Question about Car Audio & Video
Replacing radio with an after market cd player in a 1999 ford au sedan jjust need to know what color wires what on the car
  • 3,018 Answers
  • You did not list the model of Ford Sedan you are inquiring about. Here is a link that has quite a lot or car stereo wiring diagrams http://www.modifiedlife.com/request-a-ford-car-radio-stereo-wiring-diagram/ Look at the upper right of the page and scroll down a little bit as I have it on Ford vehicles already. Find the make and go to the year.
  • That being said if I can make a suggestion. I have hooked up hundreds of car stereos in my life. When I pull a factory radio I don't use the same wires that powered that factory stereo to power the after market stereos, DVD players etc. I go into the dash and find suitable wires a little thicker gauge to handle to often more powerful output of the aftermarket stereos.
Regards, Tony
Posted on May 20, 2011
L am placing an after market radio into a ford forte au 11 2000 model after pulling out the original radio out l need a wireing diagram for the original harness of 16 wires the new radio has 12 wires
http://www.fordaustraliaforums.com/forum/showthread.php?50606-Need-wiring-diagram-for-au-11-ford-2002-for-stereo-please-help
there are two links on the second post.
Aug 15, 2016 | Ford Cars & Trucks
Should i replace radio/cd player with factoy radio/cd player or after market radio/cd player
this is a matter of choice, but if you get an after market one it will most likely have to wired in by a radio installer as the plugs will no match up.......hope this helps......cheers.
Jul 05, 2011 | Ford Expedition Cars & Trucks
I need to know the wiring guide to installing a cd player into a 1999 ford festiva please
most stero shops, best buy and some walmarts will have a 15 to 30 dollar plug that plugs into the factory harness and wires color for color to the aftermarket radio. good luck
Mar 21, 2011 | 1993 Ford Festiva
What is the color code for a 94 ford bronco xlt raido? I bought an after market cd player to replace my factory ''tape'' player. I'm not getting enough power from my red wire so I thought it's probably in...
run any power wires directly to a post on the fuse block. yellow or orange needs power all the time even with the key off for the memory. the red wire should be on a switched terminal. THe factory radio wires have many other things that may come off them that may effect performance. You can buy a fuse tap at the same location you got the harness, if you need more help just post back, I will watch for any questions.
Sep 10, 2009 | 1994 Ford Bronco
Radio wiring different than everywhere on the web says it is.
the power amp is usually under the back seat.your stereo sounds like the 2000 premium model.take the radio out and go to ford and they will match it up to get you the right info for an aftermarket harness.the ford service manual has the pin out,and you can wire it all from that data.
Jun 12, 2009 | 1999 Ford Explorer
1991 Ford Tempo Stereo Wiring
you need a wire harness for your car you can buy them at most auto parts stores make sure and buy the one for your make and model they should have instructions and the wiring diagram most harnesses are color coded and pretty simple to install
May 15, 2009 | 1991 Ford Tempo 4 Door
Need to know how to hook up a sony cd player
see if this helps bro.
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
May 09, 2009 | Sony ATRAC MPS/CD/AM/FM Personal CD Player
What wires do i connect for my cd player? What colors connect?
here are the factory wire colors and what they do.
1999 Ford Escort
Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: Green
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: White/Orange
Car Stereo Amplifier Location: Under the driver seat.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Violet
Left Front Speaker Negative Wire (-): Blue/Orange
Right Front Speaker Positive Wire (+): Blue/White
Right Front Speaker Negative Wire (-): White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Blue
Left Rear Speaker Negative Wire (-): Red/Blue
Right Rear Speaker Positive Wire (+): White/Green
Right Rear Speaker Negative Wire (-): Blue
Mar 04, 2009 | 1999 Ford Escort
How to install a durabrand 60 watt car cd player?
the easy way is to buy a 5$ harness from pepboys or a auto stereo store ask them a harness for your make and model car to hook up a after market radio that harness will plug into your factory harness also the new harness will give you a wire diagram telling you what wires are what if you dont know about what wires are what on your after market radio they are sometimes listed on the top of the radio its real easy most radios are red power yellow aux -only power when ignition is on and black ground speakers are most of the time one color for all negitive and multi colored for positive good luck I hope this helps good luck....
Dec 31, 2008 | Durabrand Car CD Player and AM/FM...
Installing a new car radio
if you have a wiring harness al the wires are color coded to match the after market radios colors. the yellow constant wire goes to 12 volt or battery wire. the accessory wire would be the red wire that is the switched 12 volts. the remote is for the factory amp or an aftermarket amp which turns on and off it would be the blue with white wire.
May 28, 2008 | JVC KD-SX990 CD Player
Car Audio & Video Logo
635 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
