Question about Vacuums
I have an old singer mod.31k15 comercial sewing machine I need to buy replacement needles for it but dont know te propper size that fits the machine or where to get them
SOURCE: my singer 4166 sewing machine won't pick up the bo...
I had the same problem straight out of the box. I decided to buy a new machine and came across the 4166. It had more than enough functions and seemed to run smoothly. I too have problems with the bobbin not threading so I took it back into the store thinking I was doing something wrong. The saleswoman had the same problem. I was going to exchange it for another but before leaving I wanted to check to see if it worked. Again, same problem so I left without a machine. I spoke to the owner only to be told that 30% Singer machines are lemons and have to be returned for servicing because they don't work from the start. This is a waste of money and time.
The only suggestion I can offer is to either forget about the machine or take it into be serviced.
Posted on Jun 26, 2010
  • 78 Answers
SOURCE: Unable to locate needles for Singer Ultralock
try singer needles 2054 you should be able to find them on line or at a local sewing store
Posted on Jul 01, 2010
joeguest2
  • 2080 Answers
SOURCE: I have a singer sewing
Here are a few similar items on EBay which should give you some idea what people are asking / offering for items like that:
http://cgi.ebay.com/VTG-SINGER-SIMANCO-SEWING-MACHINE-BENTWOOD-CASE-/220779717184?pt=LH_DefaultDomain_0&hash=item33677f2240
http://cgi.ebay.com/Antique-Singer-Sewing-Machine-cabinet-1931-Simanco-/320696748066?pt=LH_DefaultDomain_0&hash=item4aab040822
http://cgi.ebay.com/VINTAGE-SPARTAN-SIMANCO-SEWING-MACHINE-WOOD-STAND-/320688377057?pt=LH_DefaultDomain_0&hash=item4aaa844ce1
http://cgi.ebay.com/ANTIQUE-SINGER-PORTABLE-SEWING-MACHINE-SIMANCO-BRITIAN-/250817313018?pt=LH_DefaultDomain_0&hash=item3a65e078fa
http://cgi.ebay.com/Vintage-Singer-Simanco-Sewing-Machine-/220779042835?pt=LH_DefaultDomain_0&hash=item336774d813
Just use your mouse to click on one of the five links, which are the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
Thank you very much and good luck.
Posted on May 09, 2011
  • 517 Answers
SOURCE: sears kenmore 158.321 sewing machine
Good day!!!
If the problem is always broke the needle..
The problem could be the correct timing of the machine please adjust the timing of your sewing machine to fix your problem...
Thank you and good luck..
Posted on Jun 24, 2011
  • 244 Answers
SOURCE: In my Singer Sewing Machine
There could be several things causing this.
First, be sure the bobbin is in the bobbin case correctly. There is usually a line diagram showing the correct placement or you can check the owner's manual.
Second, make sure your needle is inserted correctly. If it is not completely set in the housing, this can prevent the bobbin thread from being caught by the hook. The groove in the needle should be ffacing toward you to assure that the thread interacts with the hook.
Third, be certain the upper threading is correct...passing through all thread guides and correctly through tension and take up lever.
Finally, make sure the bobbin case is free of lint. The machine brush that came with the machine will clean this area well.
I hope one of these suggestions helps you solve your problem. If so, please come back to Fixya and rate my advice!
Posted on Jul 24, 2011
What can you do to stop squeaking when I'm winding bobbin
Spray wherever the squeak is coming from with a dry silicone lubricant called 'Jigaloo' or WD40 Dry Silicone Lubricant. It is also great for sliding windows.
WD 40 300014 Specialist Water Resistant Silicone Lubricant Spray 11 oz...
Jan 13, 2016 | SewShop.com Singer Model CE200 Quantum...
How do i fix my tension,bunches up the thread
sounds like a blunt needle,or tension at wrong setting.replace needle first.adrian,,,,
Feb 12, 2015 | Singer 8763 Curvy Computerized Sewing...
HOW TO INSTALL NEEDLE PLATE ON SINGER 30518 SEWING MACHINE?
Hey, i just took the needle plate out to clean and i cant put it back. same model 30518, somebody can help? :(
Oct 27, 2014 | SewShop.com Singer Model 30518 Instruction...
What is my needle hitting that breaks it on my singer sewing machine 247
sounds like the machine is out of time . best solution is to take it in to be repaired .
Oct 11, 2014 | Singer Tension Assembly, Fits: Models 242,...
Timing after installing new belt
There are about 3 MAIN delicate issues here, could be needle bar, top shaft or bottle shaft, to understand timing first knowing that needle hook is passing the cusp of the needle on its way up....
Feb 25, 2014 | SewShop.com Singer Model 758 Touch & Sew...
Need a manual for my singer sewing machine it is a singer genie 353 or 354
HI......................
Singer 353 and 354 sewing machine service manual.
Note* This is a service manual. If you need the instruction manual or the great little trouble shooting and adjusters manual, we also carry both in our store.
Service manual includes:
* Bobbin winder
* Rotating hook
* Motor and electrics
* Needle bar
* Presser bar
* Much more
THE MANUAL LINK IS GIVEN BELOW.............
http://sewingmanuals.blogspot.com/2011/04/singer-genie-353-354-sewing-machine.html
GOOD LUCK..................
Sep 22, 2011 | Vacuums
How old is the singer sewing machine with the serial number g1027369
You have a Singer Model 27, built at their Elizabethport factory in Elizabeth, NJ, in a production run of 40000 which were manufactured in 1911. Confirmation from Singer available by clicking here.
Your machine is very nearly 100 years old, but in good condition will still be fully usable and you can still buy many spare parts for it.
I trust that I have fully answered your question; please take a moment to rate my reply.
Sep 04, 2010 | Vacuums
Vacuums Logo
429 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
