Question about HP Designjet T1100ps Printer
Error 47:01 for hp desighjet t1100 plotter - HP Designjet T1100ps Printer
  • HP Master
  • 1,915 Answers
This error relates to the starwheel assembly and motor. Open the printer and make sure that there are no paper jams or anything blocking the star wheels (the little pointy wheels that guide the paper.
If nothing is visisble then service diagnostics are required. Not sure of your technical skill level, so post back if you are comfortable disassembling the unit, if not, contact HP to find a local Designjet technician.
Posted on May 21, 2011
2 Suggested Answers
  • 96 Answers
SOURCE: error 47:01 for hp desighjet t1100 plotter
System Error: 47:YZ
Problem
Description:
Star wheels motor error..
Corrective Action: Try the following:
�� Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Reconnect the power cord and power On the Printer.
�� Check that the Starwheel Assembly cable is not damaged and is correctly
connected to Main PCA.
�� Open the Window and check for any visible obstacles restricting the
movement of the Starwheel Assembly, then clear the obstruction.
�� Perform the Scan Axis Starwheel diagnostic test to troubleshoot the
problem further → Page 4-7.
�� Replace the Starwheel Motor → Page 8-167.
�� If the System Error continues, replace the Main PCA
Okay, this is direct from the repair manual. if this is a new printer you have one year warranty service on this printer. hope this helps!
Posted on Oct 01, 2009
Hp designjet t1100 blank hard drive installation
Unfortunately I had a similar issue with an HP A0 printer. The Hp 'Engineer' could not fix it. The hard drive had failed and there is a complete new hard drive with software loaded available but only through Hp.
Feb 27, 2014 | HP Designjet T1100ps Printer
02.1.10 error plotter t610 and solution
The error code 02.1:10 means the plotter has a communications problem between the main logic board and the carriage PCA. The possible parts at fault are: The Carriage PCA, Trailing Cable, or the Main Logic Board, all available here: Designjet T610 Parts
You can watch this video to see how to remove the covers Designjet T610 Belt Replacement How To Video
The service manual is here: Designjet T1100-T610 service_manual
Sep 18, 2013 | HP Designjet T610 InkJet Printer
Error code 02.1.10
02.1:10 service station error- failure to reach home position .
you need a service tech to replace the service station within the plotter
Aug 14, 2013 | HP Designjet T1100ps Printer
Error 47:01 in hp plotter t1100
Indicating "Star Wheel Motor" error, Perform the Scan Axis Starwheel diagnostic test,Entering in Service menu: hold the Up arrow key and the OK key down andswitch the printer ON using the front power switch. Wait until the LED of thepower switch stops flashing (usually after 5 seconds) before releasing ALL Diagnostics menu,go to scan axis, enter,go to star wheel lifter,press OK.. complete the mode..if fails remove star wheel are clean all gears refix again, do the diagnostic again..if you have manual that better to process the things.. Best of luck
Sep 27, 2011 | HP Designjet T1100ps Printer
El plotter t1100 saca el error 47:01 y no quiere arrrancar
Star wheel motor faulty,( to remove star wheel unit open left cover,formatter,power module,spitton)Normally most of the cases motor wont go gear unit pensions breakage observed mostly, replace star wheel motor unit or if you are tech guy you can make alteration see the snap shot how pinion got breakage..Find out metal pinion suitable for the same and fix it properly. 11_19_2011_4_07_20_am.jpg11_19_2011_4_07_49_am.jpg11_19_2011_4_08_22_am.jpgThis is the
Feb 01, 2011 | HP Designjet T1100ps Printer
Star Wheel Motor has a problem.
01 code says "reseat/reconnect/clean and manually adjust" the motor.
The Star Wheel Motor is on the left side of the printer.
If you arn't trained on it, get someone who is, to service it.
Jan 23, 2011 | HP Designjet T1100ps Printer
I am faceing the problem hp dj t1100 inkjet printer. No connectivity avaiable.
For a single computer you can install a JetDirect card and assign an IP address. Then connect the computer to the plotter directly through the ethernet connection on the computer using a cross-over cable (standard ethernet cable will not work unless you use a hub). Another option is to simply use a USB cable connection. Drivers are available from HP.com, Support, Downloads.
Mar 02, 2010 | HP Designjet T1100 Photo Printer
When I turn on my HP designjet T 1100 I get error message 08:11
turn off printer, disconect hdd from pcb, turn on then printer beeps, turn off mount hdd back, turno whait ;).
Mar 19, 2009 | HP Designjet T1100ps Printer
System Error: 47:YZ
Problem
Description:
Feb 03, 2009 | HP Designjet T1100ps Printer
HP Designjet T1100ps Printer Logo
1,404 people viewed this question
Seeker5211
Seeker5211
