Question about Bosch Saws
CHANGE BROKEN BLADE ON BOSCH GST 97 - Bosch Saws
3 Suggested Answers
comax
  • 154 Answers
SOURCE: what is the process
There is a lever on the handle, you have to pull it up and rotate it counter clockwise about 3 times (shouldn't take any more than that. The blade will be loose now,put in the new blade and turn the back lever clockwise until it clicks. The blade should be tight,push the lever down and move it into the slot in the handle.
I hope this helps
Posted on Apr 14, 2009
SOURCE: Changing the blade on my Bosch GST 2000
lift knob on top twist 3 times anti clockwise remove blade by twisting it 90 deg insert new blade turn 90 deg,turn knob on top clockwise until it clicks press down and you are ready to go
Posted on Jul 01, 2010
How change blade on bosch gst 60 pb
the holder is a twist lock just turn it counter clockwise and pull blade out .
Feb 14, 2016 | Bosch Saws
How do i remove a broken blade in the bosch rs 325
Open the chuck and try gripping the bit of broken blade with some tweezers or flick it out with a small screwdriver.
Nov 30, 2012 | Bosch RS325 Compact Demolition...
Bosch b4300 jigsaw blade replacement
To change the Bosch B4300 blade - If the grey knob does not turn to release the broken blade, you need to use a LONG THIN flathead screwdriver down the center hole at the top. Unscrew until the broken blade is loose. Pull out. Replace the new blade and then screw the it tight through the same hole at the top. DONE.
Jan 25, 2012 | Bosch 1581AVSK Top Handle Jig Saw Kit
How do i get the blade out of my gst 2000
pull up knob on top at front turn anti clockwise three times turn blade 90 deg remove blade insert new blade turn 90 deg turn knob on top clock wise untill clicks press knob back down you are ready to go
Jun 04, 2010 | Bosch Saws
ON MY 97 ECLIPSE GST WON'T
Is there oil in the turbo?
Feb 26, 2010 | 1997 Mitsubishi Eclipse
May 16, 2009 | Bosch #T101A3 3PK 4" 14TPI Jig Blade
Milwaukee jigsaw with blade change problem
a new tool will cost you about 170. You could look for a used on on craigslist.
Apr 21, 2009 | Milwaukee Tool Milwaukee Orbital Jig Saw...
What is the process to change a saw blade on Bosch GST 2000 jig saw SDS system
I hope this helps
Apr 06, 2009 | Bosch Saws
Blade Change for Bosch 1581
the screw is a flat head but you need a long series screwdriver you have to loosen the screw first then turn the blade sideways remove then place new blade in sideways turn to straight then tighten screw again its not too hard at all best of luck glenn.......
Nov 11, 2008 | Saws
How to change blade on bosch jigsaw GST 80 PBE
I just bought a used one and faced the same problem. What I found in there is a set screw at the bottom of the long shaft. I used a long narrow flat head screw driver. It worked good, but I did have to acuate the trigger to get it the blade near the top of the stroke
Hope that helps.
AG
Porsgrunn Norway
Dec 07, 2007 | Coffee Makers & Espresso Machines
Saws Logo
338 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
