Question about Kenmore Dryers
Not dyring - Kenmore Dryers
  • Kenmore Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on May 26, 2011
Problems with frigidaire affinity dryer model gle02152es1.
Hello ljdixon226 - From what you have described the unit could possibly have a communication problem with the control panel. However, if the unit is not producing any heat please have a professional diagnose the heating element and the blower assembly as well. Either, or, could be faulty at this time. This is not a typical DIY job so please consult a professional.
Oct 08, 2012 | Frigidaire GLEQ2152ES Electric Dryer
How can I make sure a Banking Trojan bug is out of my PC
Try running some WEB based virus scanning programs.
Trend MicroHouseCallhttp://housecall.trendmicro.comSymantec -Norton Security Scanhttp://security.symantec.com
Mar 29, 2012 | Compaq Computers & Internet
Any tips on extending the life of a Macbook Pro battery?
My suggestion would be to buy a new battery.
After that you should shut down your computer at night (or every other night) and make sure you don't leave it plugged in for a long time (only charge until it is 100% then unplug).
These are two of the most important things towards ensuring significant battery life.
Hope that helps!
Dec 13, 2011 | Apple MacBook Pro Laptop Computer with...
I have a Whirlpool dryer estate and we have to keep dyring our clothes a couple of times what is wrong with it and how to fix it
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Nov 06, 2010 | Dryers
I have an amana dryer, model # ale331raw. When you push/turn the timer knob to start the dyring process it turns on but as soon as you let go of the knob the dryer will turn off. You can here the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 28, 2010 | Dryers
Hi! my comp is nfected with a trojan masquerading as a security tool. it keeps popping dlhost.exe is infected with virus DOS.Jeff.812 this worm is trying to send our credit card details using dlhost.exe...
First try this but be careful:
To remove Trojan, you must first stop any Trojan processes that are running in your computer's memory. To stop all Trojan processes, press CTRL+ALT+DELETE to open the Windows Task Manager. Click on the "Processes" tab, search for Trojan, then right-click it and select "End Process" key.
To delete Trojan registry keys, open the Windows Registry Editor by clicking on the Windows "Start" button and selecting "Run." Type "regedit" into the box and click "OK." Once the Registry Editor is open, search for the registry key "HKEY_LOCAL_MACHINE\Software\Trojan." Right-click this registry key and select "Delete."
Finally, to completely get rid of Trojan, you must manually remove other Trojan files. These Trojan files can be in the form of EXE, DLL, LSP, TOOLBAR, BROWSER HIJACK, and/or BROWSER PLUGIN. For example, Trojan might create a file like
%PROGRAM_FILES%\Trojan\Trojan.exe. Locate and remove these files.
OR
If you can pass to the Windows interface you can run a Trojan remover like this one Trojan Remover at cNET. If not do it manually, instructions HERE
If your OS is Windows go to this link by Microsoft Online Scanner
also this one is a good one from TenMicro HouseCall
Oct 03, 2010 | Intel Computers & Internet
Virus Win32TrojanTdss and Packed.Generic.200 that I can't remove?
These trojans are pretty good at stopping new installations of programs that might remove them. If you were a smart bank robber, wouldn't you want to secure all the entrances so the police couldn't just walk in on you? Anyway, There are manual removal processes which are outlined by the Symantec website:
http://www.symantec.com/security_response/writeup.jsp?docid=2008-091809-0911-99&tabid=2
http://www.symantec.com/security_response/writeup.jsp?docid=2009-040809-3630-99
Or, you can find a tool to remove the trojans first, then run AdAware and MBAM.
Jul 18, 2009 | Microsoft Internet Explorer 8
Ford 2002 powerstroke
p1212 is injector control pressure not detected dyring crank.
p1280 is injectoe control pressure out of range.
Have a fuel pressure test done, Might be weak fuel pump or fuel pressure regulator.
Mar 16, 2009 | 2002 Ford F250 Super Duty SuperCab
My GE dryer will not heat up after flood damage
Hello chucky40,
There is a good chance that your gas valve has been damaged by the water. Can you tell if after you try starting it if the igniter comes on and/or you have gas flow to the burner? Those are the prime suspects ( albeit not the only ones) but you will need to verify these basic functions before others can be examined..
Keep me posted and I'll try to help you get thru this..
Regards,
Rick
Nov 23, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
Dryer is very noisy during dyring cycle.Used to be so quiet you would have to check to see if it was running.
Your complaint is;"Dryer is very noisy during dyring cycle.Used to be so quiet you would have to check to see if it was running".
You have not provided a brand name or model number. I I can only offer information based on genric or common solutions. Below is a link that should prove helpful if you need additional information.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 15, 2008 | LG Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
