Question about Maytag MAV6300 Top Load Washer
I have a Maytag MAV6300 washer and a Maytag MDG6200 gas dryer. I'm would like to know what the cu.ft for both are. It doesn't say in the manual and i'm trying to compare a new unit to replace the old. Thanks
4 Suggested Answers
  • 16 Answers
SOURCE: On-line User Manual "Kenmore 3.8 cu. ft. HE3t Washer
I have the Service Technician Diagnostic Guide...it was located behind the lower front panel on the right hand side. It's not really a user manual, but wasn't sure what info you needed that you hoped might be in the user manual, as opposed to a Diagnostic Guide.
Posted on Feb 28, 2008
Jimster
  • 240 Answers
SOURCE: What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
Posted on Jun 01, 2008
SOURCE: maytag neptune mah3000aww tub size
The answer is:
CAPACITY 3.1 Cubic Feet
The reference for this answer can be found here:
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Seach in this document for "capacity".
SECTION 1. GENERAL INFORMATION Page 1-4
Posted on May 25, 2009
MHWE200XW00 Accidentally unplugged unit while in cycle. Have technical sheet, ran diagnostic test, F1 E1 shows and 3 beeps. Released door manually. Clicking noise = power to CCU. Reset the computer?
Troubleshooting - Maytag MHWE200XW Use And Care ...
www.manualslib.com > ... > MHWE200XW > Use and care manual
Maytag MHWE200XW Manual Online: Troubleshooting. of a service call... In U.S.A. www.maytag.com/help In Canada www.maytag.ca ? Did you empty pockets.
Maytag 3.5 cu. ft. Front Load Washer (MHWE200XW)
www.searsoutlet.com > Washers & Dryers > Washers
Shop for a Maytag 3.5 cu. ft. Front Load Washer (MHWE200XW) (MHWE200X) at Sears Outlet today! We offer low prices and great service.
Maytag , Whirlpool Washer Repair - Drain pump error, no ...
? 4:29
https://www.youtube.com/watch?v=QMRIPmrlAkI
Jul 2, 2013 - Uploaded by ApplianceVideo.com
Service a Maytag Washer suffering from this following dilemmas: Drain pump error f9e1 At: http://www ...
Jan 24, 2016 | Washing Machines
Need service techs contact info
your local retailer should know who to call . we do not , as we do not know where you live , Maytag Kitchen Laundry Home Appliances
Oct 14, 2015 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Electrical on but dryer does not start
Sounds silly, but because it's an electric dryer, it's run on a 220 line. Double check your breaker box to make sure both breakers are in the correct position. If only one breaker is in the correct position, you'll have electrical power, but the drum won't spin.
Jul 28, 2013 | Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas...
My maytag bravo dryer turns on and tumbles but doesn't heat
There may still be a warranty left on it. the thermistor or the heating element may be at fault.
Dec 20, 2012 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Lid lock won't release on Cabrio washer
hey there have you tryed un plugging it the pluggin it back in
Nov 18, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer dosen't blow air
replace the blower belt and it will blow air from the dryer
Apr 20, 2012 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Dryer heats OK when turned on but the timer never moves and the dryer doesn't turn itself off......
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101,./,./'
Jul 13, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
My dryer squeeks when running
Hi, I've had a similar problem (I think) on my MDG7400 dryer. There was a cyclical squeak, metal against metal. It turned out to be the screw that holds the drum paddle to the drum. It had worked itself loose and was scraping against the inside wall of the dryer. Remove the front door lift the top, and tighten 'er up. Hope that helps.
Nov 19, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Washing Machines Logo
97 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
