Question about Sharper Image GT907 Shelf System
I need an instruction manual for GT 907 to set it up again. Forgot how to program particular radio stations and it's reception is not good at all. I've had it for many years and just moved. Thanks in advance for your help!
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
How to program the radio in a 96Lincoln continental after battery was disconnected
Here is the link to the owners manual which you can download if you wish:
http://owner.ford.com/servlet/ContentServer?pagename=Owner/Page/OwnerGuidePage&year=1996&make=Lincoln&model=Continental
Here/below are the specific instructions on the radio programming (pg. 159 of above link).
Good luck & please flag if "HELPFUL". Thanks!
(from section) Luxury Audio System
Selecting the AM or FM frequency band
Push the "AM" or "FM1/FM2" button to select the desired frequency band. Pushing the "FM1/FM2" button more than once will alternate between FM1 and FM2. These functions are used with the station memory buttons described under How to tune radio stations.
HOW to tune radio stations
There are four ways for you to tune in a particular station. You can use the "TUNE", "SEEK", 'SCAN"or memory buttons.
• Using the "TUNE" function:
You can change the frequency up or down one increment at a time by Pressing and releasing either the left (< arrow/up) or - right (> arrow/down) side of the "TUNE" or "TUNE DISCS" button. To change frequencies quickly, press and hold down either the right or left side of the button.
Manual tuning adjusts your radio to any allowable broadcast frequency, whether or not a station is present on that frequency. (See All About Radio Frequencies in this section.)
• Using the "SEEK" function
: Press the right *) side of the "SEEK" button to select the next listenable station up the frequency band. Press the left (.4) side of the button to select the next listenable station down the frequency band. By holding the button down, listenable stations can be passed over to reach the desired station. Pressing the "SCAN" button will begin the scan mode up the frequency band, stopping on each listenable station for approximately five seconds. To stop the scan mode on the presently sampled station, press the "SCAN" button again.
Setting the station MEMORY PRESET buttons
: Your radio is equipped with 6 station memory buttons. These buttons can be used to select up to 6 preset AM stations and 12 FM stations (6 in FMI and 6 in FM2)
1. Select a band, then select a frequency.
2. Press one of the memory buttons and hold until the sound returns and the lamp above the memory button lights up. That
memory button is now set.
3. Follow the above steps for each memory preset button.
NOTE:
Custom memory presets can be recalled using the keyless entry system. See Memory Profile System in the Features chapter.
Using the Automatic Memory Store feature ("AUTOSET")
: If the memory buttons have been set, either by using the Auto Memory Load feature or if you have set them manually, the system is prepared tolet you use a convenient feature called Automatic Memory Store.
With Auto Memory Store, you can continually set strong stations into your memory buttons without losing your originally set stations. Your radio will automatically set your memory buttons to the strong local stations.
Activate Auto Memory Store by pushing the "AUTOSET" button once. Your radio will set the first six strong stations of the band you are in (AM, FMI or FM2) into the memory buttons. The display will flash "AUTO" and display the autoset icon "A" while the stations are being set in the memory buttons.
NOTE: If there are less than six strong stations in the frequency band, the remaining unfilled buttons will store the last strong station detected on the band. After all stations have been filled, the radio will begin playing the station stored on memory button 1.
To deactivate the Auto Memory Store mode and return to the manually-set memory button stations, simply push the "AUTOSET" button. Display will show "AUTO" then "OFF". The next time Auto Memory Store is activated on that band, the radio will store the next set of six strong stations.
Nov 23, 2014 | 1996 Lincoln Continental
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
I can't work out how to listen to radio stations on my Toshiba 40bv700b
It is not usually done.
Who said you could do this?
Is it shown in your owner's manual?
To listen to radio stations on any receiver, you need an
appropriate antenna. Most TVs do not have antennas
suitable for ordinary radio reception.
Check your owner's manual.
Check with your knowledgeable friends.
You may have been given the wrong impression about
this TV receiver.
