Question about Garden
Have to change the points in my john deere 316 tractor.......where are they? and how to I change them
  • 69 Answers
SOURCE: JOHN DEERE 318 LAWN TRACTOR WONT START
ok, since you have the points, I assume you have the B43g Onan
engine. Was it running before the new parts were installed?
Check your point gap and make sure it is .016, plugs ahould be gapped at .025 Make sure your plug wires are good too. Should be somewhere between 0 and 10,000 ohms per foot, when measured with an ohmmeter. Once everything is rechecked for gap distance, make sure there is no spark by pulling plug out, leaving wire on and ground the outside of plug to the chassis of the tractor.
Crank over and look for the spark. Coils are about $100, so you want to eliminate everything else first.
Diagnosing a points ignition for no spark is really simple. Do you have 12V at the coil? Do you get a spark when you connect and disconnect the negative terminal of the coil to ground? If not you have a bad coil.
Posted on May 19, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
No spark while cranking,only when you turn the key off?
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
John Deere 316 318 and 420 Lawn and Garden Tractors Service Manual
Dec 05, 2015 | John Deere Technical Service Repair Manual...
My john deere 316 loses power going up hills and when I have the mower pot on
Sounds very much like a fuel issue, i.e., starving for fuel. Check the fuel filter and replace.
Aug 04, 2014 | John Deere 300 / 316 Hydrostatic Tractors...
I need a manual for a john deere 316 lawn tractor
You can get a manual for around $25 but I know this website it has every thing about the lawn mower it is http://www.tractordata.com/lawn-tractors/000/0/3/34-john-deere-316.html I hope this helps
Apr 07, 2011 | Garden
Brake pedal won't release on a John Deere 316 lawn tractor
I have the same problem. I just wiggle the black handle on the parking brake release. It usually allows the pedal to come back up. One of these days I'll see what hanging up in the linkage.
May 24, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John deere 316 won't start
not sure but i think check the battery i am fighting the same problem and i jumped it from my truck and it runs fine i am looking for a battery tto dya
Apr 21, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
321 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
