Question about Nokia 7610
Low memory in my nokia 7610, how to delete some data (messages)
I have Nokia 7610 and I got this message when I use it "Not enough memory to perform operation. Delete some data first." I discovered that my inbox message is full and when i want to delete a message I can not and I got the same message above. How to clear all inbox, sent messages from my phone.
Thanks in Advance,
  • pappuraj Aug 15, 2008
  • Nokia Master
  • 1,800 Answers
Give it a soft reset then try to mark all th e messages and delete them for once
*#7370# then yes then 12345
u might need a memory card
Posted on Aug 16, 2008
I have a nokia c5-03 and i get the message:not enough memory to perform operation.delete some data first but i cannot enter anywhere(in settings) or application manager,etc because i get this error. also...
If the phone notifies you if the phone memory is getting low. To free phone memory you have the following options:
  • Move data that you want to keep to an alternative memory (mass memory or memory card, if available) or to a compatible computer.
  • Remove data you no longer need.
Use File Manager or the respective application in your phone to remove data or to move data to alternative memory as described in the user guide. Typically you first mark files to be removed or moved and then you select the corresponding option (Delete orMove to folder).
Use Nokia Ovi Suite to move data to a compatible computer.
In order to free phone memory, you could remove or move the following:
  • Messages from Inbox, Drafts and Sent folders in Messaging
  • Retrieved e-mail messages from the phone memory
  • Saved Web pages. Clear the web browser cache to free some phone memory (e.g. select Options > Clear privacy data >Cache).
  • Saved images, videos, or sound files (in Gallery, Photos,Videos or Music player)
  • Contact information (in Contacts)
  • Calendar notes (in Calendar)
  • Downloaded application packages
  • If there are applications which are not needed any more, uninstall them with Application Manager
  • Any other data that you no longer need
If you are deleting multiple items and any of the following notes are shown: Not enough memory to perform operation. Delete some data first or Memory low. Delete some data, try deleting items one by one (starting from the smallest item). After deleting data, restart (power off/on) your phone.
Tips: Use the memory card or mass memory instead of phone memory in the Camera or other applicable applications in case the selection is available (e.g. via Options > Settings >Memory in use).
I hope this helps!!
Aug 06, 2017 | Nokia Cell Phones
I have a very old phone, Nokia 7610. it keeps displaying an error message: not enough memory to perform operation. delete some data first. i wasn't able to do the * + 3 + call key + on/off. i can't seem...
press and hold the menu button ..it will show you the apps and program you've just operated,..then click by it one by one and close it properly..do the same procedure on other apps ..thanks
Apr 28, 2011 | Nokia 7610
NOKIA 7610 Message memory change problem: i had been using my phone memory for storing messages. But it was getting somewhat overloaded so i switched to message card recently. Then once i had to see a...
Its like the memory card is faulty and this has affected the phone
all u have to do is.
get a memory card reader, insert the memory card, and connect it to a computer (desktop or laptop) format the memory card. after-which, get the original U.S.B cable of your NOKIA 7610 phone connect it to the phone and the computer and also format it.
With this, the memory card and phone will be empty.
after that, you can then receive messages and open them without problems.
But, if the problem continues, go to your phone MENU, click on SETTINGS, then also click on RESTORE FACTORY SETTINGS, it will request for a security code,, enter 12345 then the settings will be reset....
then you can enjoy your phone..
thanks
Benluis....
Jan 11, 2011 | Nokia 7610
My nokia N72 showing in the screen ''massaging not enough memory to perform operation.delete some data first'' when i want to write msg.
sir delete the inbox,sent message,outbox,draft,messages to get the enough memory from the phone and then you can send the message...........
Nov 22, 2010 | Nokia N72 Cellular Phone
Sir i have an 7610 mobile.... i have a problem with message section ... when one message received and send to my mobile..there is a problem occured that is please delete some data but i deleted all memory...
you may want to consider hard formatting your nokia phone.
switch off your phone, remove your sim and memory card.
press and hold these buttons at the same time, 3, *, call key and power on switch, don't release until you see the nokia and hard formatting message.
if first try is not successful, just repeat the pressing of the buttons. please be aware that it will do a factory reset, it will help you to erase the errors that the phone encountered..
regards.
Mar 03, 2010 | Nokia 7610
Hi i have nokia 7610 when i use it not enough
Tray to go to setting and choice back to factory setting with 12345 code.Good luck
Jan 19, 2010 | Nokia 7610
Problem in my nokia n72 memory card
There is a lil bit of tweak that you will have to do.
goto messaging and then goto settings here select the message memory to be saved in memory card.
Once you have some data transfered thru bluetooth, it will go to memory card.
Rate it, if it helps.
Jun 24, 2009 | Nokia N72 Cellular Phone
Problem with nokia 7610
RESET YOUR MOBILE PHONE AND MEMORY CARD, MAKE SURE TO BACK UP YOUR DATA FIRST.
Feb 25, 2009 | Nokia 7610
Msg: Not enough memory Delete some data
It is due to ur phone's memory must be low.
just do the following steps
Go to Messaging->settings->other->memory in use and select memory card
this will solve ur problem
Jan 07, 2009 | Nokia N72 Cellular Phone
Memory low n70
You need to change default storage device on your phone, from phone memry to card memory. In other words, move all data (messages, songs, videos etc) from your phone memory to card memory.
for example, go to messages>options>other>momory in use - change it to memory card instead of phone. (if your memory card is not named, it will be displayed as NO NAME).
Do the same with other data also.
Dec 13, 2008 | Nokia N70 Cellular Phone
Nokia 7610 Logo
286 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
