Question about Pentair Whisperflo 075 Hp Ur Pool Pump Wf23 011771
Turned on pump wont start - Pentair Whisperflo 075 Hp Ur Pool Pump Wf23 011771
    President:
  • Pentair Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
It could be the pump is bound up but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
Start with the capacitor if one is present. Use a digital multi-meter (DMM), preferably with a capacitor setting, or an analog meter set for Ohms. With an analog, you should see the needle deflect as if testing a closed circuit then it will slowly drop to 0 if the capacitor is good. If it doesn't move or moves and stays to the side showing a closed circuit the capacitor is bad. If you notice a burn hole near the terminals on the end of the capacitor do not bother to test it. If you do not have access to a meter you can try grounding the posts together with a screwdriver to see if they arc although it is not a very reliable test method. Be sure you are holding on to an insulated handle for the tool you use to short the terminals together or you can get a good poke.
Next check the internal stationary start switch for continuity thru the contacts. Bent or burned up points and arms can cause a startup failure...you may need a new part if yours is more than bent out of position.
Finally check the winding for grounds and shorts...if you find any it is most likely time for a new motor.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage. If you wish to continue to try to repair it yourself please comment with any questions you have as you work thru the pump and motor.
If this answer does not fix your problem, please comment with additional details or contact me thru our site at www.arrowpools.net prior to rating the answer; I'll do what I can to help. Positive feedback is appreciated once your problem is solved!
John
Posted on May 21, 2011
Why won't my car start? It was running last night.
Try start the car again when it is completely dry, if it starts the rain may be short circuiting something on the loom in the engine bay.
If it still wont start,
will it turn over? (car tries to start)
- If it wont turn over the battery would be dead
- If it turns over but wont burst into life then we can go from there ^_^
Oct 24, 2012 | 2002 Buick Rendezvous
1999 Jeep Grand Cherokee wont start ???
sounds like a bad fuel pump. open the gas cap and listen when you turn the key to the on position, not all the way to engage the starter, you should hear a buzzing for 5 or so secands that is the fuel pump in your gas tank. if you dont hear that buzzing the intank fuel pump is probley not working.
Aug 27, 2012 | 1999 Jeep Cherokee Grand 2WD
Will turn over but wont start yesterday would 96 chevy blazer
your fuel pump is starting to go bad...blazars are notorious for fuel pump problems and if if is the pump dont use the cheap aftermarket one.... within the next 30k it might come back again..by a dealer stock pump. let me have some feedbacor rate this, thanks.
May 07, 2010 | 1996 Chevrolet Blazer
Turn key wont start- it cranks
check plug for fuel pump in harness near gas tank for corrosion and it may also have seoerated wire where it comes out of connecter the seperation may be from pulling on wires when pump replaced insulation may look alright because it streaches.
Apr 21, 2010 | 2003 Pontiac Grand Am
Turn key to start-engine turns and i have spark wont start
I would check fuel pressure so you can rule out pump. I had a bad pump right out of the box before. Also you may want to change fuel filter so you can rule out plugged filter. You have spark, sure seems like still no fuel.
Mar 22, 2010 | 1999 Chevrolet Silverado 1500
2003 Pontiac Grandam wont start
if you are not hearing the pump turn on there's a good chance that its the fuel pump most gm's have a faulty wiring on the fuel pump harness id check the relay and wiring if theirs power to the pump but not crank that would be it id get a gm pump not a carter better to use oem
Sep 27, 2009 | 2003 Pontiac Grand Am
Chevy astro van turns over but wont start when
Check to see if the fuel pump is kicking in,
when you turn the key on without starting the van you should hear it kick on for about 2 seconds,
It could be...
A clogged fuel filter...
Blown fuse for the pump..or bad pump relay..
No gas
Bad fuel pump
Mar 07, 2009 | 2000 Chevrolet Astro
1997 blazer fuel pump problem.....
ya the fuel pump wont pump with the lines off but the pump is going bad they will work and wont work
Mar 06, 2009 | 1997 Chevrolet Blazer
Wont start
SOUNDS ASIF FUEL PUMP OR PUMP FUSE IS FAULTY CHECK FUSE FIRST THEN LISTEN FOR HUMMING SOUND WHEN KEY IS TURNED ON IF NO SOUND PUMP MOST LIKELY CAULPRIT.
Dec 17, 2008 | 1996 Plymouth Voyager
Pentair Whisperflo 075 Hp Ur Pool Pump Wf23 011771 Logo
52 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
