the Open box, and then press ENTER. Windows Task Manager opens. Click the Applications tab. If any programs appear in the Task list, click the name of the program to select it, and then click End Task. Repeat the previous step until the Task list is empty. Close Windows Task Manager. Reinsert the disc in the CD or DVD drive. If the CD or DVD drive can read the disc, there may be other programs preventing the drive from reading the disc. Go to method 3. If the CD or DVD drive still cannot read the disc, go to method 4. Or, if you are not specifically using a DVD drive, you may want to contact Support. For information about how to contact Support, go to the "Next Steps" section. Method 3: Change the CD or DVD drive configuration If there are programs that are preventing the drive from reading the disc, you can try to resolve this issue by configuring the drive to run in direct memory access (DMA) mode. DMA mode is a high performance mode for transferring data to and from devices. These include CD and DVD drives. To configure the CD or DVD drive to run in DMA mode, follow these steps: Configure the CD or DVD drive to run in DMA mode. For more information about how to switch your computer's disc drive controller to DMA mode, click the following article number to view the article in the Microsoft Knowledge Base: 310751 Device settings are hard to find in Windows XP Reinsert the disc in the CD or DVD drive. If the CD or DVD drive can read the disc, you are finished. If the CD or DVD drive still cannot read the disc, try to troubleshoot DVD components by using method 4. Or, if you are not specifically using a DVD drive, you may want to contact Support. For information about how to contact Support, go to the “Next Steps” section. Method 4: Troubleshoot DVD problems If the advanced troubleshooting methods 1 through 3 do not resolve the issue, and you have problems specifically with a DVD drive, follow these steps to try to isolate and resolve the problem. Prerequisite You must use a DVD drive with a DVD logo on the front, not a standard CD drive. Step 1: Unplug any cables that are connected Unplug any cables that are connected to the video outputs of the computer. Reinsert the disc in the DVD drive. If the DVD drive can read the disc, you may have problems with the video hardware installed on your computer. Contact the manufacturer of the video hardware for support or for a replacement. If the DVD drive still cannot read the disc, go to step 2. Step 2: Update the DVD driver Contact the manufacturer of the DVD drive to obtain an updated driver for the DVD drive, and then follow the manufacturer's instructions to install the driver. Reinsert the disc in the DVD drive. If the DVD drive can read the disc, the problem was caused by an outdated driver. You are finished. If the DVD drive still cannot read the disc, go to step 3. Step 3: Obtain a hardware-based DVD decoder or software-based DVD decoder Contact the manufacturer of the DVD drive to obtain a hardware-based DVD decoder or software-based DVD decoder, and then follow the manufacturer's instructions to install the decoder. Note Many video adapters help decode DVD discs. However, the video adapter may not fully decode a DVD movie. Reinsert the disc in the DVD drive. If the DVD drive can read the disc, the problem was caused by an outdated DVD decoder. You are finished. If the DVD drive still cannot read the disc, make sure that the sound card in the computer is compatible with the DVD drive. To do this, contact the manufacturer of the sound card. Reinsert the disc in the DVD drive.
Posted on Feb 27, 2010
I have this message " SATA CD :: TSSTcorp CDDVDW TS-U633J" What does it mean?
SATA : Serial ATA, the type of interface for the Drive as opposed to IDE (the older type.).
TSSTCorp is a joint venture Toshiba Samsung for Optical drives
CDDVD R-W CD and DVD Read Write.
TS-U633J is the model number. That is the reference you use if you are looking for drivers.
Why did this information get you worried?
Oct 27, 2013 | Samsung NC10-14GW Notebook
Tsstcorp cddvdw ts-l633a scsi cdrom device not recognized, why?
Either the data cable at its back is badly plugged in (refit the data cable correctly) or the unit itself is faulty - replace it, it cannot be repaired.
Feb 24, 2011 | Acer Computers & Internet
Acer Aspire 4535 with problem Take about 20mn to 3 hours to turn on the cd rom TSST corp CDDVDW TS -L633B SCSI CdRom Device cannot read cd and dvd
i think that you need a new cd rom drive but give me a little more information on it like what exactly is it doing and was it making any noises
Feb 04, 2011 | Acer Computers & Internet
When my Brother HL-2140 Laser printer (USB port) all of a sudden stopped printing (or prints blank pages), I went to Device Manager to check on my hardware status. Under DV/CD-ROM drives, TSSTcorp CDDVDW...
Seems like the registry for your Dvd-Rom is corrupted. Try disabling and uninstalling the driver, then enable and wait for windows to clean install its driver.
Oct 12, 2010 | Computers & Internet
My tsstcorp cddvdw TS-L632N drive is not reading the cd roms at all. Reading dvds very slow. Any suggestions pl.
1.Click on Start
2.In start search or Run window type devmgmt.msc and then hit enter.
3.This would open the Device Manager Window.
4.Try locating the option which reads as CD/Dvd,there would be a + sign next to the same.
5.Click on the +sign and locate the driver below that.
6.Right click on that driver and then click on Uninstall.
7.Now locate an option which reads ACTIONS right at the top of the device manager.
8.Click on Actions and then click on Scan for hardware Changes.
9.Restart the computer to check the functionality.
Hope this helps..
Regards
Ken
May 10, 2010 | HP Pavilion DV6700T Notebook
Not working TSSTcorp CDDVDW TS-L632H ATA Device
hi.. pls remove the CD ROM from the laptop . insert once again.check the bios status ....
Dec 12, 2009 | Computers & Internet
Nov 22, 2009 | Computers & Internet
Tsstcorp cddvdw ts-u633a driver needed. help please!
http://notebooksdrivers.com/tag/pc-laptops-tsstcorp-cddvdw-ts-u633a-driver
Oct 14, 2009 | Computers & Internet
Download it from
Sep 15, 2009 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
570 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
