Question about Casio WK110 Portable Keyboard
Sustain pedal doesn't work any more - maybe it isn't the fault of the pedal? I don't want to order a new one if the problem is in the keyboard. I'm sorry, I just lent it to summer guests and don't have any info on the pedal - or whether other sustain pedals also won't work with this Casio WK-1300.
    Sergeant:
  • 357 Answers
Take it into a music store and try a pedal there in store. If it works, buy the new pedal and charge the guests. If it does not work, you know it's th TS input on the keyboard
Posted on Nov 01, 2011
How do i lubicant my reebok b5.8e bike
Well I'm not familiar with Reebok exercise bikes specifically, but I am familiar with bike pedals in general. It looks like these are rather cheap plastic pedals that are sealed (no real way to take them apart and lubricate them). I suggest you try using some kind of household oil, 3 in1 etc. or maybe WD-40.and spray on the inside side of the pedal. If you take them off the machine, it might be easier to see where to spray or drop oil in the best area. If you do decide to take them off, the left hand pedal is reverse threaded (to unscrew the left pedal you must turn the axle of the pedal that unscrews clockwise to remove). The right pedal is regular thread (counter clockwise to remove). Depending on how much space is between the crank and the pedal body, you might have to get a special bicycle pedal wrench available from a good bicycle shop (Park tools are the best). The special wrench is very thin to be able to get between the crank and the pedal body which is usually very narrow between the pedal and the crank. If this doesn't work, I'm afraid you probably going to have to buy new ones in order to get rid of the squeak. If you don't mind doing away with the pedal straps, you could get cheap pedals at a bicycle shop. If you do choose to go this route take the pedal with you. There are two different pedal axle diameters: 1/2" and 9/16". The 1/2" isn't very common anymore, so it will probably be 9/16". The pedals usually marked L and R on the ends of the axel. If French it's D for right and G for left. If not, you will just have to try them to see which pedal is left and right by trying each one (remember preceding instructions). Good luck!
Aug 08, 2012 | Sport & Outdoor - Others
Foot pedal doesn't work
well if the foot pedal isn't working, you can either replace it with a new one or take the machine to a sewing machine repair shop & let them check the foot pedal & see if it's fixable
Mar 14, 2012 | Husqvarna Sewing Machines
I have a roland e09, and it can't be sustained,
I assume you are using ROLAND pedals... they are BACKWARDS to most other pedals you can buy regarding the on-off sense. If yours are NOT Roland pedals, you MIGHT be able to open them and rewire... not all can be rewired, but some can be rewired to reverse the switch direction.
Sep 01, 2011 | Music
I Have a Casio Privia Digital Piano and a Roland DP-10 pedal. The pedal function is inverted. When I press it stops the sustain and the effect comes back when I release the pedal. The pedal does not have...
Yep... Roland pedals are reversed, that is, normally closed contacts. Unlike some Yamaha keyboards, the Casio doesn't have an inversion function available. You have two choices to solve this: 1. Buy a pedal with the corect sense 2. Open the Roland pedal and MAYBE with a soldering iron you can move a wire to select a contact with the opposite sense.
Aug 05, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
The ASUS sdre-08d1s-u is not burning cds. Common problems? fixes?
I have the exact same unit, and after about 100 burns the little guy gave out on me. If it isn't burning, I would recommend going into your device manager on your computer and checking to see if your USB hub is functioning properly. In that doesn't work, or you don't find any issues, try plugging it into a different machine to check and see if your computer is the one at fault. Often, the motor itself is the damaged unit, rather than the internal workings, so the computer says it's working fine, and lo and behold, the drive won't work. If that doesn't work out for you, then unfortunately it sounds like you're out of luck, and it would be cheaper to just purchase a new one.
Jul 22, 2011 | ASUS SDRW-08D1S-U USB 2.0 Slim External...
My tv control doesn't work and i put new battery's in and that didn't work either
There's a quick test you can do to test the functionality of the remote to make sure it isn't the TV's IR sensor that's broken. To perform the test all you need is the remote and a digital camera (cell phone cam works too). Take the remote and look at the IR "eye" through the camera's screen. Don't actually take a picture simply use the camera as you would a magnifying glass. While looking at the IR eye press a few buttons on the remote. If the remote is working you should see light coming out of the remote. Our eyes cant see the IR light but the camera can. If the remote doesn't light up then the remote is at fault. You can replace your remote on many websites for somewhere in the 20 - 50 dollar range.
http://www.replacementremotes.com/
Here for example, you need to input your TV model number and it will tell you what remote you need with pictures. Then, once you are sure that is the remote you want, you can order right from the same website.
Hope that helps!
Jul 19, 2011 | Televison & Video
When I plug the fc-5 pedal into a P95 piano, sustain in ON (either I press the foot switch or not) and when I unplug it, sustain goes off, and sometimes it is vice versa, pressing the switch doesn't...
Sounds like a loose wire to me (because the problem isn't consistent) the most likely suspect is the jack plug. Unscrew the body of the plug and check that the two wires are firmly soldered to the terminals inside.
If they're OK you can pop the cover off the footswitch and check that end. As far as I recall that end of the cable goes straight to a PCB (printed circuit board) so be very careful if you need to solder anything. If the solder around the wire connection is cracked, that's a dry joint and can be fixed with a small blob of solder carefully applied.
If all the cable connections are fine there's a problem with the PCB or the micro-switch mounted on it.
Jun 20, 2011 | Yamaha Fc5 Sustain Footswitch
Hi, i have a problem with my casio wk 210 keyboard. when i push a key then the note keeps playing and doesn't stop. i have tried turning off the power and turning off reverb and none of them fix the...
It sounds like the sustain is stuck on as if a sustain pedal is active. You don't mention if you have one, however if you MIGHT have one and you have used a Roland pedal, that brand is reverse sensed and would cause note to remain on.
Jun 14, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
I have a FDL70S1 dehumidifier that runs and runs but doesn't take out any moisture from the air. I have cleaned out the filter and front screens thoroughly but it still doesn't work. The unit...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 10, 2011 | Frigidaire FDL50R1 Dehumidifier
My pedal is not sustaining - it is plugged in at the pedal outlet, not sure what else to look for?
The first question is has it ever worked? If this is new, the connector of the pedals is a mini DIN type which is REAL hard to get seated properly. Often something blocks it from seating fully. Remove the plug and with a bright light inspect the pins... they are EASILY broken off. Aligning the connector carefully and making sure it seats is important. This piano also has a foot under the pedals to screw down against the floor but that isn't wht cause the pedals to not work.
Apr 18, 2011 | Yamaha YDP223 Digital Piano
Casio WK110 Portable Keyboard Logo
330 people viewed this question
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
