Question about Dryers
New dryer need to vent it through the wall can it be vented paralellto the floor or take it upthe height of the dryer then out
  • Dryers Master
  • 2,180 Answers
All the dryer does is move air,you can run it up to the roof or down to the cellar and vent it however you want.if it was a washer then the drain hose should be up higher than the water in the washer so i can't siphon back in but you can run the vent line however you need to.
Posted on May 20, 2011
Testimonial: "very helpful"
My samsung dryer turns off after about 4 min
Sis it overheating due to a clogged vent hose? Remove the hose at the wall or floor and at the dryer. Look into it if it's clear and clean hook it back to the dryer only and run the dryer with it just venting into the room (if it's dirty take it outside and use a blower to clean it) if it runs with the wall or floor side unhooked you may have a clog in the wall or floor run (you may not have a long run as I do mine is 30 feet) good luck if this doesn't work check with mfg website for FAQ.
Kevin
Aug 06, 2014 | Dryers
Just got a new tumble dryer with built in vent and hose. Trouble is i have a hose and vent already fitted to outlet (wall) in kitchen what can i do? Will i need to take out the whole fitting in the wall....
Take hose off the vent and then stuff plastic into the vent and take some drywall mud and fill the rest of the vent with mud. Doing that will keep criter out of you home
Jul 21, 2010 | Dryers
How hot is the Vent temp of my new Duet?
It's not the temperature of the air that is the problem. The air is seldom over 160 Deg F. If you have a vent fire the piping needs to last long enough without melting to starve the fire of oxygen in the hopes of extinguishing. Rigid aluminum piping is best suited for this, Rigid flexible is next. The tin foil and white plastic offer little resistance to melting if a fire should begin. The melting would allow the fire to replenish oxygen and support the burning process. The main caution here is to keep your dryer and vent clean...at least annually.
If the duct inside your wall is rigid metal all the way from the dryer to the house exit you need to do nothing to it . Replace the vent between the dryer and the wall with rigid metal 4" piping or hard flexible aluminum piping. If the duct inside your wall is either of the least effective types you need a new run of vent for the dryer to avoid a fire.
You can't use white plastic or flimsy flexible aluminum that feels like aluminum foil when you touch it.
Sep 10, 2009 | Whirlpool Dryers
We built an outdoor room and the dryer vent is now "indoors".
you'll have to go to lowes or home depot and buy the rigid vent pipe not the flex type. Figure up the elbows and straight pcs. Usually vent pipe is 4,6,8 So make sure you get the correct size. Now as far as going through an existing interior since the vent pipe will be larger than the wall studs you want be able to go through the walls unless you have 6in. stud walls and the vent pipe for a dryer is usually 4in. I think. If you do have 6in interior walls you can run through them but make sure it's interior walls instead of outside wall interior walls usually dont have insulation. If you can't go through the walls your next option is simply through the each floor and out the roof or out the wall. Build a square chaise around the vent with 2x4 lumber, drywall and finish.Be careful if you go through the walls you may have to reroute wiring and water pipes.
Sep 07, 2009 | Samsung DV337 Electric Dryer
Need height from floor to dryer vent outlet for installation of dryer vent
It depends on what floor you are on. If its on a second floor you can put it wherever, but if its on a first floor, its once you vent outside, it needs to be 12 inches from the ground to the top of the vent hood. Check with your local code officials for any codes specific to your municipality.
Aug 03, 2009 | GE DBXR463EDWW Electric Dryer
I have a venting question for a new Whirlpool 9550 steam dryer
The vent must remain the same diameter all the way out. Previously installed vents do not often line up well. To get the dryer closest to the wall the bottom method sounds like the best shot. I would build a frame from 2x6s so you can design it exactly to your purpose. A purchased pedestal will still have some limitations.
eric
Jul 02, 2009 | Whirlpool WED5800S Electric Dryer
Dryer gets hot and drum is turning clothes are not drying. cleaned lint tray and removed tubing venting outside and the dryer is making a whining noise. the dryer is only 14 months old
If the drum is turning and the dryer is getting hot, then this is good news, as it means that the dryer is mechanically sound.
First check to see if the internal workings of the dryer are not blocked by running the dryer with the vent tube detached. If there is lots of warm moist air coming out the hole in the back of the dryer where the tube should be, then your dryer is fine.
Next, if you've checked the tube that connects the dryer to the wall or floor and it is clear, then on to step 3.
Probably you have a blocked or severely restricted vent tube from the wall or floor to the outside. Over time, these always become clogged with wet lint that builds up into a crust on the walls of the tubing.
Find the exhaust exit on the outside of the house and run a sewer snake up into it to see if you can open a hole in the blockage. If that works to help the air flow, then you need to replace the tubing from your laundry room to the outside, as it is probably a solid crust of lint that has built up over years.
Again, the good news here is that your expensive new dryer is probably fine.
Jun 10, 2009 | GE Dryers
Venting
don't believe it can look under bottom for a knock out similar to ones on each side ..most of those dryers are stackable and vent out either side
Jun 11, 2008 | Frigidaire FEQ1442ES Electric Dryer
Dryers Logo
121 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
