Samsung hl-p5685w sound comes on lamp is working fans are working new color wheel and lamp installed still no picture please help
  • 1 more comment
  • Giovanni Latona
    Giovanni Latona May 23, 2011
    there are no blinking lights tv shows normal , last night the tv worked *** long as i kept the back open and a large fan running on it i checked the tv fan and is working , but today even with the fan on the tv it will only stay on for about 30seconds then the picture goes away
  • Giovanni Latona
    Giovanni Latona May 24, 2011
    no blinking lights all
  • Giovanni Latona
    tv was working for around 3 hours last night after i pulled the back off and added a large fan for cooling but the tv fan is working fine but today tv comes on for 30 seconds and picture goes away volume is still on lamp is still on just no picture i just installed a new color wheel
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors most likely in the power section.
Any caps in this (or any) sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably give a display when turned on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with similar issues) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on May 24, 2011
  • 4,889 Answers
The lamp is probably coming on just barely. There is hardly anything else in the tv that can cause this issue apart from the lamp and/or its power supply(ballast). What is the status of the LEDs infront of the tv? Which of them are blinking/lit when the tv is on and when you have sound but no picture?
Posted on May 23, 2011
  • eagle338
    eagle338 May 23, 2011
    ok. And you did not tell me whats the status of the LEDs at the front when it shuts off? Which of the 3 LEDs are blinking?
  • eagle338
    eagle338 May 24, 2011
    No no this is not a color wheel issue. 100% guarantee. Its the lamp thats reaching the end of its life. I am damn sure. Pretty sure the lamp will go out completeley and all the three lights at the front will keep blinking. It cannot be anything else
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Hello
Switch Off the set and pull out its power chord from the AC wall power socket, wait of one minute and then switch it On, and see whether it helps you.
If it does not help; reset the picture setting to factory defaults.
Resetting the Picture Settings to the Factory Defaults
Press the MENU button to
display the "Mode" menu.
Press the UP or Down button to
select "Reset", then press the
ENTER button.
The previously adjusted
picture settings will be reset
to the factory defaults.
Press the EXIT button to exit
If this also does not help you; suspect the set-top box, if used. just tune the TV with external antenna and see whether there is picture and sound with normally tuned Tv. If it is ok and there is no picture with set to p box only, make sure that either the video connection from set-top box to tv, of video out from set top box is faulty. OK
Posted on May 21, 2011
  • The Knight
    The Knight May 21, 2011
    If you do not get picture from your TV even with tuned stations, DLP chip inside it shoud be suspected.
I have a Samsung HL-P5067W/HL DLP tv. When I turn it on cold the lamp light blinks on and off. The fan makes a high pitch sound a relay clicks the TV goes back to standby and the lamp light starts blinking...
This sounds like a lazy lamp--that is getting hard to start. Try a new lamp first. If you are inclined to do so--get a bard bulb and install in the old lamp housing and save some money. Get a real PHILLIPS bulb--it will last a while--compared to cheap generics that are good for maybe 6 months !!
Feb 18, 2014 | Samsung HLP5067W Television
Lamp comes on but without picture
The color wheel is the likely problem here.
Nov 27, 2012 | Samsung HL-S5087W 50" HDTV
HL-P5063W Turns on, but no picture.
remove and inspect the lamp the model indicated uses---you can usually also look from the rear to see if lamp comes on at all---set also prone to bad color wheel--grinding or high pitched fan like sound--it faces the lamp--with lamp removed look to see it is not shattered or missing pieces and that lamp not shattered inside.
10_22_2012_4_53_15_pm.jpgtypical color wheel
Oct 22, 2012 | Samsung HL-P5063W 50" Rear Projection HDTV
Tv keeps shutting off. Currently no soud or picture
The set has a color wheel which may be bad, it often makes a high pitched or fan like sound prior to failure--it can even be a grinding noise.
I would with set unplugged remove the lamp cartridge and look where it faces---the color wheel can be seen.
What you are looking for is wheel shattered or missing any of the colored segments? If wheel does not turn or runs too slow set will detect this and shut lamp off etc.
Aug 29, 2012 | Samsung HL-S4266W 42" HDTV
Samsung 50" DLP No picture and very deep & lound vibrating sound. Red lights flashing,Sand By Temp. And Green lights flash Lamp.
Loud sound you are hearing is coming from your color wheel and has your Lamp ever been replaced? this set has 3 Fans they all must be running for set to operate correctly! Encompass Parts has Boards and Color Wheel But for Lamps Mats has them for 99.00 1-800-628-1118 and EC Parts 1-800-638-3328
Jan 21, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
I have a Samsung 50 inch DLP - I heard a pop and the picture immediately disappeared. The 3 lights were flashing on the front which according to the book said it needed a new lamp installed. I ordered it,...
Sounds like the color wheel may have also gone bad. I recently saw a 56" Samsung where the bulb and color wheel went at the same time. The color wheel could produce a crying noise while trying to spin up.
May 05, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV has lot picture. Makes a Humming sound
That sounds most like the color wheel,
to change that you need to have some skill in electronics, I would recommend to take it to a shop
Apr 25, 2009 | Samsung DLP HL-P5663W 56" TV
Motorized sound and picture quality poor and jumpy
your husband is correct it is most likely your color wheel very common and it will effect the picture. what will happen soon is your tv will not turn on. The cost is two possiablities. color wheel replacement 225,00 part is 80,00 complete light engine in rear cases cost is 650.00 dollars . I hope this helps
thanks doctor video leadingedgeeletronics since 1987
May 04, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
