Question about Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho
I have an ML200RT time box with a lid. Where can I get a replacement to protect it from weather?
    Problem Solver:
  • 18 Answers
I would suggest possibly contacting the manufacturer directly, not sure of anyone else that would have a specific part like that. That is not saying that there may be someone that does. You could maybe contact some landscapers that may have something like that laying around. Other than that you can always try to fabricate something yourself.
Posted on May 20, 2011
When I turn my dvd player on, the volume will lower on its own to almost mute. It is hit or miss weather or not the unit will turn off on its own saying protect. All connections are good. Inside is clean....
When you've got good volume, try unplugging the speakers (only for a very short time) to see if that whining noise is still there or if it's stopped. We're trying to see if the whining is related to the low volume and "protect" or if it's only coincidental.
Try unplugging all the cables (except the power cord). Turn the player on & off several times & see if that whining noise acts the same. Also see if the player goes into "protect". What we're trying to do here is see if it NEVER goes into "protect" with the cables unplugged.
Last... try to get it to start & run without going into "protect", with all the cables unplugged (except power). Plug the cables in, one at a time, and see if plugging one of the cables in forces it into "protect". If so, there's something wrong with that cable or whatever's on the other end of that cable. Unplug it again & restart the player - no "protect"? Wait a little while, plug the cable in. "Protect"? Check the other end of that cable.
If it goes into "protect" with nothing plugged in except the power, then the player is probably a write-off, ready to be replaced (it's not very often that DVD players are worth repairing these days).
Nov 05, 2013 | Samsung HT-Z310T Theater System
Cigarette lighter does not work
The cigarette lghter is protected by Fuse #51 (15 Amp) in the underhood fuse and fusible link box. The diagram on the lid to the box clearly shows this fuse as "CIGAR". (unless the label on the inside of the lid is missing.)
This information is also covered in your owner's manual.
Apr 08, 2012 | 1999 Infiniti.5 QX4
I have a malibu ml200rt that won't work can I replace with malibu ml 300 rtw. Thanks
Yes, you can replace the ML200RT with the ML300TW without a problem, and you will have an extra 100 watts for more lights if you want.
Nov 29, 2010 | Malibu ML300RTW - Low Voltage Power Pack...
Can I buy timer time (off/on) PINS for the Malibu ML200RT timer?
I suspect the Malibu tripper wears out since they're made of plastic.
But I can't find replacements.
I searched the web for replacement Malibu trippers, but found none.
Malibulights.com does not show any replacement parts for Power Packs or timers on any page.
I bought a new 200W power pack from Home Deport last week, thinking there might be some information with the product. The new power pack no longer has the dial. It has a digital control where you push buttons.
Oct 23, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Having trouble setting timer o ML200RT
Set on-off times by setting trippers
-Insert trippers
-Red tripper is ON
-Black tripper is OFF
-New timer has 2 sets of trippers
Set time
-Plug-in & turn-on power pack
Turn dial clockwise to set time of day
Manual override:
Turn manual-on-off switch counterclockwise
Troubleshoot:
-Power pack not turned on
-Plug does not have power > try hair dryer in plug to see if it turns on, check GFI breaker in bathroom, replace plug
-Manual-on-off is set to OFF > rotate to ON
-Outdoor lamp burned out > test with another lamp
-Important to replace burned out lamps promptly, or other lamps burn out quickly
-High household voltage will reduce life of timer
-Timer designed to last for many years under normal conditions
Sep 22, 2010 | Malibu ML200RT - Low Voltage Power Pack...
I have a all weather system or a all temperture system. i can not change between heating and air conditioning
On top of the blower box,in,behind the glove box(lay the lid down towards the floor)look to the left,towards the middle of the vehicle,and there is a flat,white,or black rectangle shaped box mounted to the blower box,this is the temp door actuator motor,it has gone bad.
Jun 10, 2010 | 1997 Ford Explorer AWD
Timer running very slow on my malibu ml200rt
You posted under Intermatic-malibu power packs.
There are no replacement clock motors.
Improvise by setting timer to override and plug power pack into cheap plug-in timer.
For information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Apr 03, 2010 | Malibu ML200RT - Low Voltage Power Pack...
How to set timer on malibu box
Also, make sure to set the dial for the correct time of day.
Jul 25, 2009 | Malibu ML200RT - Low Voltage Power Pack...
Malibu ml200rt internal wiring schematics
If you have a meter you can test for 12 volts AC on the output of the transformer. They go to terminals
A & B
Jun 22, 2009 | Malibu ML200RT - Low Voltage Power Pack...
Malibu ML200RT low voltage power pack is not working
First check to make sure that you do not have more watts pulling than is recommended. If this is ok then pull both the red and black plastic pin from the timer and replace them then try. If neither of these solutions work you may have a problem at power source.
May 09, 2009 | Malibu ML200RT - Low Voltage Power Pack...
Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho Logo
26 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
Scott Jelt
Scott Jelt
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
