Question about Saws
I have the brutus 60010 tile saw and need bearings for the motor and a new wheels for the slide . where can i get them..
  • 2712 Answers
SOURCE: Tile Saws types problem
Mass produced ceramic tiles of medium to soft grades are cut easily with hand tools. The glazed surface of the tile is first scored with a tool that carries a hardened metal wheel. Then with a support directly under the score pressure is applied to either side of the cut and the tile snaps along the score. The harder grades of ceramic tiles like fully vitrified porcelain tiles, stone tiles, and some clay tiles with textured surfaces have to be cut with a diamond blade.
Posted on Aug 27, 2008
  • 2712 Answers
SOURCE: Tile saw helping tools
On most of the tile project you will need: tile nippers, 1/4", 1/8" and 3/16" spacers, grout sponge, mixing tub, mixer and various trowels.
rowdy45176
  • 2176 Answers
SOURCE: I need to change the bearings on the amature of a dewalt tile saw
I looked at a breakdown and there is no clip. Sometimes the bearing is tough to pull out of the gearcase. Do you have a dead blow hammer? Sometimes I have to apply pressure (pulling) to the armature and tap the gearcase make sure that I hit a solid thick piece of it and generally it will jump out of there. Also in the past with the fan bearing on the armature it is so close to fan that you have to crush it in a vise and use a bearing splitter to remove the inner race, or if you buy the parts from Dewalt you might take it with you and ask them to remove and press the new ones on. Let me know if this doesn't work and I will research further.
Posted on Feb 19, 2009
markam54
  • 5 Answers
SOURCE: my husbands wet tile saw
surley nothing wrong with fixing old one.If bearing is a easy one to get.Another thing to consider how much does he use it if for his every day work new would give less prob and warrenty.lookup make online should find part from the maker.hope helps
Posted on Apr 15, 2009
  • 55 Answers
SOURCE: I need the output shaft of this motor. It has the
You can order the parts you need from this website
http://www.mkdiamonddirect.com/category.sc;jsessionid=B8C66F8A4D5E422E3B401A634FBA7476.qscstrfrnt01?categoryId=99
Hope this is what you need
Posted on Dec 02, 2009
D24000 wet tile saw smells of burning. What could this be?
mmm.. motor problem,armature or field coil burned or bearing burn motor housing
Jun 03, 2012 | Dewalt D24000S Heavy-Duty 10-inch Wet Tile...
I have two 101's and both saws have a terrible wobbling. I have put new blades on both and no corrrection. I put the same blades on a 10" target and they boith cut perfectly....i am at a loss
well you might check the belt tension,you can tighten it by loosining the 4 nuts that hold motor then tighten the middle bolt in the back,that slides your motor forward,then retighten the 4 motor nuts.if saw sounds louder than normal, it probably needs new bearings
Nov 17, 2010 | Mk Diamond Mk Tile Saw Mk-101 Pro24 10in
The wet saw husky thd 950l wore out yhe bearing and make
I am a contractor who has used this saw for about four years. I just ordered the new motor for $79. The Husky has been a great saw. Don't waste your money buying some junk for Harbor Freight.
Oct 14, 2009 | Wet International Husky 7" Wet Tile Saw...
Tile saw began having trouble starting. I would
Your motor brushed sound like they're gone bad. Some electric motors have two small plugs on the side which house the brushes. See if yours has this and get new parts. The other possibility is that the bearings are corroded and has built up enough resistance to stop everything.
Might not be able to replace those, however.
Oct 04, 2009 | Dewalt Heavy - Duty 10" Wet Tile Saw -...
Need the Brick Carriage Rolling Bearings
i dont know where your located at, but when i need any parts for my tile saws i get them at the tile shop, that sells me the tile, most good tile distributors sell tile saws and most carry parts for saws targets a great saw and a good tile store will probably have those roller bearings in stock.good luck.chad
May 15, 2009 | Target Saws
Wet saw not cutting material completely
It might need a new blade. But try putting an old tile or offcut behind the tile you are cutting. Make sure the table surface is clean and flat. Residue tends to build up around the front of the blade which could cause the tile to crack. The ryobi's have a habit of water getting into the motor and the bearing destroys itself. Next time you take the blade off, take of the blade support and put bearing grease behind the rubber washer. I've blown up two this year until I worked out what the problem was.
Apr 25, 2009 | Saws
Mar 31, 2009 | Mk Diamond MK - 1070 Tile Saw
How to use Tile Saw
To cut a tile using a wet tile saw, measure the exact space in which the tile will fit. Cuts are usually along a perimeter, in a corner, or around an electrical outlet. Mark the line on the full-sized tile in grease pencil. Most saws will accommodate tiles up to 12 inches (30 cm) in size, but oversized saws can be rented for huge floor tiles. Wearing safety glasses, place the tile on the moveable platform, and line up the mark with the edge of the saw. With the motor running, slide the platform toward the blade with an even but gentle pressure. Since you are grinding the tile apart, ensure that the water have sufficient time to cool everything.
Aug 27, 2008 | Dewalt DW8308 60-Grit. 4 1/2" Blue...
Saws Logo
101 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
