W6011 asko front loading washing machine. Wont start. It stopped in the middle of a program. I have done all the usual things like clear the neddle trap, checked the hoses etc. Only way to open the door is by the red puller. there is power to the machine but nothing else works.
  • char9596 May 20, 2011
    Thanks Daniel, will try that.
    Carol
  • 4,323 Answers
Hi
As you have already cleaned the drain hose then check/test the door lock-switch assembly. If that is fine then the issue is with the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on May 20, 2011
  • Daniel Scott
    Daniel Scott May 20, 2011
    Alright Carol....post back for further assistance.
My Asko washing machine wont go into spin cycle it just keeps on washing after 3 hours I had to turn it off now what
call a technician in
the problem is most likely in the program board not progressing the wash cycle
Jul 12, 2016 | Asko W6021 Front Load Washer
Asko 6221 washer. push start button and here the click but the washer does not fill. Cleaned coin trap and cleared a dime from one of the lines
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 13, 2011 | Asko W6221 Front Load Washer
Asko WCAM1812 Front Load All-in-One Washer / Dryer It does not start the lights are blinking on spin. the door remains unlocked
hold down the "cycle signal" button for 3-5 sec. unplug and plug back in. should clear and reset computer
Aug 08, 2009 | Asko WCAM1812 Front Load Washer / Dryer
Machine wont stop filling with water, it just overflows. Machine is an Asko w6551 front loader
Same thing happened to my ASKO W600.  Sounds like the water inlet valve is blocked or broken so therefore can't stop the flow of water coming into machine.  Check it out and replace if necessary.
Oct 30, 2008 | Asko Washing Machines
Asko 10505 runs through was cycle in approx. 30 seconds, then wont drain. Simply stops. It doesnt matter which cycle I start with, the dial moves quickly to stop. It fill with water and spins. ANY HELP...
hi sir' start the wash machine empty and see if it happens when nothing is in it.
2. When machine is off, open the top grab the centerpiece inside the wash machine and pull and push it slowly, does it move? (For safety unplug the machine)
3. Make sure machine is 100% level (front to back, left to right)
The most common thing is bad drum bearing, which force the wash machine out of whack when in spin / wash. Which are common and the best thing is to call Maytag.
thank u .........................................please rate
__________________
Sep 11, 2008 | Asko Washing Machines
ASKO w6011 FRONT LOADER
Try to Open the safety compartment using a screwdriver under the wash machine in the front.
Then open the big white knodb this will cause the wate to drain out which is fine.
Then clean this out. Usually you will find coins and stuff here from years of operations from pockets. clear these out and your problem maybe fixed. worked for us
Jun 09, 2008 | Asko W6021 Front Load Washer
Asko w6221 washer
Try to replace the motor brushes. This is the most usual problem on these machines.
Good Luck
Nov 21, 2007 | Asko W6221 Front Load Washer
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
