Question about Cybex International Exercise & Fitness
When someone is running on the treadmill it loses power and i have to hit the fuse reset buttons
    Problem Solver:
  • 50 Answers
Sounds like your motor is on its way out but first check the control module fans are not plugged and causing over heating. These are located under the hood usually a large black or grey box.
Posted on Jun 26, 2014
3 Suggested Answers
  • 42 Answers
SOURCE: treadmill not starting evan after we hit reset
hi, disconnect the plug from the wall, remove the saftey key, check if the on/off switch is on off and the circuit breaker is on off.
also very important if you are using an extension wire make sure all of the wire is out. wait 5 mins!
now switch the power button onto the on position.
do the same with the circuit breaker, switch it to the on position.
plug in the power cord and switch on. now reinsert the key hopefully this should have started your treadmill.
also make sure you give it aleast 5 mins when you have the wall unpluged!
Posted on Nov 11, 2010
  • 1196 Answers
SOURCE: I have a U.N.O treadmill
All powered treadmills have a breaker. The purpose of the breaker is to prevent a power surge that might damage the treadmill motor. Check the circuit breaker on the frame near the power cord. If the reset/off circuit breaker has tripped, wait 5 minutes and then reset the breaker by pressing the switch in. That should fix the problem.
Posted on May 11, 2011
Weslo Cadence 340 power shut down while i was on it, tried the reset button and it actually fell inside, i took the front off and the reset button wont budge. Put the key in and I do have power, just...
If it doesn't have a fuse Only the reset button that is your over current protection, if it's broke the treadmill won't work tell it's repaired. ... hope this helps ?
Feb 24, 2015 | Weslo Cadence Treadmill 340CS
Treadmill starts then as the belt first begins to roll the it shuts down again right away
Mybe the belt is to lose see if you can ajust the tension of the Belt also to ake sure that it runs straight.
Jan 09, 2015 | Nordic Track Nordictrack C2100 Treadmill...
I plug my healthriderpro H 450i into a outlet that had no ground.It work for a little bit but turn off and nothing happens when I hit the reset button.What could be the problem?
The ground on the outlet is only for safety reasons. It will not affect the operation of the machine. Check for a fuse on the control board.
Nov 19, 2014 | HEALTHRIDER Pro H450i Treadmill HRTL61706
My spirit sr275 treadmill will not turn on after losing power.
check the over load reset button ,motor,switch etc.
Aug 09, 2014 | Spirit Exercise & Fitness
Treadmill loses power all the time
see the video and fix it. +LUBE the rollers bearing front and back,+test the drive belt motor too.and replace if necessary.
God bless you
Jul 03, 2013 | Epic Overstock T60 Treadmill Treadmills
Track 5500
Go run in the park, much softer landing if you fall again, no cost involved. Use the treadmill as a clothes hanger.
Oct 08, 2012 | Treadmill Doctor Exercise & Fitness
My horizon t202 treadmill wont start i cant even located the on/off switch where is that? I see the reset button
Normally the button and reset is in FRONT from the machine is you stand from the machine in the lower part, Is RED and at the side is reset button.
2) Test the fuse inside see the block diagram , test and replace.
3) Test the power cord for open, break
4) test the outlet wall, reset the breaker from you house, DO not use any extension cord. and proof again.
5) If you can NOT resolve the problem, you must call to the service tech,.maybe you have problem with some component, inside capacitor, transformer in the power supply.
God bless you
Sep 03, 2012 | Horizon T202 Treadmill
Treadmill Problem
I believe that your must LUBE the deck belt firt, this happen when the lack of maintenance, shut down. Can be the deck worn.
2) LUBE the rollers bearing.
3) if the problem persist you must to test: input voltage motor, if there are the motor need REPAIR.
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block.
However you must RUN the software calibration for diagnose, troubleshooting.
God bless you
Jul 25, 2012 | Exercise & Fitness
My reebok run won't work although the power is on
Dear Sir:
1) Reset the c. breaker from your outlet home.see if some wire is loose.
2) Do not use extension cord, the drop of voltage is not O.K for to keep running the treadmill.
3) Reset your c.breaker or fuse from your treadmill, is to the side of power button.
4) See internal some wires is loose.
5) Test the input voltage for 115 vac with a VOM., IF THERE ARE MISSING, you have problem with the c.breaker or transformer.
see the block diagram for illustration. sincerely. God bless you.
ernesto cuadra
managua, nicaragua.c.a
Feb 11, 2012 | Reebok Exercise & Fitness
Exercise & Fitness Logo
Top Cybex International Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Cybex International Exercise and Fitnes Expert? Answer questions, earn points and help others
