Question about Hoover Washing Machines
Tap to washing machine is working fine, but water only trickles into the machine when filling. What can I do? Hoover washing machine model 200 MONZL
  • Hoover Master
  • 713 Answers
Hi just read your posting.1st remove both inlet hoses from the taps and the machine.Check if there are little filters on the ends of the hoses,They could be blocked.Next check the filters on the water valves.The water valves are where the hoses connect to the machine.If the hose and water valve filters are clean then you will need to replace the water valve.Did you check how much water pressure is coming out of the taps?Please reply on how you got on and with additional information and I am sure I can help you on this problem.Looking forward to your reply.
Posted on May 21, 2011
I have a LG Punch WF-C5856TC washing machine. Off late, Notice that the water is trickling in rather than flowing. Hence it takes really really long time to wash clothes. Pls advise
The first place to look is the inlet tap in the wall
even you have the tap on full the tap washer inside jams and prevents the full flow of the water
next check out the filter in the hose at the tap or at the washing machine end
next replace the water inlet solenoid
you can check this by changing the hose from the hot water tap onto the cold water tap and pressing the hot water button to fill
solenoids do not know the difference , they just work when the power is applied
Sep 08, 2015 | LG Washing Machines
How hoover 200 MONZL 4.5 kg washing machine works
This is the car and truck section. You may want to repost this question in the appliance section.
Jul 02, 2013 | Cars & Trucks
Washing machine fills with water while sitting idle.
Another problem could be the inlet solenoid is failing to close properly, this could be caused by either an obstruction in the sealing part of the solenoid valve, a damaged or worn out seal or if the water pressure is too low. (some solenoids require water pressure to close off properly). To test this idea turn off the taps when not in use. If the water is still filling the tub, the back flow / syphoning idea may be valid. Also just to rule the idea out, turn off the tap to the machine and remove the inlet hose, if the tap "drips" this "trickle" of water maybe the culprit. If turning off the inlet tap fixes the problem you may need to replace the inlet solenoid.
Jan 08, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Cold water filling is very slow despite good water pressure and taps fully turned on
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 03, 2011 | Hoover Washing Machines
The cold water inlet is slow to fill machine but the hot water inlet works fine
Hi just read your posting.Could you please supply the model of your hoover and tell me if it is a front or top loader.The fault on your machine is due to a faulty cold water valve or dirty inlet filter.Turn the cold tap off and remove the cold water hose from the tap end and check to see if the little filter at the end of the hose is blocked.If it is, clean it and put back the hose to the tap and try a wash cycle.Please reply with additional information and to tell me how you got on with the filter.
Jun 29, 2010 | Washing Machines
Kenmore 90 Series Washer : cold water fills at just a trickle:
your hot water goes through the water heater so contaminates settle in the heater. the cold does not, there is a screen inside the fill valve where the hose hooks to the valve on the machine. if this in not plugged then the fill valve will have to be replaced. because of the build up of contaminates..
Jul 08, 2009 | Kenmore Washing Machines
Washing machine cold water not filling
Typically this indicates that you have a water inlet valve that is not opening. Replacement of this part would be ideal, and should fix the problem.
Regards
Brian
Sep 10, 2008 | Washing Machines
Washing Machines Logo
52 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