Aug 29, 2011 | Toshiba Televison & Video
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
How to change the time on the Timex auto set clock radio.. the DST hasn't switched back to EST.
Timex T309TT Clock Radio.
Setting the time:
Unlike another review that says it automatically sets the time, I did not find that to be the case, I believe the model with the cd player does that, but this one had to be set. I'm not one to usually read the manual as I like to figure things out on my own, and was able to set the time without the use of it. It was as simple as holding the time set button and using the reverse and forward buttons to advance the time. Unlike some clocks, you do not have the option to change just the hour or just the minutes, you have to forward or reverse through all the hours/minutes.
Calendar:
The alarm can be set to go off 7 days a week, 5 days (Monday-Friday), or 2 days (Saturday & Sunday). Again, easy to do with pushing the date button and using the forward and reverse buttons to scroll through the dates.
Adjustable display: There are 3 levels of lighted display, pressing the snooze/dimmer button allows you to change between the three. Nice touch!
Radio Operation:
After pressing the Radio on the display will show the word "on" before returning to the clock display. The bottom display shows the radio frequency.
There are 18 programmable radio station settings with the buttons to access them right on the front of the clock labeled 1-6. Programming is easy with just finding a station you like and pressing and holding one of the preset buttons until it beeps to confirm it was accepted.
I find the radio to get fairly good reception and for the times it doesn't , after moving the attached wire antennae it would pick up a better reception.
So far my experience with the sound quality has been good.
The radio also has a last station memory, so after being turned off and then back on, will recall the last station you were listening too.
Alarm:
Setting the alarm is fairly simple. To set , simply press the alarm button until the time on the screen starts to flash. Then you can click the button to choose through 3 settings which are every day, weekends, or Mon-Fri. This radio also comes with nature sounds. I have not used this feature at this time. You have the choice of
* Ocean surf
* Forest spring
* Rushing brook
* Summer wind
Hope this helps :)
May 03, 2011 | Timex T309TT Clock Radio
I have a 1970's Sony AM Receiver ICR-9. Reception is poor and sounds almost like it is receiving on another band. It has been a great radio and would like to retain. Bill
Do you use an indoor antenna ? Nowadays, with all gear around, like micro-waves receptors, strong motors, satellites, etc., reception becomes quite poor, unless you use an external antenna, properly set to catch broadcast stations. FM reception particularly has its signal much improved in that way. Correct demodulation requires a good an somewhat large outdoor antenna. Hope I could help. Good Luck.
Flavio/Brazil
Jul 13, 2010 | Sony Audio Players & Recorders
How do I change the radio station on the radio alarm
Here is the full manual
http://www.timexaudio.com/pdf/T311IB57574_35.pdf
Here are the instructions from the manual.
Setting the Radio Alarm
1. Press and hold the
Radio Alarm Button. The display will flash and the Radio Alarm Indicator will
appear. If you do not begin setting the time within ten seconds of pressing the button, the display will stop
flashing and you will need to press the
Radio Alarm Button again.
2. While the display flashes, press the Reverse and  Forward Buttons to set the wake time. Hold a button
for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, you will need to select the station. First, press the  Radio Band Button
to select a radio frequency. Next, select a station using the Memory Set 1-6 Buttons. For more
information on programming radio stations into memory, see the Programming Radio Station Settings section
of this manual. Rotate the  Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting
lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that
the correct date is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual.
While the display is still flashing, press the  Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the  Enter Button. The
Radio Alarm Indicator will appear on the display, showing that the radio alarm has been set.
Aug 08, 2009 | Timex T311T Clock Radio
Need instlation insructions
Here's the installation and operation/programming instructions for your lock set.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Weiser and Kwik set both sold and marketed the same lock under their own brand names, as Weiser was the manufacturer, these instructions apply for your lock set.
Hope you find this Very Helpful and best regards!
Jul 30, 2009 | Kwikset 907 907-15 Satin Nickel Smart...
Sharper Image GT907 Shelf System Logo
66 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
woodzowl307
Tom Chichester
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
