Question about Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer
Do i have to be connected to my modom or phe jack to use fax? i have voip and wireless??? I bought it because I dont have room to keep it plugged in and next to modom that was the point of the wireless.
    Genius:
  • Canon Master
  • 1,479 Answers
The fax uses a phone line, hope this helps
Posted on May 20, 2011
Hi, I need to connect my comSwitch 5500 to the Cable/internet/VOIP. Command Communications ComSwitch 5500 is a Telephone Line Sharing system- (automatic phone/Fax Switch) sold under the following...
I'm not one hundred percent sure on this, but it does look like you need a separate phone line since VOIP revolves around using your internet as a gateway for making phone calls. And since majority of VOIP uses ethernet connections, or wireless, there is no phone line to use.
Feb 28, 2011 | Computers & Internet
I own a Canon Pixma MP530 all-in-one fax,copier, printer,scanner. I cannot send or receive faxes since I switched my Comcast voip phone line from my office to my home phone, along with my MP530. The fax...
First try one step. The line which you have connected with the Fax, unplug any other phone from that line.
Call that number and see whether it rings or you get a fax tone.
Sep 13, 2008 | Office Equipment & Supplies
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
Is it possible to use Voip without a direct Internet connection?? For example I use wireless Internet from my neighbors connection.
LOL!! I know with Vonage you need a hard line cat 5. With the usb things like magic jack, since that directly plugs into your computer, my assumption is it wouldn't matter whether you were wireless or not.
Aug 21, 2009 | Linksys VoIP Telephone
Clearwire VOIP ph adapter + Can only connect 1 phone downstairs
http://www.allnet-italia.it/img/speciali/pdf/777702433.pdf
if you need more call me at 804-372-RROD
May 03, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
How would fax run on VOIP? what requirment it needs?
typically faxing doesn't work on VOIP. i tried many times and sometimes it would go through although it said it didn't. other times it didn't work at all. VOIP has a limited bandwidth and the fax needs to send more info over the line than VOIP makes room for.
to have the best luck, stop all downloads and other network traffic while attempting to fax, so that there are no other programs or devices using the internet. the fax will have its best chance of working that way, although it probably still won't
here are some very good tips as well:
http://chris.pirillo.com/how-to-fax-over-voip-on-the-internet/
Feb 18, 2009 | Lexmark X4270 All-In-One InkJet Printer
Connect fax from 6210 to phone via cable modem (VoIP)
In Order to use a Fax functionality of the router you need to connect the small RJ11 cable for telephones on the printer port. These printers do not suppoer VOIP Fax. To use VOIP as fax you can purchase a online VOIP subscription where you can scan and fax the documents.
Feb 04, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Voip phone is workin properly but when i try to send fax it shows comm error
Make sure the same dial tone you can talk on is plugged into your fax machine. Try plugging a plain old telephone into the wall jack your fax is plugged into. Until you hear dialtone in that jack, don't bother troubleshooting the fax any more.
Dec 17, 2008 | Computers & Internet
Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer Logo
69 people viewed this question
old marine
old marine
