Question about Sport & Outdoor - Others
What is the air gap for a magnito ignitino system for 12h8022675 model lawn mower enging
  • wdarland May 20, 2011
    it is a one cylnder engin in a sears lawn motor. engine part # 12h8022675b1
  • wdarland May 21, 2011
    thanks
  • 10,515 Answers
For best performance, it's as tight as you can get it. A dollar bill folded in half works great. The book adjustment is .010"
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 21, 2011
    Top Expert:
  • 76,649 Answers
How many cylinders is the engine? what is this motor in? It is the brand?
Posted on May 20, 2011
  • yadayada
    yadayada May 20, 2011
    OK looked it up based on it being a one cylinder.
    Set point gap at .012"- .014" inches at high point of cam.
  • yadayada
    yadayada May 22, 2011
    I gave you the information you requested why the rating???
My lawn mower will not start. It sputters but will not fully turnover. It will continue to sputter as I adjust the choke and then eventually die.
It is probably the timing. As the engine turns the ignition fires due to the rotating magnet passing by the "magnito" coil. If the system is misaligned or dirty it is firing the spark to soon or to late in the cycle. Pull the top and have a look could be loose or have a broken wire or need to adjust the pick up gap. I am guessing that the flywheel you replaced was involved with the pull cord which means that you had that opened that portion of the motor which exposes the magnito.
Oct 15, 2014 | Garden
Craftman 650 series what is the magnito gap?
Hi, 8 thou is the correct gap, regards Phil.
Jun 26, 2012 | Garden
What is the gap on the magnito
i use two pieces of printer paper to set the gap on the ones i set up im sure there is a spec but never looked
My yardman Lawn mower does not restart after stopping to empy the bag. I have to put it down for about half to one hour and try again. The spark plug has been changed, the gas tank has been changed, the...
Try adjusting the magnito. AND - - try removing the screw that holds the bowl on the carb- - look for tiny holes in the bolt or screw - [ call it either] - then run a tiny wire in the holes and blow them out - blow hard -- then replace it. Be sure the o ring is on correctly too.
Sep 13, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
OUr murray lawn mower will not make spark at spark plugs. Help
check all your kill wires first to see if they are touching ground somewhere.
then check magnito/coil for power to it
disconnect kill wire at magnito if there is power to it.
see if you have spark
if not .... you need a new magnito
May 21, 2010 | Briggs & Stratton Garden
Start and immediately stops
spark plug gap would be .030 and magnito gap would be .010. I would clean carberaor. Sounds like the main jet is plugged. Hope this helps you.
May 07, 2010 | Mtd 22" Yard Machine Push Mower
Doesnt get spark
check the magnito for rust build up.
try a different spark plug.
try adjusting the gap between the magnito and flywheel... use a peice of paper for a gap guage.
Jul 30, 2009 | Homelite Mighty Lite Lawn Trimmer
My craftsman lawn mower stalls .i changed the oil and fresh gas..air filter is clean
check the magnito there may be build up of rust on it.
it could also be a bad sparkplug
Jul 29, 2009 | Garden
Sport & Outdoor - Others Logo
20 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
