I have just purchased a 2493HM monitor. When I press the menu,audio etc on the bottom of the monitor the curser is behind the options and also are these supposed to lit up as they are just about impossible to see on the bottom of the monitor. Adjustment is impossible. Hope you can help me with this.
  • 6,487 Answers
The monitor is simply bad and better have it replace since its new..
Good luck........
Posted on Aug 15, 2008
    Champion:
  • 232 Answers
Return your monitor to where u brought it for exchane or repair, monitors either work or they don't
    Master:
  • 521 Answers
The internal system is faulty.
  • 1 more comment
  • tech expert12 Aug 15, 2008
    if you have pressed it tightly and damaged then you have to get it repaired by calling a technician . he will adjust the system manually for you.that will be under his service charge,not too costly.
    if it was from first only and not any physical damage return the monitor to the dealer/company .and get it replaced.
    as it is new it will be under warranty.very rarely this problem occurs of defective system, do not worry the company always supports their custmers.they will help you further. best of luck.thanks
Hello, I have a Samsung 2493hm monitor, earlier this week I turned on my computer to see nothing. My screen remained black. The power button stays on and it never cuts off, so i'm thinking it's a...
With my Samsung 2493hn, I used HDMI. Use auto detect, on front next to secondary power. Not the main power switch on back of unit. Windows 10, click notification button lower right on Taskbar. Click on Project, then choose which option.
If when you power on Monitor without white squares with HDMI, ANALOG, DIGITAL printed in each then yes sounds like back light.
Aug 02, 2017 | Samsung SyncMaster 2493HM Monitor
I don't know how to turn down the brightness and contrast on the Acer monitor I recently purchased (Acer G205HL LCD Monitor). I tried the instructions and brought up the menu to make a selection by...
When you press menu on the monitor it will bring up the brightness & contrast, along with several other options. Navigate using the Up and Down keys on the monitor. Press menu on the monitor again to access the specific option you want to change and use the up and down keys on the monitor to change the option.
Jul 16, 2011 | Acer Computers & Internet
Our samsung syncmaster 2493hm fades to black when on websites with dark color backgrounds. How Come? Is there a fix?
Its probibly the MagicBright settings, press the button next to the menu button (its down arrow) and change the settings to something else, i changed mine from "Dynamic Contrast" to "Game" and everything is as they should be now.
Jul 13, 2011 | Samsung SyncMaster 2493HM Monitor
Samsung monitor 2493HM wont power up I plugged it it and the blue light came on for about 5 seconds then went out and I havent been able to get it going again.
The Samsung 2493HM monitor are known to have an issue with the power supply. When the power supply fails you get the 'no power' or 'slow to show picture' problems like you are having. The board can be repaired and the monitor will be just like new again. This is what the power supply board looks like:
Here is a link to a free repair guide that will walk you through the repair.
http://www.ccl-la.com/blog/index.php/reparing-a-samsung-2493hm-24-lcd-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Jul 02, 2011 | Samsung SyncMaster 2493HM Monitor
I was cleaning the bottom of the screen and hit the color. Now it is blue and very hard to look at. I am at work, so I need this fixed
There should be a button that pulls up a menu to adjust color/contrast/ bright, etc. Press it and go through the menu options by either repeatedly pressing the menu button, or by using up-down-right left arrows. Adjust your colors using these options, or if available, try "auto" adjust.
I don't know this particular monitor, and am no "expert", but these options should be available on virtually any LCD monitor. A final option, if adjusting these does not help, look at all the menu - settings. If you see "recall" or "restore" or "default" anywhere, try selecting that option.
Good luck
Dec 08, 2010 | 3G Technology 726A (Black, Silver) 17 in....
My Samsung SyncMaster 2493HM Monitor has trouble starting. When my monitor has been off for a while and I restart it. It makes a little beeping sound and the little light on the right bottom of the screen...
The Samsung 2493HM monitors have an issue with power supply failure. When the board starts failing can be slow to show a picture, have no power at all or have a way or flashing picture. Your monitor sounds like it falls in the slow start category. The power supply board can be easily repaired and the monitor will be just as good as new. Here is a link to a free repair guide that will provide a step by step instructions showing you how to disassemble the unit, check and repair the power board.
BuddyMc
Apr 13, 2010 | Samsung SyncMaster 2493HM Monitor
No picture; no operation except flashing blue lcd light.
Look at the power supply first, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 30, 2009 | Samsung SyncMaster 2493HM Monitor
CANNOT REMOVE THE OSD MAIN MENU FROM MONITOR SCREEN
The problem of OSD Menus popping up automatically are usually caused due to a faulty switch in the Menu button which is getting switched on automatically.
This menu will not harm the computer but constant OSD menu will most probably lead to permanent damage to the pixels in the LCD screen plus it is a constant irritation to your eyes which are most precious.
This problem can be rectified by replacing the faulty menu switch. Hope this solves your problem Thanks.
Jul 23, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Computers & Internet Logo
David Payne
David Payne
