I have a Frigidaire FWT425RHS0 model washer and it stated making noise while spinning. it is like a loud knocking sound.
  • Washing Mach... Master
  • 2,183 Answers
You can unplug the washer,remove the bottom panel and check the shocks to see if they are damaged but most of the time when this noise happens it's usually the spider gear and the part is around 250 to 300.you have to split the tubs and install a new basket that sits in between the inner and outer tubs,it would be cheaper in the long run to replace the washer instead of repairing it but that's up to you to decide.most of the time this happens from using to much detergent,the extra detergent eats at the metal that the gear is made of and it just falls apart,any front load washer you get you should be using 1/4 cup of H.E. detergent.good luck and i hope my opinion helps you out.
Posted on May 20, 2011
  • Biguggy May 26, 2011
    Many posts on many sites claim that the corrosion of the spiders is due to galvanic action. I do not agree, I believe it is primarily chemical corrosion.
    Should the corrosion have been galvanic between the stainless steel drum and the aluminium spider the majority of the corrosion would have been at the junction of the two metals i.e. at the ends of the arms. I have seen no photographs of spiders corroded in such a manner, nor read of any similar descriptions.
    Aluminium, and its alloys are corroded when immersed in an aqueous solution with a pH value above about 8.0 or below about 4.0 (nitric acid is a well known exception). All detergents have to be above about 8.0 or they would not work. The Material Safety Data Sheets put out by Proctor and Gamble state that the pH for one of the liquid ‘Tides’ is 8.0 and for one of the ‘Tide’ powdered detergents as 11.0. Bleach, (sodium hypochlorite) is also very corrosive to aluminium. I should add that for corrosion of the spider to take place these levels are considerably above the levels found in a washing machine during the wash/rinse phases of the cycle.
    Sodium carbonate (washing soda) and sodium percarbonate found in some laundry aids (Affresh and Oxi-Clean [powder]) are also corrosive to aluminium and its alloys, as is borax, provided the required concentrations are reached.
    I believe the mechanics of the corrosion are as follows.
    Even after the fastest spin small quantities of water will remain on the shaft and towards the centre of the spider. Any recesses in the spider close to the centre will aggravate this situation. This water will contain ‘contaminants’. Should sufficient of these ‘contaminants’ be present the pH of the mixture can, as evaporation takes place, rise to a level where corrosion will take place.
    Corroded spiders can be seen at: -
    http://fixitnow.com/wp/2009/10/28/front-...
    http://softsolder.wordpress.com/2010/07/...
    and for a LG spider
    http://www.viewpoints.com/LG-TROMM-Front...
    For information on galvanic corrosion there is a very good paper at: -
    http://www.unene.ca/un1001/UN1001_Galvan...
    For information on chemical corrosion of aluminium (or ‘micro galvanic corrosion as the author calls it, I grew up calling it ‘pitting corrosion) there is an informative paper at: http://www.sintef.no/static/mt/norlight/...
    The only front load washers readily available in North America that I am aware of that do not have recesses close to the centre are Miele and Speed Queen. However there are numerous complaints on the internet about foul odours from these machines, in their favour is the fact that spider failures are virtually impossible to find.
  • Sal DeAngelo May 28, 2011
    every home that i went to that had damaged spider gears all were using 3/4 to one whole cup of H.E. detergent and all of them had damaged or disintigrated spider gears,ive even found pieces of the gear lodged into the pump and snapping shocks so i know what i see handson so read and copy and paste whatever you want but like i say i know what i see and pulled two of them apart and old nasty smelly detergent was on both metal gears
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Loud noise in final spin
Verify that the inner drum isn't broken. Sopin by hand it should trun smoothly and staight.
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
FWT445GES1 Washer makes loud banging noises like it's going to explode.
Washer- you need a complete tub and bearring kit. this is a common problem for people who have well water. (also just happens) the rear yoke has become corroded and broken. its a costly repair.
dryer - you would need a new front slider seal. very simple to install.
May 28, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire tumble action frontload washer loud knocking noises
These are the stabilising blocks. They are there to stop the knocking and noise. You should be able to buy them. Try the manufacturer or go on Yahoo or Google search for wash machine spares. Hope this helps.
May 20, 2009 | Frigidaire 14 Cycle Tumble Action Washer
Gallery ser. front load makes loud clunking sound in all cycles
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgsgsgf
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Fridgidaire Washer has a loud knocking noise during spin cycle.
You need to replace your washer, the Inner tub Spider broke.. I repaired mine, With me doing the labour, $285 just for the part alone. plus about 3 to 4 hours labour.
Mar 14, 2009 | Frigidaire FWTBB30DS Front Load Washer
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
