Question about KitchenAid KBRA20EL Bottom Freezer Refrigerator
The handle is coming loose on one side of my freezer door. I have a , KitchenAid Architect Series II KBFS20EVMS. Is there a way I can fix it myself?
  • sandypik992 May 23, 2011
    Thanks,
    How do I go about taking the inside panel off in order to tighten the handle screws?
  • 5,370 Answers
Yes you can tight the handle.If the handle is coming loose, that means the screws are coming loose.The handle is fitted via screws from inside.You will have to open the door, then from inside remove the inner door panel.Once the inner is out, on the back side of door you will see the screws.Just re-tight the screws and handle is tight.Then replace the panel and tight it.
To see image of door handel removal and screw location.Please click the link below:---
http://technoanswers.blogspot.com/2011/05/kitchenaid-architect-series-ii.html
This should help.thanks.Helpmech.
Posted on May 20, 2011
  • raj somaiya May 23, 2011
    Click the link:---
    http://technoanswers.blogspot.com/2011/0...
    Part number 4 is the inside panel.Its fitted by screws or clips.You will need thin knife to insert in the door panel gap.Open the door and in the inner side there is panel.Remove that panel out and you will see the screws.
    This should help.Thanks.Helpmech.
How do I tighten handle on kitchenaid refrigerator model ksso42qtb00
look for allen screws from behind the handle were it is hard to see. they will be very small.
Oct 11, 2014 | KitchenAid Architect Series II KSSO42QTB...
KSRS25CSMS02. The benzyl is loose for the ice maker and water on the freezer door. How do you remove it or tighten it up?
It should snap on because it (the facade) has plastic tabs that should snap into locking tabs as seen in the video below. Thanks John Tripp Appliance 911
Jun 17, 2014 | KitchenAid Architect Series II KSRS25CSMS...
Handle loose
should be screws coming in from the end of the door several from top of door to bottom
Nov 20, 2013 | KitchenAid Architect Series II KSSO42QTX...
Door handles loosen
You can tighten them just find where the allen key nut, or screw is, normally on the bottom of the handles.
Is it possible to replace the handles on the KitchenAid 42" built-in stainless french door refrigerator (KBFC42FTS) with different handles? Ideally handles that look more like the handles on the Pro...
most the handles will inter change . you will need the model # of the other frig in order to get the ones you like . but keep in mind they are not inexpensive . I looked up one of these pt # 2316868 stainless handle and are sittind down! they are $ 101.93 each . . and you need 3 .. hope this helps mm feed back pls
Jan 20, 2011 | KitchenAid Architect ® Series II KBFC42FTS...
I am having trouble getting new fridge cool enough in fridge. Should it get below 40 f in fridge on mid setting of both freezer and fridge section
fresh food tempt should be 38 deg ( this is good ) and 40 is close . as it will be 5 deg up and down freezer thempt should be around 5 to 15 deg or ice mker will not work . make sure the coils ore clean and fans are working or these tempt can not be obtained . mm feed back pls
Jan 01, 2011 | KitchenAid Architect Series II KSRG25FVMS...
KSRS25RGBT00 Kitchenaid How Long does a ref run each day if unopened, full of food in ref and freezer and room temp around 72deg f Ref is 11 years old. Coil is very clean.
lets just say a modern unit would run about 15mins every 2 hours.(if the doors are kept SHUT.(they dont count how many times the little darlings leave the door open)
Oct 14, 2010 | KitchenAid Architect ® Series II KSRS25RS
Handle loose on Refrigerator
I have same problem. Just called KitchenAid and they told me I needed a T-20 torque key - you can buy it from them or at a hardware store. Good luck.
Jun 03, 2008 | KitchenAid Superba Architect KSCS25INSS...
To fix this you will need an Allen wrench small one there are 2 set screws on the inside part of the handle (on side toward the center) you wil need to tighten these to fix your problem
Feb 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KBRA20EL Bottom Freezer Refrigerator Logo
129 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
