Question about Whirlpool Washing Machines
Motor coupling on whirlpool washer model LSQ9600LW0
3 Suggested Answers
honeymokey
  • 3113 Answers
SOURCE: My Whirlpool washer Model LSR5233EQ1
Try this--- http://www.youtube.com/watch?v=WLPGs2UMUJc
Posted on Jan 12, 2011
Macmarkus
  • 2605 Answers
SOURCE: Sister in law has a
Welcome to FixYa.
Based on the info you provided in your post, it quite likely is the drive coupling that has broken...it is very common, that would indeed explain the noise appearing to be from the motor.
**Unplug the washer from it's source/the wall before performing any service to the unit...safety first**
To inspect the drive coupling to confirm it is broken or not, you can lean the washer back (careful of the hoses) to allow you to visually inspect it or remove the cabinet completely...it is fairly straight forward and can be done even by a novice "handyman/person"
Part number is 285753A and will look like this image....
I've attached a link here that will provide the part availability and clear instructions to replace the coupling but also help describe the removal of the cabinet or to just inspect everything thoroughly. Once there scroll to the bottom of the page.
http://www.repairclinic.com/PartDetail/Motor-Coupling/1195967
Let me know how you make out or if you require further assistance and I'll be glad to help in any manner I can. Good luck.
Regards,
Macmarkus :)
Posted on May 20, 2011
Replace belt for model CJ4732600
that model number you sent isn't a good model number,your problem is under Whirlpool Ultimate Care II LSQ9549L Top Load Washer,if this is your washer there isn't a belt in it,it has a motor coupling,let me know if this si your washer and i can help you out.
Jan 16, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool top loader washer will not spin
Could be one of several different things depending on the age and model. If its less than 10 years old and is a top load washer its probably a motor coupling (connects the motor to the transmission kinda like a belt) or lid switch. If the water is draining out but the washer is not spinning its probably the motor coupling. If it still has water in it and won't spin, its probably the lid switch. If your washer is a front loader there could be several things going on. Hope that helps.
Aug 29, 2011 | Whirlpool Washing Machines
Need to replace coupling between tub and motor? How does tub come off?
If you are referring to the motor coupling, it is actually located between the drive motor and teh gearcase. You DO NOT have to remove the wash tub in order to access and replace it. The following link explains step-by-step how to replace a motor coupling on a Whirlpool top loader:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
If you have questions about this repair, or if the model washer you have differs from the one you listed this question under, please post back and let me know. I hope this helps you.
Apr 19, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool type 111 model LSQ9200LQ3 washer not
I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
Jan 30, 2010 | Whirlpool Washing Machines
Will not spin. whirlpool washer model no GSQ9344EZ0
tip washer over and check the rubber coupling from motor to transmission. if the coupling breaks it will wash but not spin. it is between motor and transmission.
Jan 11, 2010 | Maytag PAV2300 Top Load Washer
I have a whirlpool ultra care 11 washer, model # LSQ92002T0. WILL NOT DRAIN OR AGITATE. STARTED FINE STOPPED DURING USING. THANK YOU
Your motor coupling is probably broken. Tip washer back and look for rubber shavings or any broken plastic.Motor coupling goes from motor to transmission This is common with these models/t.Visually check coupler.
Jul 07, 2009 | Whirlpool Washing Machines
My Estate Whirlpool Washer, model #TAWS850PQ0 fills the tub but does nothing else. It does not agitate or spin, just hums.
if it cuts off the water ok and motor running
it could be a coupling .
possible transmission.
if no motor noise
could be motor .
wiring,
timer.
Jun 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultra Care II
I believe this is a similar model to mine, which did the same things. This is a direct drive style (no belt). What possible happened is the coupling in between the motor and transmission has broken partially, and it "grabbing" only under a light load. It's a relatively inexpensive (under $5) part, and can be changed pretty easily.
These couplings can be found on Ebay:
http://cgi.ebay.com/285753-Whirlpool-Washing-Machine-
Motor-Coupling-Coupler_W0QQitemZ170183665420QQihZ007QQcategoryZ20714QQss
PageNameZWDVWQQrdZ1QQcmdZViewItem
If this link doesn't post correctly, just search for "whirlpool coupling". Good luck.
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer does not spin or agitate
you need to remove the cabinet to expose the washer. once you do that you need to remove the 2 clips that hold the pump to the motor. then remove the 2 1/4 inch screws that hold the 2 clips onto the motor. ( remove the wireing connector first) remove the motor and Im sure you will find that the coupling need to be replaced. There are 3 parts to the coupling. 1 rubber and 2 white plastic parts. replace the coupling and install everything in reverst. your washer should work fine after this.
Jul 22, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
64 people viewed this question
Dan Webster
Dan Webster
prem mathew
