Question about Fishman SA220 Solo Performance System Speaker PA Active
Is it okay to (carefully) use a powered mixer as an input to the Fishman SA200? The objective is to have four inputs rather than just two.
3 Suggested Answers
  • 34 Answers
SOURCE: My Fishman Loudbox 100 bass speaker buzzes- what
It is a poor ground but it is not necessarily in your amp.
If it is only buzzing when you have a guitar or other piece of equipment connected try a new lead cable.
If it buzzes all of the time......remove the cover at the rear of the amp and remove control panel.
Inspect the feed line to the input. If it is loose or broken....repair or take to have repaired.
Posted on Oct 12, 2009
  • 5603 Answers
SOURCE: Low volume from Fishman Loudbox
I have seen defective XLR cables so check it with an ohmmeter. It is possible the mic input preamp has been damaged. If that is the case, the unit will have to be repaired.
Posted on Aug 31, 2011
I want to use theMackie as a sub mixer into a powered "all in one" Peavy mixer, where do I come out of the Mackie into one of my powered mixer line inputs?
Take the main outputs into a stereo input (or a pair of mono inputs) on the Peavey - without knowing which Peavey I cannot tell you further info re set-up but as you'll be sending line level signal you'll need to back off the gain on the channels you input to on the Peavey
Nov 17, 2016 | Mackie Music
What do you hook up first, mixer or power amp oreffects in a rack system?
Effects plug into mixer, mixer plugs into power amp. Others may want the mixer and the effects plugged into the power amp for the most available inputs. (when multiple inputs are available.)
Effects and mixer are a line level output and the mixer can be considered a line level input as well. A mic mixer has gain amplifiers for the inputs that are below line level such as unamplied microphones. It is possible to parse to absurdity, but the gist of it is above assuming you do not want to apply the same effects to everything all at once.
Feb 06, 2012 | Soundcraft Efx12 12-channel Mixer With...
What's your problem?I have two Fishman amps.The older Loudbox 100 single channel and a Loudbox mini. I am trying to find the service manual for the older fishman as I have a fault with it and the
Fishman iis you best bet http://www.fishman.com
You can download the user manuals, they do have a block diagram, but the scan is pretty bad.
It may end up the person looking at it is going to need to rely upon their general knowledge.
My own suggestion is to pull the chassis out so you can work on it while powering it. And then work your way through the amp with either a signal source plugged in at the input, and with high impedance headphones with test lead ends, go through each audio stage carefully. until the fault is isolated. If it is not caps or the rectifiers in the power supply, faulty ground connections to chassis or faceplate, a faulty 4558 is most probable. The headphone approach is the fastest way to address this last one. If a different series of preamp chip is used, a good source for the IC datasheets in general is Digikey http://www.digikey.com and parts too.
Feb 05, 2012 | Fishman Loudbox 100 Acoustic Guitar...
Low volume from Fishman Loudbox Mini mic input, using brand new XLR cable and dynamic mic. Mic works just fine on instrument input using a Hi-Z cable so problem is not mik
Aug 31, 2011 | Fishman Loudbox Mini Acoustic Amplifier...
My band plugs into the input channels on the SX2442FX mixer, which we then hook up to the PMP2000 to use as a PA. Since the SX2442FX is not a "Powered" Mixer, I figured that we should be going...
Either way will work, however your friend's method probably would be slightly better since it goes through less stages within the PMP2000. The "left and right power amp inputs" are the INPUTS to the power amp in the PMP2000 and hence are the best places to connect the mixer if using the PMP2000 as only a power amp. Note doing this will LIKELY disconnect any other input to the PMP2000 from the power amps in it... that is all the preamps in the PMP2000. DO USE TRS cables!!! and power both units from the same receptacle to avoid ground bounce.
Aug 25, 2011 | Behringer Sx2442fx Eurodesk 24channel...
I have a mackie fx 8 mixer connected to two thump 15 " speakers. i want to add a set of base non- powered speakers with power amp to my fx 8. what are the connections?
Balanced audio interconnects (either XLR or TRS cables from the mixer and then balanced audio interconnects from the amp daisy chain inputs to the existing speaker inputs. If the amps do not have linked input jacks, then use TRS type WYE connectors at the inputs. Then use speaker rated cables from the amps to the passive speakers.
Aug 12, 2011 | Mackie ProFX8 Professional Compact Mixer
I bought a second hand Fishman LoudBox Performer. The problem is that the Aux-in for the headphone doesn't work. So sick... What can I do? tnx
I don't understand your question. The "Aux in" is just that an input that goes to the power amp. Please note that the Fishman Loudbox does NOT have a headphone jack so don't be disappointed as there plain isn't a headphone jack on this unit. I would recommend that you get a small headphone amplifier for the purpose... or even go to a thrift store and get an old stereo system that has a headphone jack and use that.
Aug 01, 2011 | Fishman Loudbox Performer Amp Acoustic
Xenyx 1002fx Mixer 10 Input 2 Bus with Efx: behringer mixer power goes off after running about...
Problem is likely thermal. Open unit carefully and use freeze mist (circuit cooler) to find bad component.
With that long a time period, it is possibly a component mounted on a heatsink.
May 18, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Iam trying to make my behringerXENYX 1204fx mixer, / connect
I have trouble my new behringer xenyx 1204FX VU led dead , like new VU it must play , how to repair this unit VU light
Mar 13, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
The reverb (or any effect) on my Fishman Loudbox 100 has become unreliable. It goes in and out randomly.
If you have a pedal input, you may be getting FALSE trips of this.
You may have a pedal jack with switch that is marginal.
TRY putting a pedal into the effect pedal input IF your unit has that and SEE if it acts stable.
These jack and jack switch problems are a pain on all these amps... any brand.
Jan 27, 2010 | Fishman Loudbox 100
Fishman SA220 Solo Performance System Speaker PA Active Logo
87 people viewed this question
Top Fishman Music Experts
Matthew Spark
Matthew Spark
Norma Garcia
Norma Garcia
Are you a Fishman Music Expert? Answer questions, earn points and help others
